toaster73(at)embarqmail.c Guest
Posted: Sun Sep 01, 2013 1:06 pm Post subject: Nose gear leg fairing |
I have noticed some apparent heat damage around my nose gear strut fairing right around the area where it exits the cowling to the first screw that attaches it to the gear leg. Seems like the fiberglass has gotten a little warm and changed shape with some of the weave showing through the paint. Have others seen this or know what can be done to prevent it??
Chris Lucas
N919AR
bill.peyton
Posted: Sun Sep 01, 2013 5:08 pm Post subject: Re: Nose gear leg fairing |
Posting some photos would be helpful to assist in answering your question. Are you sure that it is heat, or could it be that the fairing is in a bind when it is installed and it's trying to twist? I haven't noticed anything on mine indicating heat was an issue. Do you have any reflective heat mat on the lower cowling?
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Posted: Sun Sep 01, 2013 7:00 pm Post subject: Nose gear leg fairing |
Yep I have reflective mat on the cowl bottom - I should have attached a
picture, I'll try to get a photo tomorrow.
-Chris
Posted: Mon Sep 02, 2013 3:12 pm Post subject: Nose gear leg fairing |
Here are the pictures. I am wondering if hot air is coming in from the top
and kind of dead heading at the screw attach triangles on the leg - or the
whole leg has a lot of heat too.
-Chris
N919AR
322.43 KB |
15749 Time(s) |
306.73 KB |
15749 Time(s) |
365.89 KB |
15749 Time(s) |
303.86 KB |
15749 Time(s) |
376.85 KB |
15749 Time(s) |
bill.peyton
Posted: Mon Sep 02, 2013 3:47 pm Post subject: Re: Nose gear leg fairing |
It almost looks like the nose gear leg brackets are distorting the fairing. Almost like the front of the fairing is resting on the gear leg to deeply. My 4
Attachment screws are much closer to the hinge edge of The fairing than yours. I don't have any photos, but I will take a look this week and see if that's the case.
WA0SYV
Lew Gallagher
Posted: Mon Sep 02, 2013 3:58 pm Post subject: Nose gear leg fairing |
Hey Chris,
It sure looks like heat concentrating at the screw -- checked for exhaust
leaks, heat muffler leaks? Have you also checked for fuel overflow (hot
start flooding, etc.)? There would probably be fuel discoloring if that
were the case.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Mon Sep 02, 2013 5:13 pm Post subject: Nose gear leg fairing |
While there is typically a negative pressure gradient that sets up cowl
exhaust air to go down the nose gear fairing to the nose wheel pant, I
suspect this is not heat damage as much as the fastener working the fairing.
Looking at the photo, you have the same situation I had on my plane - the
fairing needs to have a backing on it so that you don't deform it when you
tighten the mounting screw.
As a general rule, anyplace you have thin fiberglass held to something like
a small steel plate with a fastener you must add reinforcement. On the nose
gear leg fairings I added 4-6 bids of glass reinforcement on the inside
where the fairing rubs on the gear leg bracket. This adds a lot of strength
to the area where the screw goes through as well as the needed spacer so the
mounting screw does not deform the fairing. The same practice goes for the
wheel pants, some areas like the outboard bolt hole get much thicker layers
of glass than others. On the front gear pant don't forget to add some glass
reinforcement on the inside about 6" up from the tire cutout. I had the
wheel pant split in this area, as have others. On the front shoulder belt
to cabin top mounting screws I added ( bids of glass on inside, 6"x10" or
so in size centered on the screw hole. I did not consider the thickness of
the cabin top glass adequate after I got done countersinking for the
mounting screw.
Carl
RV-10 (125 hrs)
RV-8A (sold)
rv10flyer
Posted: Mon Sep 02, 2013 8:54 pm Post subject: Re: Nose gear leg fairing |
I had to build up on the inside of mine 1/8" at all four locations. Weekend job for you coming up.
_________________ Wayne G. |
Posted: Tue Sep 03, 2013 12:49 pm Post subject: Nose gear leg fairing |
Thanks to all on the replies. I guess my case is a bit isolated. I do
remember adding glass to the lower attach points but I don't remember if I
did to the uppers - it is drawn in a bit by the screw but the gopro camera
lens might exaggerate it a little. Easy enough to go ahead and pull it off
and add some glass as you say below, and check for any exhaust leaks. I did
not see any fuel residue around it.
Chris
N919AR
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Wed Sep 04, 2013 3:52 am Post subject: Re: Nose gear leg fairing |
I have a question about the louvers you are using, are those stock? It seems like they are cut in the cowl more forward than most. Could it be that your installation has more hot air being pulled out the forward portion of the cowl rather than the aft opening? If that is the case then your fairing would see more heat than others. Just a thought - Jason
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
rv10flyer
Posted: Wed Sep 04, 2013 3:55 am Post subject: Re: Nose gear leg fairing |
They appear stock and in stock location to me.
Posted: Wed Sep 04, 2013 4:46 pm Post subject: Nose gear leg fairing |
My FWF is all stock unless I made a plans mistake.
-Chris
jkreidler
Posted: Thu Sep 05, 2013 3:52 am Post subject: Re: Nose gear leg fairing |
May I ask what kind of paint you used? - Jason
Posted: Thu Sep 05, 2013 6:36 am Post subject: Nose gear leg fairing |
Jason
May I suggest that, when you ask a question regarding a previous email, you
do include the text of that previous email.
Best
Carlos
-----Mensagem original-----
De: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Em nome de jkreidler
Enviada: 5 de setembro de 2013 12:53
Para: rv10-list(at)matronics.com
Assunto: Re: Nose gear leg fairing
--> <jason.kreidler(at)regalbeloit.com>
Jason Kreidler
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617
http://forums.matronics.com/viewtopic.php?p=408051#408051
Posted: Thu Sep 05, 2013 5:43 pm Post subject: Nose gear leg fairing |
Its PPG Deltron base with clear. K36 primer and alodined.
-Chris
