Need explanation of fuel system w/dual 5gal pickups
Goto page 1, 2  Next
dsmithlib
PostPosted: Sat Aug 03, 2013 6:29 pm    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
I am rebuilding a Firestar II project. It has two 5 gal tanks, I have the plans from the mid-90's and (I thought) I had a pretty good understanding of aviation fuel systems and venting.
However, I am seeing both tanks fed together to a T and then up to the pump or primer etc.. What I am missing is how the fuel is drawn from the tanks equally. It seems to me that once air is introduced to EITHER fuel pickup, the system will be fuel starved.
I realize there is something I am not picking up from the drawings. I do not see any depiction of the venting which may hold the key. In any event, I would appreciate a few comments on best practices for plumbing the two standard 5 gal tanks.
Dave
Dave Smith
RV7 Flying
Kolb Firestar II (in-progress)
GeoB
PostPosted: Sun Aug 04, 2013 2:06 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Are the tanks at the same level?
Are the pickups descending from a fitting at the bottom of the tanks, or do
they drop down into the tanks from above?
If the tanks are level, then when you suck air both tanks will be almost
completely empty.
In the case where the tanks are not level, if the pickups descend from a
bottom fitting the weight of the fuel will displace the air potentially
introduced from the empty tank, and the fuel line will have fuel in it.
I have no experience with what I'm talking about here, I was just
visualizing the situation. I probably have misunderstood you cuz I imagine
you have already thought of all this.
GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors"
racerjerry
PostPosted: Sun Aug 04, 2013 3:13 am    Post subject: Re: Need explanation of fuel system w/dual 5gal pickups Reply with quote
If you are feeding fuel from fittings attached to the bottom of each tank; and both tanks are vented and at the same level, then gravity will do a good job of evenly emptying both tanks. I didn’t care much for drilling holes in the bottom of the tanks, so I opted to feed fuel from the top of each tank.
If you are feeding fuel sucking from the top of each tank, then things are a bit different. Fuel flow here is more dependent on venting pressures for each tank to empty evenly. You are correct in that if one tank sucks air, it’s GAME OVER. I had one forced landing because of this and attributed it to a small pressure difference between the tank vents (they are located fore and aft in a ‘breezy’ spot behind the pilot/passenger) where most likely each vent was subjected to different airflow patterns. There was only a small amount of fuel left in the other tank; so the system worked OK as long as neither one got too low. You might try tying both vents together to equalize any pressure differences; but just don’t let the fuel level get too low and you won’t have to worry about it.
Jerry King
rickofudall
PostPosted: Sun Aug 04, 2013 4:08 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Dave, I battled this one on my Mk III. My solution was to use a modified Weatherhead valve to get left, right, both, and off so I could control the tanks.The modification is simple. The Weatherhead valve has a nylon ball with two passages at right angles that meet in the center. There are four detents that control how the passages line up with the ports. Simply drill through one side so that there are now three passages in a "T" configuration. Which one of the original two you use to guide the drill is only dependent on where you want the handle to be when the the undrilled side of the ball is over the fuel inlet port (where you want the handle when the valve is in the OFF position.
With this solution you have absolute control over how fuel is drawn from the tanks. On a cross country flight when I was running low on fuel and needed every available drop I was able to purposely run a tank dry and switch to the tank that still had fuel before the engine died. Having a Facet pump to boost fuel to the Mikuni pneumatic pump I got an instant prime when I switched tanks and the engine hardly stuttered before it had fuel from the other tank and resumed running.
Yep, bad practice that I pulled off once and never repeated. The fact that I could do it at all was because the valve gave me complete control over the fuel supply.
Rick Girard
On Sat, Aug 3, 2013 at 9:29 PM, dsmithlib <dsmithlib(at)ameritech.net (dsmithlib(at)ameritech.net)> wrote:
--> Kolb-List message posted by: "dsmithlib" <dsmithlib(at)ameritech.net (dsmithlib(at)ameritech.net)>
Dave
Dave Smith
RV7 Flying
http://forums.matronics.com/viewtopic.php?p=405880#405880
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
  - Groucho Marx
frank goodnight
PostPosted: Sun Aug 04, 2013 4:45 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Richard
What is weather head valve?
Where can I get one?
How can I be sure it is good for
Fuel?
