asarangan(at)gmail.com Guest
Posted: Fri Oct 04, 2013 8:08 pm Post subject: AN bolts too long |
I noticed that all bolts for the CS14 brackets are specified to be about one size too long. The manual calls for AN3-6A to mount the brackets to the cockpit module. Since these bolts are only partially threaded, I was running out of threads before the nut was able to grip. So I ordered some AN3-5A bolts and that worked better.
Then I noticed the same problem when mounting the bellcrank onto the CS14 brackets. The manual calls for AN4-12A, but they are too long.
Has anyone else noticed this, or am I missing something here?
craigb(at)onthenet.com.au Guest
Posted: Sat Oct 05, 2013 2:41 am Post subject: AN bolts too long |
It’s been a few years, but yes I recall some of the bolts called for were too long without the use of many washers to pack out the space
So I opted to go down one size I seemed to have a lot of extras of most sizes so I didn’t need to order them
craig
Posted: Sat Oct 05, 2013 7:12 am Post subject: AN bolts too long |
Thank you for that reply. That is reassuring to know...
On Sat, Oct 5, 2013 at 6:40 AM, craig <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)> wrote:
craig
arget="_blank">http://www.matronics.com/Navigator?Europa-List
tp://forums.matronics.com
