Battery questions
Goto page 1, 2, 3, 4  Next
Fred Klein
PostPosted: Mon Sep 30, 2013 3:50 pm    Post subject: Battery questions Reply with quote
All,
Are there any Europas flying w/ something other than an Odyssey 680, and would there be a good reason to choose another brand or type?
Experience and insights welcomed,
Fred
pestar
PostPosted: Mon Sep 30, 2013 5:37 pm    Post subject: Re: Battery questions Reply with quote
Fred
Do not have a Europa, but have a DynAero MCR-4S Rotax 914 powered. I have just swapped my dual Odyssey batteries out for dual AeroVoltz (12 cell) Lithium Plumbate (they do not burn or ignite) batteries.
Reason
400 Cold cranking amps verse 170
20AH verse 7AH
2/3rds the weight and slightly smaller. Same height and width (just the length is shorter).
Did not need to swap my Odysseys but liked the look due to the all electric design of the 914. Price approximately the same.
So far so good, use a Schicke GR6 regulator verse the Ducatti (approved by your LAA).
Cheers Peter
Peter Armstrong
Auckland, New Zealand
DynAero MCR-4S (Do not shoot me Smile ).
ptag.dev(at)tiscali.co.uk
PostPosted: Mon Sep 30, 2013 10:55 pm    Post subject: Battery questions Reply with quote
Hi! Fred, Answer .......two Odyssey 680's on the passenger footwell in
parallel. (initially prompted to get the Jabiru 3300 six cylinder to crank)
now in use with the 914 and a heavy duty starter is totally an instant
start. Stop fiddling on the edge and just go for it .
Bob Harrison G-PTAG
ward.t(at)xtra.co.nz
PostPosted: Mon Sep 30, 2013 11:26 pm    Post subject: Battery questions Reply with quote
Fred,
Try a Shorai Lithium iron (not ion) battery. Wonderful, powerful, expensive but brilliant for my Rotax 912s with the old original starter. New technology! Talk about light weight, small and so powerful!
See;
Enjoy your Shorai LFX battery!
SHORAI INC.
845 STEWART DR., SUITE C SUNNYVALE, CA 94085
See http://shoraipower.com for full product details and much more... Please use the on-site CONTACT form to ask us for help with installation, if needed.
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Ph 64 3 3515166
Mob 0210640221
On 1/10/2013, at 12:45 pm, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
[quote]--> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
All,
http://www.matronics.====================================================; - MATRONICS WEB FORUMS -http://www.matronics.com/contribution
_-============================================================
frans(at)privatepilots.nl
PostPosted: Tue Oct 01, 2013 1:25 am    Post subject: Battery questions Reply with quote
My experience and insight:
First you need to establish how many amp hours you really need.
I have two Odyssey 310's. They each have half the capacity of a 680.
Although I have a switch to put both batteries in parallel, the truth is
that so far I have never needed it. My 914 has started fast and reliable
on just one battery (250 flight hours), and this includes the occasions
where I had to crank excessively due to the hot start problem (which I
have now solved by closing the fuel pump prematurely to empty the carb
bowl before the engine shuts down). I can't believe how much cranking
power there is in a 310.
So, for starting you don't need any larger battery than this.
The 914 is dependant on electrical power (and I believe your engine is
dependant as well). So, you may need to have electrical power when your
alternator dies. If this is the case then you need to do the math and
calculate how long you want to be able to fly with a dead alternator and
how much amp hours are needed for that (and multiply that with two
because of battery aging and other reasons).
Another way to solve this problem is to install two alternators in your
ship. Assuming that you don't want to go beyond this reduncancy, now you
only need your battery to start the engine. It might be that a second
alternator is lighter than a larger battery, so you will save some
weight and it gives some piece of mind that in case of an alternator
failure you don't have to worry about the remaining capacity and charge
state of the battery.
I decided to go that route and have a second alternator installed.
The reason to use two small batteries:
With two alternators and two batteries I could make two totally
independant electrical systems. I have two fuel pumps, each on a
different system. I have two GPS's, both on a different system. I have
CHT gauges and a coolant gauge, both are wired to a different system.
And so forth. In reality it means that one of the electrical systems may
give up the ghost completely, but I will still get home safely.
(I don't want to become stuck at the North Cape or to run out of options
above the Alps or over sea).
Another reason is that I wanted to be able to use the glider wings in
the future. While soaring I would just use one electrical bus (and not
worry about depleting the battery), and save the other battery for
starting up the engine again.