Frank
On Aug 4, 2013, at 7:07 AM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote] Dave, I battled this one on my Mk III. My solution was to use a modified Weatherhead valve to get left, right, both, and off so I could control the tanks.
Rick Girard
On Sat, Aug 3, 2013 at 9:29 PM, dsmithlib <dsmithlib(at)ameritech.net> wrote:
> Thanks,
> Dave
> Dave Smith
> RV7 Flying
> arget="_blank">http://www.matronics.com/Navigator?Kolb-List
> le, List Admin.
> ="_blank">http://www.matronics.com/contribution
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
Richard Pike
PostPosted: Sun Aug 04, 2013 5:36 am    Post subject: Re: Need explanation of fuel system w/dual 5gal pickups Reply with quote
If switching tanks does not appeal to you, think about adding a hopper tank. Go to Home Depot and purchase some 4" PVC pipe and flat end caps. They sell 3 types of PVC pipe, one is thick wall and heavy, and the other is thin wall. The third type has a foam core, don't get the foam core. Gasoline doesn't affect the PVC. Make it whatever size you can get to fit anywhere near the back seat and below the level of the stock tanks. Make up some appropriate brackets and clamp it securely in place. It doesn't need to be very big, it just needs to hold a quart or so and be the lowest point in the system.
NAPA auto parts sells a metal tire valve stem with a wide flat flange on each side and rubber gaskets, you can drill it out and use it as a fuel fitting, put it into the flat end cap of the pipe.
Set it up so that both of your stock tanks drain into the hopper tank, and the hopper tank goes to your Facet pump. The fitting that goes to the Facet pump is obviously the lowest point in the system. Also rig it for a sump drain. Since this little hopper tank is below your stock tanks, you don't care if one of them drains dry, you only have to be on the ground before both of them drain dry.
If you want to spend about $150 for various pieces-parts (mostly on on brass T fittings) you can put in 2 of these things, mount them vertically beside the forwardmost stock tank, and gain a bit over 2 gallons of fuel. Figuring out how to arrange all the plumbing will have you making up a real flow chart, but if you want 12 gallons of usable fuel, here's how to do it: http://www.bcchapel.org/pages/0003/FSIITankMods.html
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
rickofudall
PostPosted: Sun Aug 04, 2013 6:52 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Frank, Here you go.http://www.aircraftspruce.com/catalog/appages/whfsv.php
Rick
On Sun, Aug 4, 2013 at 7:44 AM, Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
Richard
Fuel?
Frank
On Aug 4, 2013, at 7:07 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Dave, I battled this one on my Mk III. My solution was to use a modified Weatherhead valve to get left, right, both, and off so I could control the tanks. The modification is simple. The Weatherhead valve has a nylon ball with two passages at right angles that meet in the center. There are four detents that control how the passages line up with the ports. Simply drill through one side so that there are now three passages in a "T" configuration. Which one of the original two you use to guide the drill is only dependent on where you want the handle to be when the the undrilled side of the ball is over the fuel inlet port (where you want the handle when the valve is in the OFF position.
Rick Girard
Dave
Dave Smith
RV7 Flying
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
cs.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Thom Riddle
PostPosted: Sun Aug 04, 2013 6:59 am    Post subject: Re: Need explanation of fuel system w/dual 5gal pickups Reply with quote
My Slingshot had two 5 gallon tanks with a connection tube between them close to the bottom so that they acted almost as if they were one tank. I say almost because the connection was not in the bottom but on the side wall close to the bottom. The line to the electric fuel pump was from the top in the rear of the two tanks since it is a bit lower than the front except in a dive. The vent from the top of front tank(which also connected to the top of the rear tank) went down and exited below the fuselage. Since the connection line was small (1/4") the flow between the two tanks was not nearly as fast as the rate you can fill the tanks. It is quicker to fill both than wait for one to drain to the other.
If you don't mind putting holes in the bottom of the tank, which is what I would have done had I been the builder, the connection line will make them effectively one 10 gallon tank. RANS Aircraft has an excellent fuel tank fitting for the bottom of tanks and they do not leak.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
frank goodnight
PostPosted: Sun Aug 04, 2013 7:04 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Richard
The metal tire valve you mentioned
Also makes an excelant fitting if you want to feed from the bottom of
The tanks. Just drill out the center
And use a fuel proof gasket.
Used them for years my firestar.
Frank----they come in 2 sizes, the
Long ones work best.
