Outboard Tension Rod
jeff(at)westcottpress.com
PostPosted: Sat Sep 21, 2013 2:21 pm    Post subject: Outboard Tension Rod Reply with quote
When I make the outboard tension rods to the plan specs, I get the gap you see in the attached picture between the curved portion of the fwd left air ramp and the cooling fins. Is this correct, or should a make a new tension rod to reduce the gap?
Also, I don't feel much resistance as I tighten the MS21042-06 lock nut on the 6-32 threaded end of the tension rod. Is this peculiar to me or have others found this? Any suggestions to keep this from backing off in flight?
Jeff Carpenter
40304
 Filesize:  270.75 KB
 Viewed:  11199 Time(s)
Tim Olson
PostPosted: Sat Sep 21, 2013 2:55 pm    Post subject: Outboard Tension Rod Reply with quote
Regarding the baffle rods, definitely do something else in addition to
the plans for them instead of just washers. It took 900+ hours, but
finally the stress was too great and the washer cracked through the
metal on those bent tabs of the baffle ramps. To fix the other one,
I got some 1/8" thick angle steel (remember one side of aluminum angle
has a rounded lip?), and cut it into 2 strips instead of being angle.
So I had 1/2" approx by 1.5 or 2" length. The rounded lip fit nicely
into the bend in that baffle, and I drilled a hole thru where the
baffle hole was. That way the entire piece of aluminum 1/8" backing
is pushing on that baffle ear, evening out the stress a bit.
Mine haven't backed off in flight, but they were snug.
Jeff Carpenter
40304
jesse(at)saintaviation.co
PostPosted: Sat Sep 21, 2013 3:00 pm    Post subject: Outboard Tension Rod Reply with quote
There should be tension due to the nut being a lock but. It is possible that you have cut e threads on the rod too small.
In a perfect world, you would want it tighter against the cylinders, but I doubt you will see any measurable difference in cooling. I personally have started using .041" safety wire with a sleeve over it, which has proven to work well. I would make a mental note and see if that cylinder runs hot and then maybe make a new rod. The nut tension would be much more important to me. You could score the threads behind the nut to keep it from backing off, but make sure you have good threads.
On Sep 21, 2013, at 6:18 PM, Jeff Carpenter <jeff(at)westcottpress.com> wrote:
Jeff Carpenter
40304
<photo.jpeg>
cooprv7(at)yahoo.com
PostPosted: Sat Sep 21, 2013 3:02 pm    Post subject: Outboard Tension Rod Reply with quote
Jeff,
I would recommend you do close the gap to make the most use of the cooling fins on the cylinder. I struggled with the rods as well and on the right side never could get a good fit and also not interfere with anything. In the end I just used a long piece of safety wire and it has worked great for over 600 hours and 7 years. Probably not so clean and I'm sure I just caused great disgust in someone, but whatever method you choose the baffle should fit tight. I vaguely remember the locknut not having as much tension as well, may just be due to the small size of the rod but I can't be certain.
Looks like you are getting close, have fun.
Marcus
Jeff Carpenter
40304
<photo.jpeg>
rv10free2fly(at)yahoo.com
PostPosted: Sat Sep 21, 2013 3:11 pm    Post subject: Outboard Tension Rod Reply with quote
Do you have photos on your website of this baffle securing modification please Tim, as I'm up to this section.
Warm regards
Patrick Pulis
Adelaide, South Australia
> Jeff Carpenter
> 40304
flying-nut(at)cfl.rr.com
PostPosted: Sat Sep 21, 2013 3:23 pm    Post subject: Outboard Tension Rod Reply with quote
I'm not there yet so take this with a grain of salt: (maybe not salt
... bad for the heart) Wink
Seeing the replies using safety wire ..... I'll use the supplied rod to
go horizontally on the lip with the safety wire looped over the rod. An
anti-chafe tube over the safety wire should clean things up a bit.
Thanks for triggering a few brain cells!
