Fuel filters
pete(at)lawless.info
PostPosted: Sun Sep 01, 2013 2:08 am    Post subject: Fuel filters Reply with quote
Hi John
I have the original glass filters and am very happy with them. In the first
few hours of a new Europa they do get blocked and mine needed cleaning every
5 hours or so for the first 25 hours and on one occasion at about 10 hours
caused fuel starvation on the climb out. Then less frequently cleaning
until the tank settled down at about 100 hours. At 550 hours the filter now
need a clean about every 50 hours.
My filters are installed under the seats protected by a Perspex cover, as
per the original Classic layout. I inspect them BEFORE EVERY FLIGHT. The
beauty of the glass container is that you can see what is going on, all that
is needed is to pull up the seat cushion and look. Cleaning is very easy
you just change the filter screen for a new one and wipe the inside of the
glass.
I would be very reluctant to install a filter unit I could not inspect
without taking it to bits.
Pete
Classic #109 Rotax 912UL
carl(at)flyers.freeserve.
PostPosted: Sun Sep 01, 2013 3:21 am    Post subject: Fuel filters Reply with quote
Hi All,
I am surprised that anyone ever gets blocked filters after the initial
shakedown. I know it is difficult to clean out tanks after build but it's
definitely worth pumping a few gallons of fuel through the system before
assuming everything is clean.
If you have dirty fuel in your tanks this is an issue that should be
addressed first rather instead of relying on the fuel filters to do their
job. I accept that some of us have less control over what we put in our
tanks than others (ie: if you are purchasing fuel at the airfield pumps).
In the early days I recall that clogged filters were an issue for some
builders. The filters were becoming overwhelmed by large amounts of crud
which should never have been there in the first place - I do not believe
that changing the size of the filter mesh would address this particular
issue.
Personally I never liked the factory system and opted for a gascolator setup
instead - nothing fancy like an Andair, just the cheap kit builders one
available from LAS or Aircraft Spruce (I priced one at the LAA yesterday and
they are selling for £60) . The beauty of the setup is that any large lumps
of crud (or water) tend to settle in the bottom of the gascolator bowl and
will be drained off when you do your do your daily fuel checks - very little
muck reaches the filter mesh at the top of the bowl (this is a 120 micron
screen).
We are fortunate in that all our fuel is from cans which we insist on
filtering through a fine mesh funnel and we have never found any signs of a
clogged filter. It is worth noting that metal fuel cans generate their own
debris as the internal paint on the cans tends to flake off and if not
filtered would cause problems if not pre filtered.
For those who have to rely on airfield based supplies if it should be
possible to carry a filter sock (wire or nylon mesh) which could be dropped
down the fuel filler opening to ensure the cleanliness of any external
sources of fuel. This could even be a permanent installation.
Additionally as a backup, a fuel pressure gauge which would give a visual
warning of low pressure due to a filter blockage.
Carl Pattinson
G-LABS
raimo.toivio(at)rwm.fi
PostPosted: Sun Sep 01, 2013 10:03 am    Post subject: Fuel filters Reply with quote
Carl and the rest of you who are interested in
this topic,
I did it also. I cleaned my tank very careful
several times (I had heard warnings!). I pumped
through the system at least 300 liters of fuel
before first flight.
Despite that - total hours 5 - I once pushed full
power during cruise and my Rotax went silent
immediately. Fuel pressure went down. Over
mountaineous forest. My co-pilot was Jyrki
Laukkanen, a famous test pilot (google!). We
looked each others and I elected to switch
electric pump on AND changed to reserve tank (and
to another fuel filter also - how genious is that
fuel system - there is always a clean filter
waiting!). That was an autonomious reflex only.
Rotax fired up immediately.
Jyrki said later please never apply full power
with a new construction or after a major service
if you are not above airfield! That makes sense.
He also said he is alive because after every
service or repair he had had a habit to fly at
least 15 minutes over the field before heading to
somewhere. He had completed 9 forced landings and
all over the runways, all succesful and all
because of service failure or service mistake.
That has happened during his career say 50 years.
My fuel filter was checked in lab. It was totally
blocked by small particles looking gold but they
were identified to be shit from lay-upp processes.
My guess was they (those particles) were "glued"
to the tank inside surfaces by static forces.
That after I checked my fuel filter after EVERY
flight. Flight by flight it seemed to be cleaner
and cleaner.
Today I check my filters say after every 10
hours - always clean.
When refueling I have only two alternatives:
1) Refuel 100LL direct to my ac in the airfield.
Systems are aircraft quality, classified and
certified, filtered and water-isolated.
2) Refuel autofuel 98E 0-5% alcohol from petrol
stations w as good brand as possible direct to MY
canisters through Mr. Mc Funnel´s debris /water
isolator.
