bob88
Posted: Sun Sep 08, 2013 8:15 pm Post subject: ACK E04 ELT MOUNTING |
I noted that Tim Olson has mounted the ELT basically under the vertical stabilizer and between the elevator trim control cables. For the ACK unit, it seems that it will be a very tight fit. Anyone done it? Photo? Also, how does the antenna live under the fairing with the 20 degree angle?
johngoodman
Posted: Mon Sep 09, 2013 5:17 am Post subject: Re: ACK E04 ELT MOUNTING |
Make it easy to get to, behind the baggage bulkhead. Put the antenna on the top - nobody notices antennas anyway. Keep in mind that it uses an "almost" ordinary telephone cord between it and your panel. You need that cord in place when pulling wires.
Kellym
Posted: Mon Sep 09, 2013 6:08 am Post subject: ACK E04 ELT MOUNTING |
While I agree with mounting the ELT in the area behind the baggage
compartment, I don't agree with mounting the antenna just anywhere on top.
Antennas and spacing do matter. You need at least 2 ft from any com or
GPS antenna, and 3 ft is better. The closer the ELT antenna is to the
vertical stabilizer the better it will be protected from crash damage.
The neat, out of sight mounting between the vert and horiz stabilizers
under the fiberglass fairing is probably the best crash protected
location. While the manufacturer's instructions call for mounting
within 20 or 30 degrees of vertical, it is somewhat difficult to define
where vertical will be post-crash. I mounted mine on the rear most
bulkhead before the vertical stab, and will use a nylon wire clamp to
keep the other end of the antenna clear of any metal.
There is one other issue with ELT antennas that is rarely discussed. The
121.5 transmitters are easily excited by TV and FM signals which are
close in frequency, and they re-radiate that energy. If there is a com
antenna anywhere near the ELT antenna it can cause a nasty squelch break
that interferes. I had this problem with my Mooney when all the com
antennas were on top of fuselage. I was able to greatly reduce it by
moving one com antenna to the belly. Yes, newer ELTs are supposed to
have better suppression of this "feature" but I doubt they have
eliminated it. Likewise any VHF transmission anywhere near your GPS
antenna creates potential for interference with GPS. So mounting your
ELT as far away from other antennas as possible is beneficial.
On 9/9/2013 6:17 AM, johngoodman wrote:
#40572 Phase One complete and flying.
http://forums.matronics.com/viewtopic.php?p=408262#408262
KCHD |
rv10pro(at)gmail.com Guest
Posted: Mon Sep 09, 2013 7:17 am Post subject: ACK E04 ELT MOUNTING |
As a guy who tests ELTs and gets paid to do it, Kelly's advise is invaluable. Cosmetically hiding ELT antenna produced too many units which won't propagate an adequate signal. It looks like you have a unit but the signal strength is inadequate.
John On Sep 9, 2013 7:17 AM, "Kelly McMullen" <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:[quote] --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
While I agree with mounting the ELT in the area behind the baggage compartment, I don't agree with mounting the antenna just anywhere on top.
Antennas and spacing do matter. You need at least 2 ft from any com or GPS antenna, and 3 ft is better. The closer the ELT antenna is to the vertical stabilizer the better it will be protected from crash damage. The neat, out of sight mounting between the vert and horiz stabilizers under the fiberglass fairing is probably the best crash protected location. While the manufacturer's instructions call for mounting within 20 or 30 degrees of vertical, it is somewhat difficult to define where vertical will be post-crash. I mounted mine on the rear most bulkhead before the vertical stab, and will use a nylon wire clamp to keep the other end of the antenna clear of any metal.
There is one other issue with ELT antennas that is rarely discussed. The 121.5 transmitters are easily excited by TV and FM signals which are close in frequency, and they re-radiate that energy. If there is a com antenna anywhere near the ELT antenna it can cause a nasty squelch break that interferes. I had this problem with my Mooney when all the com antennas were on top of fuselage. I was able to greatly reduce it by moving one com antenna to the belly. Yes, newer ELTs are supposed to have better suppression of this "feature" but I doubt they have eliminated it. Likewise any VHF transmission anywhere near your GPS antenna creates potential for interference with GPS. So mounting your ELT as far away from other antennas as possible is beneficial.
| Quote: | --> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
le, List Admin.
michael(at)sausen.net Guest
Posted: Mon Sep 09, 2013 7:23 am Post subject: ACK E04 ELT MOUNTING |
Couldn't get mine to fit there anymore when I switched, ended up making a spot for it next to the batteries like others.
Michael
aerosport1
Posted: Mon Sep 09, 2013 8:42 am Post subject: ACK E04 ELT MOUNTING |
I built little aluminum standoffs and works great
Geoff Combs
310.7 KB |
10811 Time(s) |
232.57 KB |
10811 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Mon Sep 09, 2013 10:50 am Post subject: ACK E04 ELT MOUNTING |
Geoff,
That's the old 121.5. The new 406 E-04 is much longer and won't fit.
Michael
Tim Olson
Posted: Mon Sep 09, 2013 11:01 am Post subject: ACK E04 ELT MOUNTING |
Not true.... I added legs to my bracket on the new E-04 and that makes
it fit fine. I think that's what Geoff was referring to also.
The old one was shaped differently. The new one I needed to raise
up a little, and then it fit fine.
Here's my write-up from 2011 when I did it.
http://www.myrv10.com/N104CD/upgrades/20110506/index.html
On 9/9/2013 1:50 PM, Michael Sausen wrote:
Geoff,
Michael
Posted: Mon Sep 09, 2013 11:03 am Post subject: ACK E04 ELT MOUNTING |
Interesting, just noticed the one in Geoff's picture is the old one.
Michael
Bob Turner
Posted: Mon Sep 09, 2013 11:20 am Post subject: Re: ACK E04 ELT MOUNTING |
Guys,
This confusion has happened before.
Model E-04 is made by ACK technologies.
Unfortunately Ameri-King (shown in the photo) uses "AK-xxx" for their model numbers and is often confused with ACK.
_________________ Bob Turner
RV-10 QB |
aerosport1
Posted: Mon Sep 09, 2013 11:53 am Post subject: ACK E04 ELT MOUNTING |
That is correct. These pictures were over 4 yrs ago. Below is the new 406
Ameriking that is a drop in
Replacement Pretty much. See Pictures
Geoff
Geoff Combs
Aerosport Modeling and Design
8090 howe industrial pkwy
canal winchester, ohio 43110
614.834.5227p
614.834.5230f
www.aerosportmodeling.com
238.1 KB |
10795 Time(s) |
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Mon Sep 09, 2013 11:57 am Post subject: ACK E04 ELT MOUNTING |
Not an ACK but here's my ELT mounting solution ......
[img]cid:part1.00020103.02090009(at)cfl.rr.com[/img]
It's an ACR/Artex ME406, but you can make the 'shelf' to fit just about anything. That's 3/4" alum channel with a piece of scrap alum riveted between and mounts the ELT. Those holes allow screw to go into nutplates to hold everything down.
I was waiting to talk to folks in a booth at Airventure last year and was standing next to the Artex booth. Filled out the entry for the ELT giveaway while I waited. Won the raffle! I hope to never use it though!
Linn
On 9/9/2013 3:20 PM, Bob Turner wrote:
| Quote: | | Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu> (bobturner(at)alum.rpi.edu)
Guys,
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=408296#408296
Checked by AVG - www.avg.com
105.41 KB |
10795 Time(s) |
