7suds(at)Chartermi.net Guest
Posted: Thu Aug 22, 2013 7:07 pm Post subject: spring gear flexing & brake lines |
Clem,
Not sure what you are running for brake line, I used the flexible plastic
line, I did however run my lines from the brake pedals along the outboard
inside edge of the fuselage and exited through the bottom of the fuselage
just behind the pivot attach point for the spring gear, lines will see the
least amount of movement at this location from gear flex. My gear is not gun
drilled so my lines continue down the rear edge of the gear in a factory
milled grove.
lloyd