Richard Pike
richard (at) bcchapel(dot)org
Kingsport, TN 3TN0
Now faith is the substance of things hoped for, the evidence of things not seen.
Hebrews 11:1
http://forums.matronics.com/viewtopic.php?p=405898#405898
frank goodnight
PostPosted: Sun Aug 04, 2013 8:30 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Richard
Thanks , Got one on my701but didn't
Know it. Was going to buy new valves
And replumb,so i could run from both tanks ,your method is a lot quicker
Eaiser and cheaper.Love this Kolb list.
Frank
On Aug 4, 2013, at 9:52 AM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote] Frank, Here you go.
Rick
On Sun, Aug 4, 2013 at 7:44 AM, Frank <frank.goodnight(at)att.net> wrote:
> Richard
> Fuel?
> Thanks
> Frank
> Sent from my iPhone
>> Rick Girard
>> do not archive
>>> Thanks,
>>> Dave
>>> Dave Smith
>>> RV7 Flying
>>> Read this topic online here:
>>> le, List Admin.
>> Zulu Delta
>> Mk IIIC
>> Thanks, Homer GBYM
>> - Groucho Marx
>> cs.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
Frankd
PostPosted: Sun Aug 04, 2013 8:44 am    Post subject: Re: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Hi Dave,
I have the two tank system in my MkIII Xtra.
The fuel pickup tubes go to the bottom of both tanks and I have connected them with a T at the top and then this single fuel line I run down to a fuel pump placed at the height of the bottom of the tanks.
The trick is to initially suck fuel from BOTH tanks so there is no air in the lines.
Both 5Gal tanks are side by side so if one is full and one is half full the fuel will eventually flow from the full to the lower until they are equal.
My vent lines just plumb into the top of the tank and I run them up about 6 inches and then down to the outside of the plane. In case I go inverted the fuel will stay outside the aircraft.
This system acts like one tank, no switching required. Just fill both up equally and its fine.
I'm thinking of adding another 5 gal tank and may add a valve as a control into the 1st two if I do that.
Hope this helps.
Oh, I also have two fuel filters, one just after the T at the top of the tank and one on the fuel pump. No problems so far, 50Hrs flying.
FrankD
byoungplumbing(at)gmail.c
PostPosted: Sun Aug 04, 2013 9:17 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
I have never tried this, but offer it to you for your consideration,, you would have to do some experimenting to see if the system works, or how hard to eliminate all the air.
if you come out of the top of both tanks,,, then loop the lines to below both tanks and put the tee from both tanks and the inlet to the engine in the bottom of the cage. you would have to start a siphon from each tank to purge the air from both lines and establish a siphon. then each tank will drain via the siphon line to the tee. if one tank goes empty the siphon for that tank will quit, the other will continue to siphon till it is empty, if one tank is empty the other tank will keep the area of the tee (going to the engine) flooded with fuel, this should keep the engine happy till the second tank empties and the second siphon is lost. at that point you are out of gas and are going to let gravity be a major part of flying the plane. down side would be if you had a vacuum leak that stopped the siphon on one tank... your engine could quit with one tank full. to prevent this,, you could put a “left right or both� valve at the bottom the cage in place of a simple T,
just thinking out loud.
boyd young
Dave
dan42101(at)yahoo.com
PostPosted: Sun Aug 04, 2013 10:07 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
One way to do it is to just use the front tank to feed the carbs via the Mikuni pump, and use a facet pump to transfer fuel in flight. When you feel fuel on the back of your neck you know your font tank is full... Once you feel the fuel on your neck you will never take your hand off the pump switch during a transfer again.
Some good fuel system suggestions:
http://www.challengers101.com/FuelSys.html
Sent: Saturday, August 3, 2013 9:29 PM
Subject: Need explanation of fuel system w/dual 5gal pickups
Dave
Dave Smith
RV7 Flying
http://forums.matronics.com/vi-> http://ww=======================
dsmithlib
PostPosted: Mon Aug 05, 2013 8:10 am    Post subject: Re: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Thank you to all for replying.
From what I have learned here......
I will...
use individual pickups from the top
then connect with a T
then go to a filter
then to a elec facet pump
then to the pulse pump
I will T off at some point for primer
They will be well vented but I am not sure how I will plumb the vents at this moment......sounds like they will also get T'd and then plumbed overboard.
Thank you !
Thank you !
Thank you !
