Flap positioning system
Ed Godfrey
PostPosted: Wed Oct 09, 2013 1:36 pm    Post subject: Flap positioning system Reply with quote
For those of you who installed the Flap Positioning System from
Aircraft Extras, did you install it where Vans suggests to install it in
the tunnel, or elsewhere. I am concerned about the heat in the tunnel.
Any thoughts would really be appreciated.
Ed Godfrey
40717
rleffler
PostPosted: Wed Oct 09, 2013 1:50 pm    Post subject: Flap positioning system Reply with quote
I would be more concerned about mixing fuel vapors and electronics than heat.
I have a VP/X, but I would put it behind the panel if I were to install one.
On Oct 9, 2013, at 5:35 PM, Ed Godfrey <egodfrey(at)ameritech.net> wrote:
For those of you who installed the Flap Positioning System from Aircraft Extras, did you install it where Vans suggests to install it in the tunnel, or elsewhere. I am concerned about the heat in the tunnel. Any thoughts would really be appreciated.
Ed Godfrey
40717
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
tfarrell839
PostPosted: Wed Oct 09, 2013 5:53 pm    Post subject: Flap positioning system Reply with quote
I haven't done the aircraft extra's flap system, but we've always found room for the TCW safety trim box behind the panel. I second installing it there. When the plane is fully assembled you will have better access as well. The tunnel cover takes some time to remove and replace.
Ed Godfrey
40717
Tim Farrell
Aircrafters
831-722-9141
Mauledriver(at)nc.rr.com
PostPosted: Thu Oct 10, 2013 8:15 am    Post subject: Flap positioning system Reply with quote
Mine is installed in the tunnel as suggested. I don't think it can
practically be installed elsewhere. Works fine, no worries here.
The tunnel can be hot but I don't think that's an issue here. The FPS
is behind the spar, the fuel is ahead of the spar so there is
significant separation.
Just FYI - I don't have any sort of flap position indicator... I just
look out the window. Seems natural and right as long as you have the
FPS detents.
Ed Godfrey
40717
hotwheels
PostPosted: Fri Oct 11, 2013 8:36 am    Post subject: Re: Flap positioning system Reply with quote
Here's where I mounted my flap controller. The photo is a bit dated, but close enough.
The only thing in the tunnel is the motor. I've inspected this area several times since phase 1 and it's pretty easy to get to.
I also have the flap safety trim system, but it's mounted on an under panel drop down tray on the copilot side.
Jay
N433RV - Flying
 Filesize:  62.34 KB
 Viewed:  7208 Time(s)
