Lightspeed Plasma III current curves
PostPosted: Thu Sep 05, 2013 7:38 am    Post subject: Lightspeed Plasma III current curves Reply with quote
It took awhile to find the plot . . . but here's a set
of curves for current draw taken in the laboratory on
a number of Plasma III ignition systems.
[img]cid:7.1.0.9.0.20130905103652.020fab50(at)aeroelectric.com.0[/img]
 Filesize:  76.54 KB
 Viewed:  6711 Time(s)
hotwheels
PostPosted: Fri Sep 06, 2013 7:42 am    Post subject: Re: Lightspeed Plasma III current curves Reply with quote
I have dual LSE Plasma IIIs. Here are the current draw numbers Klaus shared recently for Box version "B". Your mileage may vary depending upon box vintage...
Box on, engine off: ~0.2A
Engine at idle power: ~0.8-0.9A
Engine at cruise power: ~2A
Jay
N433RV RV-10 ... Flying!
jonlaury
PostPosted: Fri Sep 06, 2013 8:34 am    Post subject: Re: Lightspeed Plasma III current curves Reply with quote
As Jay uses the singular "Box Version B". I assume the current draw would be double for dual LSE III's . Correct?
peter(at)sportingaero.com
PostPosted: Fri Sep 06, 2013 9:20 am    Post subject: Lightspeed Plasma III current curves Reply with quote
nuckollsr
PostPosted: Fri Sep 06, 2013 7:47 pm    Post subject: Re: Lightspeed Plasma III current curves Reply with quote
2.0A at 'cruise' is consistent with the data taken assuming that you cruise at 2200 rpm and the electronics package is in a 75F ambient. It also assumes a 13.8v bus. Since these ignition systems are fitted with wide range switchmode power supplies, they will consume constant power for varying input voltages. So if you're operating in a battery-only endurance mode, the current draw at end of battery life (10.5v) would be on the order of 2.6A at 2200 rpm.
PostPosted: Mon Sep 09, 2013 5:20 am    Post subject: Lightspeed Plasma III current curves Reply with quote
Yes . . . that is PER system . . .
