Builder_Bill
Joined: 19 Sep 2012 Posts: 7 Location: Newport News, VA USA
Posted: Thu Aug 29, 2013 12:29 pm Post subject: How to lose both ignition systems? |
Bob, I was at your seminar at EAA431Brodhead, WI this Spring.
There was a discussion on an accident involving a Lancair Dual LSE Ignition failure. I could not find it in a simple NSTB search assuming I even have enough details right to do so.
The builder had supplied each LSE from an independent source, but failed to consider something else. Something about fuse & CB's in series maybe?
Can you detail what happened to take down both LSE's? It's likely that sketch will be necessary.
Bill Jones
Posted: Thu Aug 29, 2013 6:09 pm Post subject: How to lose both ignition systems? |
At 03:29 PM 8/29/2013, you wrote:
<jonesw(at)mindspring.com>
Yes. That case settled a few weeks ago. I'm going to publish
my reports and demonstration videos that were produced in
support of the technical analysis. I need to 'sanitize' them
a little so as to avoid causing unwarranted discomfort on
the part of the participants.
In any case, it is unlikely that anyone here on the
List would repeat the error . . . an error that grew out
of a combination of 'redundancy' features stacked on top
of each other combined with a poor selection of components
wherein both systems shared hardware in the power path.
Run each ignition from a separate protective device on
the battery bus . . . or separate battery busses if there
are two batteries. Simple, direct, no shared hardware
and truly redundant.
Builder_Bill
Posted: Fri May 09, 2014 9:47 am Post subject: Re: How to lose both ignition systems? |
Hello Bob and AEC.
Can we re visit this one. I've read the NTSB accident narrative, but I need a sketch to follow this builders mistake.
Thanks, Bill
| nuckolls.bob(at)aeroelect wrote: | At 03:29 PM 8/29/2013, you wrote:
<jonesw>
Bob . . . |
Posted: Fri May 09, 2014 10:36 am Post subject: How to lose both ignition systems? |
At 12:47 PM 5/9/2014, you wrote:
Hello Bob and AEC.
Can we re visit this one. I've read the NTSB accident natative, but
Thanks, Bill
See N811HB at . . .
http://tinyurl.com/ky7szec
. . . for a detailed data dump
Posted: Sat May 10, 2014 8:32 am Post subject: How to lose both ignition systems? |
Hello Bob and AEC.
Bill, I didn't remember that the file-set
I posted had a few of holes in it.
hit these three links . . .
http://tinyurl.com/kyfn4y2
http://tinyurl.com/lmbbrmg
and particularly . . . this one
http://tinyurl.com/k5593wo
