Vedeneyev engines
richard.goode(at)russiana
PostPosted: Tue Oct 01, 2013 3:42 am    Post subject: Vedeneyev engines Reply with quote
For those interested in mechanical oddities, particularly involving the Vedenyeev engine, I did a couple of hours flying last week in Hungary in a Kamov 26, the helicopter using two M14V engines (the helicopter version of the "P") which are mounted on either side of the fuselage, driving a right- angled gearbox to a central gearbox, which then drives two main rotors, one above the other, which contra-rotate, so there is no problem with torque, so no need for a tail-rotor. They are very basic machines; incredibly noisy inside, but a tough workhorse for crop-spraying. Officially the engines run at 99%, and while spraying they tend to keep at maximum power, but a lot of operators go to 102/103% in search of extra lift. Inevitably the engines run very hot, and 3L (roughly a US quart) an hour is considered very reasonable, with some engines using up to 8L an hour! Unfortunately the world's fleet of these helicopters is now running out of rotor blades, and the cost of a set of six is significantly more than the value of a flying helicopter, so within 2/3 years all will be grounded. If you're interested in what they look like attached are pictures.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
 Filesize:  1.24 MB
 Viewed:  4372 Time(s)
 Filesize:  1.27 MB
jan.mevis(at)informavia.b
PostPosted: Tue Oct 01, 2013 4:14 am    Post subject: Vedeneyev engines Reply with quote
Thanks Richard! Very interesting!
Jan
From: Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
Reply-To: "yak-list(at)matronics.com (yak-list(at)matronics.com)" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Date: Tuesday 1 October 2013 13:38
Subject: Vedeneyev engines
1024x768 <![endif]--> Clean false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]-->/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} <![endif]--> <![endif]--> <![endif]-->
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
dsavarese0812(at)bellsout
PostPosted: Tue Oct 01, 2013 5:14 am    Post subject: Vedeneyev engines Reply with quote
Enjoyed reading your short story Richard. Thanks for sharing.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 10/1/2013 6:38 AM, Richard Goode wrote:
[quote] 1024x768 <![endif]--> Clean false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} <![endif]--> <![endif]--> <![endif]-->
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
McFly
PostPosted: Tue Oct 01, 2013 7:52 am    Post subject: Vedeneyev engines Reply with quote
Very cool!
So these are not limited to 99% for 5 min?
Todd McCutchanT-34A & Yak-50
Cell (260) 402-1740
E-mail todd(at)fastaircraft.com (todd(at)fastaircraft.com)
www.fastaircraft.com
On Oct 1, 2013, at 7:38 AM, "Richard Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
[quote] 1024x768 <![endif]--> Clean false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]-->/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} <![endif]--> <![endif]--> <![endif]-->
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
<DSCF3238.JPG>
<DSCF3239.JPG>
Todd McCutchan
Fast Aircraft
T-34A - N134FA
KDVT Hangar 33-13
Cell - 260.402.1740
Email: todd@fastaircraft.com
Skype: tmccutchan
Web: www.fastaircraft.com & www.flyams.com
PostPosted: Tue Oct 01, 2013 8:11 am    Post subject: Vedeneyev engines Reply with quote
Yes, they are limited as you say. But with a full spraying load and a hot day, they are rather underpowered, so the operators turn the governors up a little! They have a 500 hour TBO, and quite a lot have major problems before that!
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Todd McCutchan
Sent: 01 October 2013 16:50
To: yak-list(at)matronics.com
Subject: Re: Vedeneyev engines
Very cool!
Todd McCutchan
T-34A & Yak-50
Cell (260) 402-1740
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
<DSCF3238.JPG>
<DSCF3239.JPG>
believed to be clean.
