Harv
Posted: Thu Sep 19, 2013 4:23 am Post subject: CJ6 Start Boost Coil Adjustment/Testing |
Chaps
After having some issues with my CJ boost/ignition coil (shower of sparks) or whatever you'd like to call it I spent some time searching on this forum and in the parts manuals (Thanks Doug).
There's a test/set-up procedure for it in the maintenance manual which I've reproduced here....
Rgs
Harv
132.65 KB |
3569 Time(s) |
Posted: Thu Sep 19, 2013 10:13 am Post subject: CJ6 Start Boost Coil Adjustment/Testing |
Interesting! Great info Harv.
FYI, to M-14 engine guys... the vibrator spark coil on the CJ is identical to the YAK's. This procedure thus is applicable.
A tester would need to build the test jig with the precision spark gap, but that is no big deal really. You could make it out of something that has a point at the end, good screws for instance... and then just have two of them opposing each other with the precision gap. Adjust as necessary as they wear.
Advice from the peanut gallery: Be extremely careful "sanding down" the points. There is actually a special file specifically made for relay point polishing, and it is quite smooth, not rough at all. I'd stay away from a file and just go with the "000" emery if you really feel it necessary. Just sayin.... A bad mistake messing with the points would ruin the device.
Mark
GeorgeCoy
Posted: Thu Sep 19, 2013 10:28 am Post subject: CJ6 Start Boost Coil Adjustment/Testing |
We make a solid state replacement as well.
George Coy
Posted: Thu Sep 19, 2013 10:56 am Post subject: CJ6 Start Boost Coil Adjustment/Testing |
Probably a smart purchase.
jan.mevis(at)informavia.b Guest
Posted: Thu Sep 19, 2013 8:34 pm Post subject: CJ6 Start Boost Coil Adjustment/Testing |
It certainly is, I have one.
Jan
On 19/09/13 20:44, "Bitterlich, Mark G CIV NAVAIR, WD"