Since that scary action 2007, I have had never any
more fuel problems.
I never clean my filters. I change them for new
ones once a year (after 50-100 hrs service).
I do not use those original puzzle filters w
several parts and glass tube.
One was broken during towing action and one was
broken by itself in the hangar.
I use original Rotax filters - they are throwaway
models - transparent - one piece - plastic non
glass - you are not able to assemble them wrong
way - cheap - unbreakable.
Sold? How many you want?
Raimo Toivio
FINLAND
OH-XRT
-----Alkuperäinen viesti-----
Sent: Sunday, September 01, 2013 2:21 PM
Subject: RE: Fuel filters
Pattinson" <carl(at)flyers.freeserve.co.uk>
Hi All,
issue.
screen).
which we insist on
installation.
Carl Pattinson
G-LABS
ptag.dev(at)tiscali.co.uk
PostPosted: Sun Sep 01, 2013 12:29 pm    Post subject: Fuel filters Reply with quote
Hi! Raimo/all
You make an interesting statement with regards to switching to the reserve
tank and got a clean filter to start up with , however I think you should
remember that on a much used aircraft the filling system always delivers
"the new shit " into the reserve side of the saddle tank and with the best
will in the world it is likely to always store water contamination in a
greater proportion than that on the main delivery side, so don't expect that
the reserve switch will always be your salvation! The water drain valves
need to be often tested on both sides . I did away with the standard glass
Europa issue filters and use TWO mini Andair gascolator filters one for each
saddle tank side.
After an overnight stay in pouring rain I took about half a litre of water
from the reserve drain valve which I believe went into the tank through the
locking fuel cap so I try to tape up the entire filler cap when in rain .
This incident was at Zelam See (?and I don't think it was from their refuel
facility but who knows?
Best regards
Bob Harrison G-PTAG kit 337 Now Rotax 914 total airframe hours in excess of
1000.
grahamsingleton(at)btinte
PostPosted: Sun Sep 01, 2013 1:48 pm    Post subject: Fuel filters Reply with quote
good to see you at the show.
I have seen water leak into the tank from overnight rain.
through the plastic fuel tank cap that many Europas have. Difficult to adjust when
they get corroded and the hut rusts up. Also the size of the O ring is imprtant.
Graham
Sent: Sunday, 1 September 2013, 21:29
--> Europa-List message posted by: "Bob Harrison" <ptag.dev(at)tiscali.co.uk (ptag.dev(at)tiscali.co.uk)>
Hi! Raimo/all
saddle tank side.
Best regards
1000.
kjburns(at)btinternet.com
PostPosted: Sun Sep 01, 2013 2:56 pm    Post subject: Fuel filters Reply with quote
You are correct a saddle tank type reserve will build up water in the bottom if you take no preventative actions, as you suggest water drain valves,(with the aircraft levelled to remove more water, but I would suggest that the only way to know if the engine will run on that tank (filter / pipe/ valve position /pump combination) is to 1 ground run it (if new build or restoration fuel flow tests on both sides of tank) then 2 at safe height over a suitable airfield change to reserve and run on reserve as a regular check /flushing run on that side of the tank.
If you find it difficult to change tanks with the standard fuel valve position, then consider the benefits of removing the valve and putting it where you can do it easily.
Also I would consider a Gascilator valuable even if its primary purpose is as a water trap as you can not be sure to drain all the water all the time.
Also we take pump samples at our airfield, on a daily basis which are left to settle out water and contaminants (in glass Jam Jars) so fuel quality is controlled (Look for globules in bottom of jar.
Rather loose some interior trim or other non essentials...
I hope these considerations will help, they are not original thinking , or rocket science, I have also discussed with more than a few guys at the LAA show the need for trained /automatic response to power loss (push instantly forward on stick to an attitude that speed is maintained, and also plan for that eventuality during cockpit checks, plan to land ahead until you have the height to turn (Know what height you need to complete a turn), the glider pilots amongst you will recognise the BGA training and pilot review methods ...used to reduce stall spin accidents on winch launching -found only poor examples on u tube but helps to see results ...the second failure is a bit low for comfort to do a 360..
http://www.youtube.com/watch?v=iFT1K1rQvHA
http://www.youtube.com/watch?v=MqKrQ5uAbRg
Kevin
Hi! Raimo/all
saddle tank side.
Best regards
1000.
asarangan(at)gmail.com
PostPosted: Sun Sep 01, 2013 5:33 pm    Post subject: Fuel filters Reply with quote
Raimo
When you say "I pumped through the system at least 300 liters of fuel
before first flight", was that done through the fuel filter? If yes, I
am curious why those particles were released during flight and not
during the flush. Could ie be vibration, or some other antistatic
effect during flight. May be an ionizing airgun can be used to release
stuck particles?
