Fuel flow
clemwehner
PostPosted: Sun Aug 18, 2013 8:25 am    Post subject: Fuel flow Reply with quote
Our KF-IV has the plastic header tank behind the seat. Since the header tank is lower than the carbs, how can the engine run from the header tank in the event fuel flow stops from the main tanks for some reason? Some guys have said that there is about 10 minutes of fuel in the header tank. How is that possible with no gravity flow in level flight?
Does the engine fuel pump suck fuel from the header when it's running?
thanks,
Clem
Oklahoma
Guy Buchanan
PostPosted: Sun Aug 18, 2013 9:07 am    Post subject: Fuel flow Reply with quote
In a "normal" IV installation the mechanical pump will draw fuel from
the header at any sustainable pitch angle. Interestingly, I could find
no specification in the install manual for the minimum fuel level (below
the pump) that the pump would draw. Note that the mechanical pump works
with many aircraft that have low wings and therefore much less head
pressure than even your header tank.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
mikeperkins
PostPosted: Mon Aug 19, 2013 6:30 am    Post subject: Re: Fuel flow Reply with quote
The Mikuni fuel pump is spec'd to pull fuel against gravity to a height of 24 inches. However, I assume that's at 1 G. When the aircraft is at 2 Gs, so is the fuel. So if the assumption is correct that 24 inches is at 1 G, then the distance at 2 Gs becomes 12 inches. But I'm not sure how the fuel lift distance was specified (if it spec'd at 1 G or if it is spec'd at more than 1 G). Anyway, here's a writeup on the Mikuni fuel pump: http://www.ultralightnews.ca/mikuni/
Also, most Kitfoxes have fuel caps with ram air vents, but I'm not sure how many inches of fuel pressure they add.
That having been said, I plan to never count on the fuel remaining in the header tank alone because with a failed fuel pump, the lack of head pressure with empty wing tanks will create an unpleasant situation.
Mike Perkins
Havana, Illinois
Model I, 532, B gearbox, GSC prop
Guy Buchanan
PostPosted: Mon Aug 19, 2013 7:28 am    Post subject: Fuel flow Reply with quote
Mike,
Not too many people launch with empty wing tanks, and if you do, I
guess you get what you asked for, eh? Fortunately the head pressure in
level flight is nearly even, with most of the "loss" of pressure
attributable to friction and other mechanical losses. I don't know if
anyone else has done this but when I get to the end of this installation
I'll be testing without the fuel pump to see if the wing tanks will
gravity feed and at what attitude. There's some conjecture that the
vibration of the carbs allows a pure gravity feed in spite of the lack
of 2.5psi static pressure.
Guy Buchanan
Ramona, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
mikeperkins
PostPosted: Mon Aug 19, 2013 8:00 am    Post subject: Re: Fuel flow Reply with quote
Hi Guy,
You're right to say that no one would (or should) launch with empty tanks, but someone who encountered something unexpected enroute might wind up accidentally landing with them empty. In that case, a go-around would put the behind-the-seat header tank pretty dang low.
I once did a differential measurement of my Kiftox I's behind-the-seat header tank and the carbs. I discovered the aircraft's supply of fuel would depend upon a working fuel pump. But I don't remember the distance.
Mike Perkins
Havana, Illinois
lcfitt(at)sbcglobal.net
PostPosted: Mon Aug 19, 2013 8:40 am    Post subject: Fuel flow Reply with quote
Interesting discussion. On another forum a guy measured fuel flow beyond the
fuel pump at the carburetors and he found that the flow there didn't come
up to the FAA recommendations. So the fuel will flow past an inop pump.
However I seem to have heard that if the diaphragm has been breached, fuel
will preferably simply flow into the crank case - not sure on this. I would
think an easy fix would be an electric aux pump between the header tank and
the mechanical fuel pump. I have one on mine and the on switch is within
thumbs reach with my hand on the throttle.
Lowell
Sent: Monday, August 19, 2013 9:00 AM
Subject: Re: Fuel flow
Hi Guy,
Mike Perkins
Havana, Illinois
http://forums.matronics.com/viewtopic.php?p=407039#407039
Guy Buchanan
PostPosted: Mon Aug 19, 2013 9:24 am    Post subject: Fuel flow Reply with quote
On 8/19/2013 9:39 AM, Lowell Fitt wrote:
However I seem to have heard that if the diaphragm has been breached, fuel will preferably simply flow into the crank case - not sure on this. I would think an easy fix would be an electric aux pump between the header tank and the mechanical fuel pump. I have one on mine and the on switch is within thumbs reach with my hand on the throttle.
'Course if it's true about the diaphragm, the aux pump isn't going to help you much in that failure mode. (I've never heard of anyone pumping fuel into the case, though.)
Guy Buchanan
Ramona, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
redrocketrider
PostPosted: Mon Aug 19, 2013 9:53 am    Post subject: Fuel flow Reply with quote
I agree, the only way to fly, Back up for the mechanical. Bob & Toodie KF
4/1200/ O02, High Sierras.
Sent: Monday, August 19, 2013 9:39 AM
Subject: Re: Re: Fuel flow
the fuel pump at the carburetors and he found that the flow there didn't
come up to the FAA recommendations. So the fuel will flow past an inop
pump. However I seem to have heard that if the diaphragm has been
Lowell
> Hi Guy,
> Mike Perkins
> Havana, Illinois
.vcf
 Filename:  .vcf
 Filesize:  75 Bytes
 Downloaded:  706 Time(s)
Keep the dirty side down/Blue skies. Bob
cliffh(at)outdrs.net
PostPosted: Mon Aug 19, 2013 5:48 pm    Post subject: Fuel flow Reply with quote
I had a fuel pump failure last spring.
The engine would only run for less than a minute at full throttle.
Would run fine at cruise setting.
Fkoran Higgins
Helena, Mt.
Speedster
912 ULS
Dorsal
PostPosted: Thu Aug 22, 2013 3:41 pm    Post subject: Re: Fuel flow Reply with quote
Clem,
I initially ran my engine (without priming) off the header tank alone and it was happy to start and reach full power. This was on the ground, normal flight attitude on a 912ULS.
Dorsal ~~^~~
Series 7 Flying
912S Warp Drive