To safe some weight I decided to use only very small batteries. With my
system setup I only need the batteries to start the engine, and to prime
the alternator. I made a provision to connect both systems together in
case of starting problems, but I never needed it so far. (In flight it
is forbidden to interconnect both systems because it defeats the whole
redundancy).
Once in two years I take out the battery of bus B, put the battery of
bus A into bus B, and put a new battery in bus A. (Bus A is used for
starting up the engine). This means that I always have a relatively new
battery for starting, and the "old" battery will get an easy time for
the remainder of its usefull life and will only be used for powering up
the fuel pump before start. It is a cost effective strategy.
About the Lithium things: I have decided against it for various reasons.
Although I have not researched the subject once my ship was ready, there
are a few things I remember:
1) The cell voltage of lithium batteries is different thant that of lead
acid batteries. It means that you will get a somewhat different voltage
than all your avionics was designed for.
2) Lithium batteries have special charging requirements. It means in
reality that you can't connect the alternator and battery in parallel,
but there needs to be some piece of electronics in between. This will
become a weak spot in your ship with no redundancy.
3) Field maintenance will be more difficult. Batteries sometimes die. A
lead acid battery is easier to replace, a motorcycle battery can be
sourced everywhere and will get you home. Also field charging is easier.
4) The technology has not matured yet. Some batteries explode, others
have only few charge/discharge cycles, others require complicate
management systems, and others have a weird discharge curve (with either
too much voltage sag during discharge, or just too little so the end
will come as a sudden surprise).
So, in short:
1) If I want to build a light weight ship with a non electrical power
depenant engine, I would install just a Odyssey 310.
2) If I want to build a light weight ship with an electrical power
dependant engine, I would use two alternators and still a small Odyssey 310.
3) If redundancy is important, I would use two alternators and two small
Odyssey 310's.
In my scenario's there is no place for anything heavier than an Odyssey
310, unless of course I need to have some ballast in the rear of the
ship. Then I would favor a bigger battery over just a piece of dead lead.
Frans
christoph.both(at)acadiau
PostPosted: Tue Oct 01, 2013 3:52 am    Post subject: Battery questions Reply with quote
Fred,
I have a Classic mount not allowing the heavy duty starter for the 912ULS.
Voltage stability during cranking is essential. So I decided to have
firewall forward a "Ballistic" 16 cell Lithium-Iron Battery cleared for
ATV's, large displacement motorcycles obtainable at any of those stores.
While the capacity for the largest obtainable model (16 cell) is only 9AH,
many comments online point to the fact that it holds cranking voltage
close to open cell voltage (13.4 Volts) while many OPB batteries drop as
much as to 10 Volts. Short term cranking amps are rated at 500A, the Rotax
starter takes only 60-70 amps.
I also saved 12 lbs weight, so the battery could be installed on the
firewall forward footwell Port side, effectively balancing out the extra
12 lbs extra weight for the Woodcomp SR3000/2 blade. The 2 blade saved me
another 10 lbs up front. B&W settles at 59.95 at 875lbs with a GRT Sport
plus conventional gauges. The 2-blade also has much less inertia when
starting, staying well below 3 bladed props, lowering kick back tendencies.
Because of the small starter and higher reported probability of kickback I
switched to the new fly wheel and new start retarding E-Modules.
Having logged 20+ test flying hours last week I noticed that the engine
cranks well. I compared the old modules with the new, the old being not
bad worth the new flywheel, but noticeable rougher. With the new modules
there is absolutely no kickback tendency and when shutting down I let her
settle on Right Magneto setting (one Module) for 10 seconds and she shuts
down without kicking. It is essential to do both mechanical and pneumatic
carb balancing. It needs to be done at different RPM. Smallest changes in
the linkages disturb a smooth operation. The Woodcomp came with custom
made Classic spinner and was already balanced at the factory. One less
thing to worry. Just bolts on.
The Ballistic battery comes with a special charging unit, quickly
recognized coming from the Radio Control market, weights very little and
also has cell balancing capacity which they say to apply once in a while
to lengthen the life of the battery. Otherwise they say it works well with
all existing charging /regulator units for cars, motorcycles, etc. It
recharges fast at 5 Amps and can even be operated in the field directly
from a car battery as it pushed the voltage up to where it is needed, up
to 10 cells (20 Volts). Max operating temps for the battery is 60 degree
celsius. I have an in cowling air temp sensor which indicates, with
classic installation, only a 10 degree celsius elevated air temperature (I
have no cold air inlet installed to save further 5 lbs weight - the
conical carbs such air right inside the cowling. After shut down it is
essential to open the 2 top cowling hatches to keep the under cowling air
temps at app. 40-45 degrees max. The battery was also wrapped in heat
shield material obtainable from race car stores.
