jpkarnes
Posted: Wed Oct 02, 2013 1:03 am Post subject: Low RPM @ full throttle |
Hi all,
After installing my Ram heads and dual dizzy's, I am only getting 3600 RPM (at) full throttle. The engine is running smooth with no hiccups, just only getting 3600 RPM. The Bing carbs are the original setup with the old heads and Subaru ignition. Any suggestions?
John K.
Zenith 601 HDS
Bremerton, WA
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
larrycmcfarland(at)gmail. Guest
Posted: Wed Oct 02, 2013 5:52 am Post subject: Low RPM @ full throttle |
Hi John,
I’d look at the butterfly travel and linkage at the carbs. If you’re running distributors, I’d look at fly-weights in the distributor. Check your carbs and jets for corruption from the tank. I was surprised to have lots of aluminum swarf and grit from construction of my tanks with same result. Smooth could be with misadjusted valve gap and or timing. Get a good filter on your fuel line ahead of the carbs. I used a see thru type, no problems.
Larry McFarland
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of jpkarnes(at)comcast.net
Sent: Wednesday, October 02, 2013 4:04 AM
To: stratus-list(at)matronics.com
Subject: Low RPM (at) full throttle
Hi all,
John K.
Zenith 601 HDS
Bremerton, WA
01234567890123
