altman51
Posted: Fri Aug 23, 2013 12:25 pm Post subject: Nanchang CJ 6 canopy |
Hey, I have a Nanchang CJ6 and will be putting on new canopies. Anybody out there that has done this please share your experience. How did yo handle the rivets and what kind of sealant did you use?
keithmckinley
Posted: Fri Aug 23, 2013 5:16 pm Post subject: Re: Nanchang CJ 6 canopy |
I did my rear canopy a couple years ago (2 piece). It was a bit of work but I made a simple jig to reinstall. Lots of test fitting, trimming, masking and careful drilling. Some basics:
1.you need a belt sander set up on a table (vice) to shape and grind the canopy to fit
2.I did not use sealant but a rubberized tape strip
3.I disassembled everything and had all parts powder coated except the actual canopy frame which I painted. Primed first, then painted inside, installed glass then painted outside.
4. no rivets, replaced all with screws
5. used all new 8-32 screws, the 4mm specialty nuts (if you re-use) tap out nicely. The heads on the us 8-32 screws are not quite the same taper as the chinese 4mm but there is no issue.
5. buy a plexiglass drill bit and oversize the holes. Also grind a taper in them.
6. do not wreck your old canopy! use it for measurement for the new glass
As I recall, my rear canopy took me about 40 hours without the painting.
Good luck
altman51
Posted: Sat Aug 24, 2013 2:56 am Post subject: Re: Nanchang CJ 6 canopy |
Thanks Keith that is very helpful information...
GeorgeCoy
Posted: Sat Aug 24, 2013 7:31 am Post subject: Nanchang CJ 6 canopy |
When we do the YAK Canopies, we place them on a table and nail a wooden
frame to match the outside of the frame. ( A jig). We also make a swinging
lever at the front to insure that the frame is square. Then take apart. DO
your restoration then fit the glass and put it back in the frame to do the
riveting. Do a few rivets and then put it airframe to check the fit. Then
back in the frame for the rest of the rivets.
George
barryhancock
Posted: Sat Aug 24, 2013 12:43 pm Post subject: Re: Nanchang CJ 6 canopy |
We have a jig for the Malcom Hood front slider. It is terrific for building new frames. We would be happy to sell it at this point since we no longer operate a restoration shop. If someone is interested, please contact me directly.
Obviously when you are drilling the holes you have to be very careful, drill slowly, and make the hole oversize to allow for temperature variation.
We offer complete sets of new canopies in clear, tint, and UV tint, including the Malcom Hood front slider (gives you about 3" additional height and much better overall visibility), and our WW exclusive one piece rear canopy.
Happy Flying,
Barry
_________________ Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com |
keithmckinley
Posted: Sat Aug 24, 2013 2:07 pm Post subject: Re: Nanchang CJ 6 canopy |
You can make a simple jig yourself on a plywood bench. I disagree with putting rivets back in unless you can get soft rivets and a rivet squeezer to control the pressure (at least on a CJ). With the right size screws and low profile nylon insert nuts there is nothing in the way or anything to catch on. I'll be happy to send you pics of mine when I get back to the hangar. just give me an email.
wlannon(at)shaw.ca Guest
Posted: Sat Aug 24, 2013 8:28 pm Post subject: Nanchang CJ 6 canopy |
There is only one area on the CJ canopy where you have to use rivets. That
is the aft end fairing of the front slider. All other rivets should be
replaced with 4-440 flush head screws and AN365 nuts.
You MUST use AN426A rivets. These are pure aluminum. The standard aircraft
rivet (flush head) is the AN426AD. These are alum. alloy and much too hard
for this application.
Even with the "A" rivet I manufacture bushings from 3/16" 5052 tubing 1/32"
longer than the Plexiglas thickness to carry the rivet load. And
definitely use a rivet squeeze!
For a nice job you should re-counter sink the original rivet holes to 100
degs. from the original 110 degs. for both the new rivets and 4-440 screws.
Holes in the glass should be 1/8" larger in dia. than the screw or rivet
bushing dia. which will allow some leeway for a mis-aligned hole. The
fastener should not come into contact with the glass.
This may sound like blasphemy but I do not re-grind drill bits or use a
special bit. The largest drill bit I use is a new 1/8" (or #30) to drill
the pilot holes. All drilling after that is with a Uni-Bit step drill which
will produce perfect holes with a chamfered edge. Note that it must be a
"Uni-Bit" - A single cutting edge.
Walt
Posted: Mon Aug 26, 2013 5:58 am Post subject: Nanchang CJ 6 canopy |
Kieth,
Thanks. Will start that project after Labor Day. At beach (PCN) getting attitude adjustment.
Ck 6,
Doc
On Aug 23, 2013, at 9:16 PM, "keithmckinley" <cetopfed(at)gmail.com> wrote:
Good luck
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=407397#407397
keithmckinley
Posted: Mon Aug 26, 2013 6:29 am Post subject: Re: Nanchang CJ 6 canopy |
Walt,
Thanks for that tip, I should have it made it more clear that the rivet issue or lack there of was for the rear canopy. I have attached a sheet from LP Aero that has some tips. I would definitely invest in special drills for the plexiglass. A small one to make pilot holes and the size you desire for the holes.