So far it works. But you might notice I did put it in from of the
firewall, 787 permittingŠ
Christoph Both
#223 912ULS, Flying since SEPT 19, 20 hrs
Wolfville, Nova Scotia, Canada
On 13-09-30 8:45 PM, "Fred Klein" <fklein(at)orcasonline.com> wrote:
All,
Fred
PostPosted: Tue Oct 01, 2013 3:55 am    Post subject: Battery questions Reply with quote
Lots of extra weight in the footwell, though. 29lb more than with a
lithium having the same cranking capacityŠ
Christoph
crank)
Bob Harrison G-PTAG
PostPosted: Tue Oct 01, 2013 3:58 am    Post subject: Battery questions Reply with quote
Tim,
See my comments to Fred – You were actually the Europa builder inspiring me to go for the iron-lithium, having your combination of engine/starter.
So far an absolute delight. The Odyssee 680 is now in my friends BMW RT 1150.
Christoph
From: Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>
Reply-To: "europa-list(at)matronics.com (europa-list(at)matronics.com)" <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Date: Tuesday, 1 October, 2013 4:26 AM
Subject: Re: Battery questions
Fred,
See;
SHORAI INC.
See http://shoraipower.comfor full product details and much more... Please use the on-site CONTACT form to ask us for help with installation, if needed.
Tim Ward 12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
All,
wnload, 7-Day Browse, f="http://www.matronics.com/Navigator?Europa-List"> -= --> http://www.matronics.com/=================
PostPosted: Tue Oct 01, 2013 5:34 am    Post subject: Battery questions Reply with quote
This lithium iron battery may be a good battery indeed. (I just visited
the website) However, the pitfall here is that the manufacturer
specifies cranking power. In the FAQ of their website they explain that
the actual amp/hr rating is only one third. So, while a 18A/hr
lithium-iron battery may have more cranking power than an 18A/hr lead
acid battery, it has only 1/3 of the slow discharge capability. This
means that if your alternator dies, and you need 6 Amps to keep your
ship flying, you can't do this for three hours (as you would with a lead
acid battery of 18A/hr) but only for one hour.
It isn't bad, but certainly something you will want to know before the
unthinkable happens. If you want to have the same real amp/hours as with
your lead acid battery, I wonder how much the saving in weight would be.
Futhermore, I get the impression that they are not really that
enthousiastic about using standard alternators in parallel with the
battery. I see a lot of talking about recharging afterwards rather than
while driving. This may be because they market towards racers of course.
And Lithium batteries are not self balancing like lead acid batteries.
You will have to use balancing equipment to keep the battery in good shape.
Frans
Fred Klein
PostPosted: Tue Oct 01, 2013 7:10 am    Post subject: Battery questions Reply with quote
Bob, Tim, Christoph, and Frans...thank you for your thoughtful and detailed responses to my question.
I should have given more detail w/ my question...my engine is a 140 hp MPEFI engine by RAM Performance which is based on the Subaru...I have been using Fig. Z-19 from Bob Nuckolls' AeroElectric Connection, an electrical layout intended for a "Dual Battery, Single Alternator, Electronic Controlled Fuel Injection Engine", as a guide. Following it will build in the redundancy which Frans speaks of except for the single alternator...a shortcoming to be compensated for by using higher Amp/hr batteries which will be swapped out annually or bi-annually as Frans suggests.
Additional built-in redundancy derives from dual fuel pumps, back up battery for my EFIS, back up, independent GPS, and duplicate circuitry in the ECU.
In my case, for weight and balance considerations, my batteries will be aft, and at this stage of the game, it appears that lightweight batteries would not necessarily be beneficial.
..onward...
Fred
PostPosted: Tue Oct 01, 2013 8:11 am    Post subject: Battery questions Reply with quote
Is it really not possible to get an additional alternator in it? EFI
tends to use quite some electrical power, and with batteries alone the
flight won't last very long.
Don't worry about constructing weight aft. I have both batteries aft,
but also have the strobe unit behind the D-panel, the ELT-unit, the
Flarm/ADS-B/Wifi antenna's and transreceivers, I could also have put the
transponder in the tail (except for the control head), you can put a HID
landing light in the fin, etc. If you need to get more weight aft, there
are plenty of opportunities without having to resort to dead lead or
even lead acid batteries. Wink And yes I like to have the CofG near the
aft limit. Wink
Thinking about it, there is another possibility for having reserve
electrical power for single alternator setups. A non-rechargable battery
for just the EFI is also an option. Non-rechargable batteries are able
to hold much more power per weight unit than their rechargable cousins.