Dave Smith
RV7 Flying
neilsenrm(at)gmail.com
PostPosted: Mon Aug 05, 2013 11:17 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
I keep hearing people say they don't want to put the fuel pickup on the bottom of their tanks. I don't understand their issues. I have been flying my VW powered MKIIIC for fifteen years. I use the press fit bushings in the standard Kolb plastic tanks and have never had a seeping fuel issue. About 7-8 years ago I replaced the tanks just to be safe and again no issues. I now have the 6 gallon tanks ready to install and yes I have drilled the bottoms and installed the press fit bushings. I insert a fitting that has a finger strainer and shut off valve.
My theory is feeding fuel from the bottom is the most reliable way to get fuel to my engine because there are fewer things that can go wrong. Fuel feeds evenly from both tanks and if one tank gets filled more than the other they will equalize in time. Again I have never had a press fit bushing leak but I have had a fuel line leak. When the fuel line developed a leak it was dangerous but it didn't cause a engine failure like would have happened if I was feeding from the top of the tanks. I did notice a fuel smell that got me looking. It would seem that fuel seepage would be the worst case problem for bottom feed. If you top feed and you get even a minor air leak you wouldn't know till engine start or worst case in the air.
I use a stepped drill bit to drill the hole in the plastic fuel tanks for the fuel bushings. I think they drill a more rounded hole in thin plastic. Then I very carefully debur the holes.
I tee the fuel tanks together. I have flown many different GA airplanes that have fuel selectors and they are a pain. Something else that you HAVE to do. On low wing airplanes with wing tanks, where it is necessary it is a necessary evil, it is ok. Why add something like a fuel selector that adds to the work load and is a potential problem?
Just my opinion. As always this is worth what you paid for it.
Rick Neilsen
1st Redrive VW powered MKIIIC
On Sun, Aug 4, 2013 at 12:44 PM, Frankd <FDucker(at)aol.com (FDucker(at)aol.com)> wrote: [quote] --> Kolb-List message posted by: "Frankd" <FDucker(at)aol.com (FDucker(at)aol.com)>
Hi Dave,
Hope this helps.
FrankD
http://forums.matronics.com/viewtopic.php?p=405914#405914
le, List Admin.
jim.baker(at)windstream.n
PostPosted: Mon Aug 05, 2013 2:45 pm    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
Murphy said it best -  "Anything that can go wrong, will go wrong".
Yours doesn't leak and hasn't leaked. That's not to say that at some time in the future it won't leak. The top plumbed units won't leak as yours might but still have a slight chance of leaking thru a cracked seam or some other mechanism.
There is no advantage to top plumbed except possibly access and maintenance. Top plumbed allows me to but a bronze filtered clunk at the bottom of the tank standpipe without having to pull the tank out. All maintenance can be done with the tank as is, where is. Either methodology, top or bottom, will work, just depends on your point of view. I've had the same tanks for 18 years. There was never a time when I doubted the integrity of fuel delivery methodology chosen. Personal choice, not a denouncement.
Date sent:                  Mon, 5 Aug 2013 15:17:02 -0400
Subject:                     Re: Re: Need explanation of fuel system w/dual 5gal pickups
From:                         Rick Neilsen <neilsenrm(at)gmail.com>
To:                            kolb-list(at)matronics.com
Send reply to:            kolb-list(at)matronics.com
> Rick Neilsen
> On Sun, Aug 4, 2013 at 12:44 PM, Frankd <FDucker(at)aol.com> wrote:
>     --> Kolb-List message posted by: "Frankd" <FDucker(at)aol.com>
>     Hi Dave,
>     fine.
>     if I do that.
>     Hope this helps.
>     FrankD
>     le, List Admin.
Jim Baker
Elmore City, OK
580.788.2779 home
405.426.5377 cell
rickofudall
PostPosted: Mon Aug 05, 2013 6:35 pm    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
When I decided to redo the fuel system in my Mk III I debated top or bottom draw. Then I pulled the old tanks out and the grommet was split almost to the fitting. Pushed me in favor of top draw, plus that was the factory recommendation. Since Mr. Murphy never sleeps, I had an engine out landing because I didn't have any sort of filter on the top pickups. Fixed that and never had another fuel problem. Venting. Something I haven't seen discussed on the forum is venting that will not become a drain if you inadvertently do a low altitude outside loop (flip over on landing). The LongEZ crowd recommends a vent design that includes a suction break to prevent such an occurrence. I never got it implemented, but I will during this rebuild. Just a thought.