On Sun, Sep 1, 2013 at 2:02 PM, Raimo Toivio <raimo.toivio(at)rwm.fi> wrote:
Carl and the rest of you who are interested in this topic,
I did it also. I cleaned my tank very careful several times (I had heard
warnings!). I pumped through the system at least 300 liters of fuel before
first flight.
Despite that - total hours 5 - I once pushed full power during cruise and my
Rotax went silent immediately. Fuel pressure went down. Over mountaineous
forest. My co-pilot was Jyrki Laukkanen, a famous test pilot (google!). We
looked each others and I elected to switch electric pump on AND changed to
reserve tank (and to another fuel filter also - how genious is that fuel
system - there is always a clean filter waiting!). That was an autonomious
reflex only. Rotax fired up immediately.
Jyrki said later please never apply full power with a new construction or
after a major service if you are not above airfield! That makes sense. He
also said he is alive because after every service or repair he had had a
habit to fly at least 15 minutes over the field before heading to somewhere.
He had completed 9 forced landings and all over the runways, all succesful
and all because of service failure or service mistake. That has happened
My fuel filter was checked in lab. It was totally blocked by small particles
looking gold but they were identified to be shit from lay-upp processes. My
guess was they (those particles) were "glued" to the tank inside surfaces by
static forces.
That after I checked my fuel filter after EVERY flight. Flight by flight it
seemed to be cleaner and cleaner.
Today I check my filters say after every 10 hours - always clean.
1) Refuel 100LL direct to my ac in the airfield. Systems are aircraft
quality, classified and certified, filtered and water-isolated.
2) Refuel autofuel 98E 0-5% alcohol from petrol stations w as good brand as
possible direct to MY canisters through Mr. Mc Funnel´s debris /water
isolator.
Since that scary action 2007, I have had never any more fuel problems.
I never clean my filters. I change them for new ones once a year (after
I do not use those original puzzle filters w several parts and glass tube.
One was broken during towing action and one was broken by itself in the
hangar.
I use original Rotax filters - they are throwaway models - transparent - one
piece - plastic non glass - you are not able to assemble them wrong way -
Raimo Toivio
FINLAND
OH-XRT
-----Alkuperäinen viesti----- From: Carl Pattinson
Hi All,
issue.
screen).
Carl Pattinson
G-LABS
PostPosted: Sun Sep 01, 2013 11:08 pm    Post subject: Fuel filters Reply with quote
Hi all,
Maybe I am being smug or just plain naive but we have never had a blockage/ stoppage with our fuel system. I believe this is almost entirely due to us opting for a gascolator as opposed to the standard filter system.
As per my previous post it is a cheapo homebuild gascolator unit with a very fine mesh filter (unfortunately 140 micron is the only size available).
We do get the odd bit of muck (ie: small particles) but these settle in the bottom of the gascolator bowl and get drained out on the preflight inspection. One one occasion there was about a tablespoon of water after the ac had been left standing in the rain without covering the filler cap.
The gascolator is dismantled and filter gauze changed every 6 months though little debris is found at these inspections. Fuel tank is fully drained and flushed once a year with tail raised as high as possible.
It worries me when I hear tales of blocked filters as we have never experienced this. Im tempted to re design our system and introduce a dual system but then with over 10 years of trouble free flying its probably best to leave well alone.
One recommendation I would strongly make is to ensure that all fuel going into the tank is filtered. I believe it will eliminate 90% of the problem.
Carl Pattinson - G-LABS.
Sent from my ASUS Pad
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
Graham
Subject: RE: Europa-List: Fuel filters
Hi! Raimo/all
saddle tank side.
Best regards
1000.
PostPosted: Mon Sep 02, 2013 12:11 am    Post subject: Fuel filters Reply with quote
Dear Bob /all,
please try to understand that was MY only option!
Otherwise - forced landing to the hard rocky
forest including hungry wolves and beers.
It is better you believe it was good to have two
parallel filters - that is like to have two radios
or two generators...that 2nd filter really made
our day.
Also, I was proud about myself, that my reaction
was one and only correct way to proceed in that
situation!
It was not very risky to get new shit to the 2nd
filter because
- loose shit was obvious already in the 1st filter
and
- I fired up the engine with moderate power only.
More:
- In my pre-flight list there is a task "change
for res/2nd filter for 3 minutes to test it"
and
- Water-drain both sides (never seen water).
and
- when out and raining I always cover a fuel cap
because I do not trust it.
Better to believe there are safe points but also
not-so-safe-points in our Europa as well as any
planes.