There exist alkaline power packs for remote electrical fences which hold
quite some amp/hours in a small package, but of course they lack
cranking power and rechargability. But they have a lot of power in the
package, just what you need if you need to keep the EFI going. It is
just a thought that this might be more weight efficient than lead acid
batteries.
Frans
gholland(at)content-strea
PostPosted: Tue Oct 01, 2013 8:55 am    Post subject: Battery questions Reply with quote
I have a small Ballistic battery in an vintage aircraft to power radio. No electrics and hand swung.It's performance is excellent. Several top things about it.
Small
  • Dimensions : 61mm (L) x 61mm (W) x 112mm (H)
  • Dimensions : 2.5" (L) x 2.5" (W) x 4.25" (H)
Lightweight.
10% loss of charge over 1 year when stored.
Mine is the 4 Cell version of the EVO 2 and has following characteristics:
  • Weight: 444 grams (.979 lbs.)
  • Voltage (Charged): 13.6V
  • Amperage: 2.3 Amp/Hour
  • Lead Acid Equivalent Amperage: 8 Pb-eq/Ah
  • Burst Cranking Amps: 135amps
  • Operating Environment: -18°C (0°°F) to 60°C (140°F)
Ordered mine via US EBay and imported to UK. The delivery costs were OK for the benefit.
Take a look: http://www.ballisticparts.com/products/batteries/batteries.php
Gerry
Gerry Holland
gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)
+44 (0)7808 402404
[img]cid:4C0DBE17-4DEB-411D-BF75-8C8AFF101B75[/img]White Ox Mead Airstrip, Bath. England
 Filesize:  7.92 KB
 Viewed:  20467 Time(s)
Fred Klein
PostPosted: Tue Oct 01, 2013 9:04 am    Post subject: Battery questions Reply with quote
Frans..as usual, you raise excellent questions along with innovative answers.
As one who has gone far afield from the standard build, I nonetheless have a "comfort zone" and endeavor to stay within it...for me to add a second alternator seems like a daunting task with potential unintended consequences. I seem to recall reading about or having a conversation w/ an A & P about differences between automotive and aircraft alternators...the salient point being that (for some reason) the automotive alternators are more reliable...but I speculate.
My EFIS (Dynon Skyview) has a back up battery module...and, for simplicity's sake, along with accepting that electronics is NOT my strong suit...I'll rely upon my mantra about "managing the degree of novelty", an arguably absurd claim given my decisions on my firewall forward set up.
Fred
kees de bussy
PostPosted: Wed Oct 02, 2013 12:11 am    Post subject: Re: Battery questions Reply with quote
Fred,
I have an Odyssey 545 mounted on the rightside footwell. The 545 is a little smaller than the 680, has somewhat less cranking power and saves about 1.3 kg over a 680. Although its smaller capacity it cranks and cranks and cranks my 912s for years, even in freezing cold wheather.
For what it is worth.
Kees de Bussy
davidjoyce(at)doctors.org
PostPosted: Wed Oct 02, 2013 1:14 am    Post subject: Battery questions Reply with quote
Fred, I would go along with the notion hat a single
Odyssey battery ( or any modern equivalent - but not a
conventional lead acid battery) is sufficient. It Has
worked well for me for 12 years. Never needs charging.
Starts first time in mid winter after being ignored for 3
months. I do not see the need for doubling up. Once had a
rectifier failure in the North Sea with perhaps 50 nm to
go to land, but it was not an issue. Got all the way back
to Gloucester without any drama! The engine carries on
(even my 914 which has its electric fuel pump driven
directly from the alternator and carries on in spite of
rectifier failure or indeed if you switch off both master
and alternator switches) and you don't absolutely need
any other form of electricity, although the battery has
ample reserves to run a radio and a GPS (if it doesn't
have it's own internal battery) for several hours. It is
possible to imagine some really complex form of failure
that could bring another battery into use, but I have
never heard of anyone having such a failure, and the
weight of an extra battery + wiring is a heavy penalty to
pay. Build light & fly further!
Regards, David Joyce, G- XSDJ
On Wed, 2 Oct 2013 01:11:19 -0700
Fred,
Kees de Bussy
http://forums.matronics.com/viewtopic.php?p=409646#409646
Un/Subscription,
Forums!