See attachment: canopy_installation_tips
 Download |
| Filename: |
canopy_installation_tips.pdf |
82.66 KB |
| Downloaded: |
790 Time(s) |
keithmckinley
Posted: Mon Aug 26, 2013 8:37 am Post subject: Nanchang CJ 6 canopy |
Keith;
Thanks - After four CJ6, Two Beech 35, Two Navion , One Bell47 and other
canopy installations I will be sure to change my process so I can begin to
crack expensive (customer's) plexiglas. I too use LP Aero materials
-they are well made.
Walt
Posted: Mon Aug 26, 2013 10:17 am Post subject: Nanchang CJ 6 canopy |
The instructions you referenced Keith differ somewhat from what Walt
recommends. While there are some similarities, Walt's recommendations
are ones that I have seen from other folks who are also very experienced
in how to work with Plexiglas.
I believe that personal experience tends to trump reference articles,
and I believe that was all Walt was saying.
Just my 2 cents.
Mark
keithmckinley
Posted: Mon Aug 26, 2013 10:26 am Post subject: Re: Nanchang CJ 6 canopy |
Walt,
I addressed a post to you and was thanking you for your tips. I did not mean to tell you to invest in a different drilling process. Instead that comment about drill bits was intended for the general audience. I should have made that clear. A guy that hasn't done a million canopies may want to use the method LP Aero suggest. I did and had excellent results. I have no doubt your method meets or exceeds that standard. It's no wonder nobody dares post on this site.
Sorry if I hurt your feelings.
Keith
| wlannon(at)shaw.ca wrote: | Keith;
Walt
keithmckinley
Posted: Mon Aug 26, 2013 10:42 am Post subject: Re: Nanchang CJ 6 canopy |
Mark,
I have no problem with that, non at all. God knows I'm no expert. I just know what worked for me. What I don't appreciate is a condescending cheap shot from behind a keyboard.
Posted: Mon Aug 26, 2013 11:09 am Post subject: Nanchang CJ 6 canopy |
I don't have a dog in this fight. In fact, I don't even own a dog.
Mark
p.s. I will never drill a windscreen or canopy as I am simply terrible
with that kind of stuff. A case of knowing one's own limitations.
jan.mevis(at)informavia.b Guest
Posted: Mon Aug 26, 2013 11:17 am Post subject: Nanchang CJ 6 canopy |
That's one remark that is right on spot: "no wonder nobody dares post on
this site".
And I can assure you that people whose native language happens to be
something else than English hesitate even more.
Jan
On 26/08/13 20:26, "keithmckinley" <cetopfed(at)gmail.com> wrote:
Walt,
Keith
> Keith;
>other
>to
> Walt
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=407523#407523
cjpilot710(at)aol.com Guest
Posted: Mon Aug 26, 2013 12:39 pm Post subject: Nanchang CJ 6 canopy |
That is the trouble with e-mail. In human communication 50% (by actual research) is visual body language. One can't see when someone has their tongue in their cheek. ;-}
Pappy
In a message dated 8/26/2013 3:18:16 P.M. Eastern Daylight Time, jan.mevis(at)informavia.be writes:
| Quote: | --> Yak-List message posted by: Jan Mevis <jan.mevis(at)informavia.be>
this site".
Jan
| Quote: | --> Yak-List message posted by: "keithmckinley" <cetopfed(at)gmail.com>
Walt,
Keith
> Keith;
>other
>to
> Walt
Keith McKinley
700HS
X26 Sebastian, FL
ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
Posted: Mon Aug 26, 2013 5:47 pm Post subject: Nanchang CJ 6 canopy |
Keith;
Just saw all the reaction to my post. I only see email in the AM and after
work - no I phone or anything like that.
I took your comments to mean you were in fact telling me to use another
process. If that was not the case then you have my apology.
You are right - no one dares post here and I usually refrain from posting
professional advice precisely because of that reaction.
I will not be offering any in future.
Walt
keithmckinley
Posted: Mon Aug 26, 2013 7:03 pm Post subject: Re: Nanchang CJ 6 canopy |
I wouldn't TELL anyone to do anything on this forum, especially someone I have asked for help from in the past.
No worries.
cd001633(at)mindspring.co Guest
Posted: Mon Aug 26, 2013 7:46 pm Post subject: Nanchang CJ 6 canopy |
Now, wait a minute Walt...
You and a few others are very knowledgeable and bring serious value to this
List - I appeal to you to reconsider refraining from further contributing to
this List.
I believe Pappy's comments regarding the limitation of E-mails in conveying
the true spirit and intention of the text is very true. The lack of voice
tone and eye contact is one of the major shortcomings of the E-mail concept
making it very easy to miss the intention (tonality, if you will) of the
written text.
This has happened to me too, several times, both in sending a message that
was misunderstood and misunderstanding a message sent to me...
In reading this evening's latest posts, it is obvious to me at least, that
there was no ill intent with neither one of you - let's agree to continue to
operate within the limitation of the e-mail system and continue to
contribute - we need you and others like you to stay and help the rest of
us, especially newbies who both you and I once were...
I hope you will consider the above,
Sam Sax
Miami, FL