Dual fuel systems is great and one of the in-build
safe systems.
Notice:
- Adding one-way-valve to the fuel return line
(idea by Frans Veldman) is a great must (and
mandatory at least for me).
Are you coming to EHTX next weekend?
Cheers, Raimo
Sent: Sunday, September 01, 2013 11:29 PM
<ptag.dev(at)tiscali.co.uk>
Hi! Raimo/all
saddle tank side.
Best regards
1000.
frans(at)privatepilots.nl
PostPosted: Mon Sep 02, 2013 12:29 am    Post subject: Fuel filters Reply with quote
I'm not to fond about the hungry wolves but that beer is included is a big plus!
[quote]--
PostPosted: Mon Sep 02, 2013 12:38 am    Post subject: Fuel filters Reply with quote
Anrew,
you made a good question:
Yes - that was made through BOTH filters (150
liters /filter) and they remain totally clean.
Main reason they were clean was obviously that I
run fuel only by electric fuel pump ie. engine was
not running.
My purpose was to calibrate fuel gauge (electric
and visual), check the system and to clean it.
As we know, I did not succeeded. But I did during
that flight! After that - filters have been
*almost* clean after every change period one year
(=50-100 hrs).
Notice:
I had flown before that case 5 hours. I had used
more or less full power at least ten times x 5
minutes during every take-off. That main filter
was still clean from flight to flight until that
almost destiny flight. That´s a bit scary, isn´t
it?
Why:
As you wrote, vibration, static effects and also
time, fuel itself, temperature changes etc affects
to the tank shit and its releasing time. Maybe
also full moon periods can do that. I am sure
Frans can imagine a lot more reasons for that.
How to avoid:
- clean more carefully.
- use your time.
- use different methods (ionizing could be that).
- check the tank by using boroscope with light.
- before first flight complete a lot full power
engine tests.
- when flying a test period say first 5 hours do
that only over your landing area.
- when using full power during your test phase say
first 10 hours do that only over your landing
area.
BTW - checked that lab report - that gold coloured
"material" which suddenly blocked my filter during
that flight - shit in the filter - was epoxbased.
Maybe it was somehow glued to the tank inside and
finally separated.
Cheers, Raimo
OH-XRT
Sent: Monday, September 02, 2013 4:32 AM
To: Europa List
Subject: Re: Fuel filters
<asarangan(at)gmail.com>
Raimo
300 liters of fuel
other antistatic
stuck particles?
Toivio" <raimo.toivio(at)rwm.fi>
this topic,
first flight.
static forces.
water-isolated.
isolator.
hangar.
Raimo Toivio
FINLAND
OH-XRT
Pattinson
Pattinson"
Hi All,
issue.
screen).
filtered.
installation.
blockage.
Carl Pattinson
G-LABS
PostPosted: Mon Sep 02, 2013 12:41 am    Post subject: Fuel filters Reply with quote
OK Frans, that beer* is still waiting for you
here - I will handle those bears then (maybe eat)!
* Aviators Beer
Sent: Monday, September 02, 2013 11:28 AM
<frans(at)privatepilots.nl>
[quote]--
PostPosted: Mon Sep 02, 2013 12:49 am    Post subject: Fuel filters Reply with quote
Carl, if I were you, I would do same. Your method is proofed after 10 years. Re-designing is always a new risk.
Refueling quality is essential anyway as you wrote.
You take care of your plane a lot better than me: I have not cleaned my tank after it´s completion 2007. I have only trusted my refueling manners and filters (which are always *almost* clean).
One more thing:
- use only your very own and known canisters.
- in the new canister there could be what so ever like mices or gigarrettes (from China).
- trust only yourself when refueling.
Cheers, Raimo
OH-XRT
Sent: Monday, September 02, 2013 9:56 AM
Hi all,
Graham
Hi! Raimo/all
saddle tank side.
PostPosted: Mon Sep 02, 2013 1:28 am    Post subject: Fuel filters Reply with quote
Hi! Raimo/all
I hope to be at Texel, except I have bad mag drop readout which I have to
"bottom out" and a new Arificial Gyro Horizon since LAA Rally to fit plus I
may have "date" with a Heathrow "arrival" which will take priority !
But hope so since it is the last for my season.
Bob Harrison G-PTAG
rparigoris
PostPosted: Thu Sep 05, 2013 6:22 pm    Post subject: Fuel filters Reply with quote
Hi Raimo
You mentioned:
Notice:
Can you elaborate a little on why you might want to put a one-way-valve on the fuel return line? Is this for a 914 fuel system?
Thx.
Ron Parigoris [quote][b]
rparigoris
Hi Raimo
You mentioned:
Notice:
Thx.
