gholland(at)content-strea Guest
Posted: Sun Oct 13, 2013 11:24 am Post subject: NDB Let downs |
A local Ryan Air Captain here tells me that he does NDB letdowns regularly as some of their destinations are not ILS equipped.I'm presuming it's probably the same with EasyJet.
The young lad in my Hangar just gone professional and now has his CPL/IR (self funded!) and the IR certainly involved NDB letdowns.
Gerry
Gerry Holland
gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)
+44 (0)7808 402404
[img]cid:4C0DBE17-4DEB-411D-BF75-8C8AFF101B75[/img]White Ox Mead Airstrip, Bath. England
7.92 KB |
3403 Time(s) |
stranfaer(at)btinternet.c Guest
Posted: Sun Oct 13, 2013 11:31 am Post subject: NDB Let downs |
NDB usage is certainly part of the UK IMC test and training. VOR is also of course part of it.
And to finalise this discussion it is not legal to fly in IMC or train on our LAA permit Europa aircraft! which are cleared for daylight VFR use only.
rgds
David Joyce
The other one....
Sent to you from David Joyce
www.eastmidsspas.com
From: Gerry Holland <gholland(at)content-stream.co.uk>
Sent: Sunday, 13 October 2013, 21:24
Subject: Europa-List: NDB Let downs
Gerry
Gerry Holland
+44 (0)7808 402404
[img]cid:1.763002741(at)web87403.mail.ir2.yahoo.com[/img]White Ox Mead Airstrip, Bath. England
7.92 KB |
3402 Time(s) |
houlihan(at)blueyonder.co Guest
Posted: Sun Oct 13, 2013 11:38 am Post subject: NDB Let downs |
Hi Gerry.
I bet you will find that his Ryanair bomber has a simulated ADF derived from INS and GPS systems I doubt they have an ADF receiver fitted.
Knowing Ryanair I bet they charge the crew to use the equipment installed.
On 13 October 2013 21:24, Gerry Holland <gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)> wrote:
| Quote: | A local Ryan Air Captain here tells me that he does NDB letdowns regularly as some of their destinations are not ILS equipped. I'm presuming it's probably the same with EasyJet.
Gerry
Gerry Holland
+44 (0)7808 402404
7.92 KB |
3401 Time(s) |
Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Sun Oct 13, 2013 11:40 am Post subject: Re: NDB Let downs |
Hi.
No problem with NDB approaches, a higher minima in ALT and Vis are used.
Sometimes it VFR only landing, with an instrument approach with a break off height, then circle to land, often in mountainous terrain.
Alan
Posted: Sun Oct 13, 2013 11:56 am Post subject: NDB Let downs |
Tim Hi!
You could be right on all counts!
They seem to be fitted with Honeywell Quantum Line which does have VOR and ADF in the range somehow.
Gerry
