peter(at)sportingaero.com Guest
Posted: Thu Oct 03, 2013 12:26 pm Post subject: Dual voltage output from fuel quantity senders |
I have 2 fuel gauges in my airplane that work on 12v and 5v, and only
one (resistance type) sender. I am trying to figure out how to get both
gauges to work and be accurate. The 12v gauge is a straight analogue
device with a pointer. The 5v gauge is part of an EFIS. At present I am
using the analogue gauge only and the EFIS is continually upset at
having no fuel quantity input.
I have looked into a solution using an Arduino, sampling the data in
doesn't seem to be too difficult, using the analogue input and a voltage
divider circuit to drop the input voltage. I think I can get the Arduino
to drive something like a MCP41100 8 bit dual digital potentiometer as
an output device, with the 2 channels one for each of the 12v & 5v
circuits. However these devices work at 5v and low current.
So my question to the smart people here is how to I use the output of
these digipots to look to the gauges as though they are a 30-240 ohm
fuel quantity sender?
Regards, Peter
billp(at)wwpc.com Guest
Posted: Fri Oct 04, 2013 7:11 am Post subject: Dual voltage output from fuel quantity senders |
Eric M. Jones
Posted: Fri Oct 04, 2013 10:13 am Post subject: Re: Dual voltage output from fuel quantity senders |
| Quote: | I have 2 fuel gauges in my airplane that work on 12v and 5v, and only
Regards, Peter |
| Quote: | | sampling the data in doesn't seem to be too difficult, using the analogue input and a voltage divider circuit to drop the input voltage |
So Peter, why not run that output into the Efis? Or if this won't do, then reduce the 12V ratiometric voltage with an op amp. I think your approach is getting way too complicated to start adding an Arduino.
What am I missing?
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