Linn
> Jeff Carpenter
> 40304
Checked by AVG - www.avg.com
Tim Olson
I don't, sorry. It was something I found on a quick oil change opening
and I didn't shoot pictures...just fixed it asap.
Warm regards
Patrick Pulis
> Tim
>> Jeff Carpenter
>> 40304
Kelly McMullen
PostPosted: Sat Sep 21, 2013 3:39 pm    Post subject: Outboard Tension Rod Reply with quote
Y'all are doing it the hard way. I admit to making rods per plans, but will replace any that don't fit right with 6X32 all thread rod available at your favorite FAA/PMA dept of Lowes, Home Depot, etc.
The supplied rods are a real pain to run through a die to make the threads, especially due to small size.
The all thread has it done for you and you just cut to length, where it isn't critical because you can adjust nuts to fit.
You can then get 4 flat nuts for each rod, put one on each end inside the baffle, install rod and put one on each outside, with washers as desired. Then tighten the inner and outer nut against each other. I've done this and seen it done on certified planes with good results. You can enhance by placing sleeve of heat shrink over the rod to prevent any abrasion with rocker drainback tubes, as well as bending for clearance. If it makes you feel better you can use the self locking nuts on the outside. I do not like those tiny self locking nuts.
Kelly
On Sat, Sep 21, 2013 at 7:22 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
I'm not there yet so take this with a grain of salt:   (maybe not salt .... bad for the heart) Wink
Seeing the replies using safety wire ..... I'll use the supplied rod to go horizontally on the lip with the safety wire looped over the rod.  An anti-chafe tube over the safety wire should clean things up a bit.  Thanks for triggering a few brain cells!
Linn
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Jeff Carpenter
40304
http://forums.matronics.com
le, List Admin.
- sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Kelly McMullen
PostPosted: Sat Sep 21, 2013 3:47 pm    Post subject: Outboard Tension Rod Reply with quote
While your sleeve may protect the baffling, in general  I would advise against safety wire for this application, as I have seen it on many aircraft and it eventually cuts right through the baffling, leaving a broken hole.
Many production aircraft came with a pair of springs that hooked into the hole in the baffle, with a washer underneath to protect the aluminum, and then the other end of springs hooked together  in middle, under center cylinder(or between cylinders on 4 cyl engine). I haven't found anything easier to install, nor more durable than the all thread rod.
On Sat, Sep 21, 2013 at 6:58 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
On Sep 21, 2013, at 6:18 PM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
> Jeff Carpenter
> 40304
<photo.jpeg>
le, List Admin.
Kelly McMullen
KCHD
pilotdds(at)aol.com
PostPosted: Sat Sep 21, 2013 5:47 pm    Post subject: Outboard Tension Rod Reply with quote
For whatever its worth on my kit the rod vans suppled was to small in diameter to achieve a true 6-32 .I wound up using all thread -The bends provid tension when the nuts are tightened.
PostPosted: Sun Sep 22, 2013 11:10 am    Post subject: Outboard Tension Rod Reply with quote
Okay... here's what I've come up with... a shortened tension rod and a custom washer made from j-channel. I don't think it's possible to get the gap any better. I'm still not happy with the lock nut resistance. I've got that question in to Vans.. and not happy that the nut isn't sitting flat, but that's been determined by Vans putting the hole too close to the bend.
Jeff Carpenter
40304
<photo.jpeg>
 Filesize:  295.92 KB
 Viewed:  11163 Time(s)
PostPosted: Sun Sep 22, 2013 2:51 pm    Post subject: Outboard Tension Rod Reply with quote
PostPosted: Mon Sep 23, 2013 4:01 pm    Post subject: Outboard Tension Rod Reply with quote
.. just to report on the feedback from Joe at Vans:
He said that the curved portion of the air ramps should be pulled in as close to the fins as possible, but suggested a bead of red RTV near the flange to keep them from actually touching. If they touch, the fins will eventually wear through the baffle.
He offered that safety wire could be used instead of the rods, but that some kind of steel around the flange of the baffle would be necessary to keep the wire from cutting through the baffle at the hole.