Admin.
grahamsingleton(at)btinte
PostPosted: Wed Oct 02, 2013 1:26 am    Post subject: Battery questions Reply with quote
Sounds reasonable David, the only caveat I can think of is a short on the main buss
which would flatten the battery.
This is the reason for Bob Nuckolds emergency buss which I think is a good idea
Graham
Sent: Wednesday, 2 October 2013, 10:13
Subject: Re: Re: Battery questions
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Fred, I would go along with the notion hat a single Odyssey battery ( or any modern equivalent - but not a conventional lead acid battery) is sufficient. It Has worked well for me for 12 years. Never needs charging. Starts first time in mid winter after being ignored for 3 months. I do not see the need for doubling up. Once had a rectifier failure in the North Sea with perhaps 50 nm to go to land, but it was not an issue. Got all the way back to Gloucester without any drama! The engine carries on (even my 914 which has its electric fuel pump driven directly from the alternator and carries on in spite of rectifier failure or indeed if you switch off both master and alternator switches) and you don't absolutely need any other form of electricity, although the battery has ample reserves to run a radio and a GPS (if it doesn't have it's own internal battery) for several hours. It is possible to imagine some really complex form of failure that could bring another battery into use, but I have never heard of anyone having such a failure, and the weight of an extra battery + wiring is a heavy penalty to pay. Build light & fly further!
"kees de bussy" <keesdebussy(at)hotmail.com (keesdebussy(at)hotmail.com)> wrote:
--> Europa-List message posted by: "kees de bussy" <keesdebussy(at)hotmail.com (keesdebussy(at)hotmail.com)>
Fred,
Kees de Bussy
Un/Subscription,
Frchive Search & Download, 7-Day Browse, Chat, gt; http://forums.matronics.com
; -Matt Dralcontribution" =======
h&jeuropa
PostPosted: Wed Oct 02, 2013 5:03 am    Post subject: Re: Battery questions Reply with quote
Fred,
We've used Panasonic LC-RD1217P batteries in our Europa since first flight. They are a little less expensive than the Oddessy batteries.
We once purchased a "look alike" battery which failed in a few hours!
We do load check the battery every year and find we replace it about every two years.
Jim & Heather
N241BW
Mono 914
PostPosted: Wed Oct 02, 2013 5:33 am    Post subject: Battery questions Reply with quote
Jim, I have replaced my Odyssey every 5 + years so you may
not be getting value for money! Regards, David Joyce,
G-XSDJ
On Wed, 2 Oct 2013 06:03:28 -0700
Fred,
a few hours!
Jim & Heather
N241BW
Mono 914
http://forums.matronics.com/viewtopic.php?p=409663#409663
Un/Subscription,
Forums!
Admin.
raimo.toivio(at)rwm.fi
PostPosted: Tue Oct 08, 2013 11:33 am    Post subject: Battery questions Reply with quote
I have a little Odyssey story:
once I forgot my IBBS (Integrated Battery Backup
System) on for several weeks, which gives juice to
my Gemini ADI (Tru Trak). It went empty and so
went finally my lovely Odyssey. Normally there is
like fixed 12,58 V but now hardly 4 V (four). I
had a must to fly so I elected to fire upp engine
w an external battery. I run the engine say 20
minutes and after that session it was fireable by
Odyssey only. I never noticed any failures in that
brave battery but just in case I ordered a new one
(Odyssey retail shop is just 10 km from here). Now
I have a reserve battery, which is year modell
2006, has been in use 6 years, went totally empty
and still a new like. So far I will carry those
extra kilos happily - want to hear more reports
before updating more modern batt techs.
Cheers, Raimo
OH-XRT
My wife was licensed on Monday with w top ratings.
Now I know how is it to try to sleep w a captain.
-----Alkuperäinen viesti-----
Sent: Wednesday, October 02, 2013 4:32 PM
<davidjoyce(at)doctors.org.uk>
you may
Joyce,
G-XSDJ
Fred,
Jim & Heather
N241BW Mono 914
Un/Subscription,
Forums!
Admin.
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
PostPosted: Tue Oct 08, 2013 12:00 pm    Post subject: Battery questions Reply with quote
Hi!Raimo,
I had two Odyssey 13 amp hour batteries in parallel for starting my 6 pot
Jabiru. For in the region of 9 years and they never faltered . I replaced
them about 3 years ago just because I got "cold feet " with the 914 Rotax
being all electric fuel pumps and replaced them like for like. The old ones
are still used for slave purposes around the workshop and my caravan and
still hold a charge for a long while .
Congrats to Marke on doing her solo flight .
Bob Harrison G-PTAG
Page 1 of 4