Two nuts or loctite is what I need to use as the lock nuts don't seem to be "locking"
Jeff Carpenter
40304
<photo.jpeg>
john(at)trollingers.com
PostPosted: Wed Sep 25, 2013 2:43 am    Post subject: Outboard Tension Rod Reply with quote
What is the purpose of the tension rods, is it to pull the baffling close to the cylinders, or is it to hold the baffling in place as air moves around the engine.
I ask because I made the rods per the plans and they do not seem to pull the baffling close to the cylinders at all and I am not sure if they are to long, or if that is the expected behavior.
thanks,
40923
On Mon, Sep 23, 2013 at 8:00 PM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
[quote]--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)>
> Jeff Carpenter
> 40304
<photo.jpeg>
le, List Admin.
Kelly McMullen
PostPosted: Wed Sep 25, 2013 3:10 am    Post subject: Outboard Tension Rod Reply with quote
They are supposed to do both. You need to get most of the air to exit where the openings are, centered on each cylinder. Think what will happen with the baffles with no rods and 200 mph air flowing past them. You want an even gap, about 1/8" between cylinders and the baffle, which should not be wider at the bottom.
Makes me wonder if some of the folks reporting high CHTs have baffles pulled snug like they should be.
On Wed, Sep 25, 2013 at 6:42 AM, John Trollinger <john(at)trollingers.com (john(at)trollingers.com)> wrote:
[quote]What is the purpose of the tension rods, is it to pull the baffling close to the cylinders, or is it to hold the baffling in place as air moves around the engine.
thanks,
40923
Kelly McMullen
KCHD
rv10flyer(at)live.com
PostPosted: Wed Sep 25, 2013 6:11 am    Post subject: Outboard Tension Rod Reply with quote
Let me tell you from experience, (Eci cylinders) you want to assure there is no where for the air to go than through the cylinders. I recall the tension rods were an issue for me as well. I have RTV on both sides (inside and outside of baffles), but I also have a good fit with front and back tight enough that it will hold solid and not work itself loose.
Sent: Wednesday, September 25, 2013 3:42 AM
Subject: Re: Outboard Tension Rod
thanks,
40923
... just to report on the feedback from Joe at Vans:
Jeff Carpenter
40304
<photo.jpeg>
le, List Admin.
PostPosted: Mon Sep 30, 2013 4:11 pm    Post subject: Outboard Tension Rod Reply with quote
Okay... so here's what I finally wound up with. I feel like this will wear well. Time will tell.
Had I started with this approach I'd probably be finishing up the exhaust system by now... oh well.
Jeff Carpenter
40304
Jeff Carpenter
40304
<photo.jpeg>
 Filesize:  72.68 KB
 Viewed:  11039 Time(s)
 Filesize:  70.57 KB
 Filesize:  77.67 KB
larkrv10(at)gmail.com
PostPosted: Mon Sep 30, 2013 6:24 pm    Post subject: Outboard Tension Rod Reply with quote
Nice Jeff, is that aluminum rod or stainless?
Rick
#40956
Southampton, Ont
On Mon, Sep 30, 2013 at 8:03 PM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
[quote]Okay... so here's what I finally wound up with. I feel like this will wear well. Time will tell.
Jeff Carpenter
40304
> Jeff Carpenter
> 40304
> <photo.jpeg>
PostPosted: Mon Sep 30, 2013 7:18 pm    Post subject: Outboard Tension Rod Reply with quote
That's the stainless rod that was furnished to make the tension rods with. You can see in one of the pictures that I ground a "dog bone" style groove in the center of the rods for the wire to nest in. That should keep the rods from working their way out.
On Sep 30, 2013, at 7:24 PM, Rick Lark wrote:
[quote]Nice Jeff, is that aluminum rod or stainless?
Rick
#40956
Southampton, Ont
Jeff Carpenter
40304
> Jeff Carpenter
> 40304
> <photo.jpeg>