Rick Girard
On Mon, Aug 5, 2013 at 5:45 PM, Jim Baker <jim.baker(at)windstream.net (jim.baker(at)windstream.net)> wrote:
Subject:                     Re: Kolb-List: Re: Need explanation of fuel system w/dual 5gal pickups
From:                         Rick Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)>
To:                            kolb-list(at)matronics.com (kolb-list(at)matronics.com)
Send reply to:            kolb-list(at)matronics.com (kolb-list(at)matronics.com)
> Rick Neilsen
>     Hi Dave,
>     fine.
>     if I do that.
>     Hope this helps.
>     FrankD
>     le, List Admin.
Jim Baker
Elmore City, OK
[url=tel:580.788.2779]580.788.2779[/url] home
[url=tel:405.426.5377]405.426.5377[/url] cell
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
PostPosted: Mon Aug 05, 2013 7:26 pm    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
I generally recommend a sintered bronze filter as a clunk on the bottom of the standpipe. For those unfamiliar with the term clunk, comes from the radio control world where the fuel pickup was guided by G forces to follow the fuel's location in the tank. It's close enough to the bottom of the tank that should the filter-hose-standpipe connection be compromised you'll still draw fuel from the standpipe, it just won't be filtered and you won't get that last little bit out of the tank. If you're flying that close to the edge....well......
Date sent:                  Mon, 5 Aug 2013 21:35:18 -0500
From:                         Richard Girard <aslsa.rng(at)gmail.com>
To:                            "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
> Rick Girard
> do not archive
> On Mon, Aug 5, 2013 at 5:45 PM, Jim Baker <jim.baker(at)windstream.net > wrote:
>     Date sent:Mon, 5 Aug 2013 15:17:02 -0400
>     Subject:Re: Re: Need explanation of fuel system w/dual 5gal
>     pickups
>     From:Rick Neilsen <neilsenrm(at)gmail.com>
>     To:kolb-list(at)matronics.com
>     Send reply to:kolb-list(at)matronics.com
>     > I keep hearing people say they don't want to put the fuel pickup on the bottom of their
>     tanks. I
>     > don't understand their issues. I have been flying my VW powered MKIIIC for fifteen
>     years. I use
>     > the press fit bushings in the standard Kolb plastic tanks and have never had a seeping
>     fuel
>     > issue. About 7-8 years ago I replaced the tanks just to be safe and again no issues. I
>     now have
>     > the 6 gallon tanks ready to install and yes I have drilled the bottoms and installed the
>     press fit
>     > bushings. I insert a fitting that has a finger strainer and shut off valve.
>     > My theory is feeding fuel from the bottom is the most reliable way to get fuel to my engine
>     > because there are fewer things that can go wrong. Fuel feeds evenly from both tanks and
>     if one
>     > tank gets filled more than the other they will equalize in time. Again I have never had a
>     press fit
>     > bushing leak but I have had a fuel line leak. When the fuel line developed a leak it was
>     > dangerous but it didn't cause a engine failure like would have happened if I was feeding
>     from the
>     > top of the tanks. I did notice a fuel smell that got me looking. It would seem that fuel
>     seepage
>     > would be the worst case problem for bottom feed. If you top feed and you get even a
>     minor air
>     > leak you wouldn't know till engine start or worst case in the air.
>     > I use a stepped drill bit to drill the hole in the plastic fuel tanks for the fuel bushings. I
>     think they
>     > drill a more rounded hole in thin plastic. Then I very carefully debur the holes.
>     > I tee the fuel tanks together. I have flown many different GA airplanes that have fuel
>     selectors
>     > and they are a pain. Something else that you HAVE to do. On low wing airplanes with
>     wing
>     > tanks, where it is necessary it is a necessary evil, it is ok. Why add something like a fuel
>     selector
>     > that adds to the work load and is a potential problem?
>     > Just my opinion. As always this is worth what you paid for it.
>     > Rick Neilsen
>     > 1st Redrive VW powered MKIIIC
>     > On Sun, Aug 4, 2013 at 12:44 PM, Frankd <FDucker(at)aol.com> wrote:
>     > --> Kolb-List message posted by: "Frankd" <FDucker(at)aol.com>
>     > Hi Dave,
>     > I have the two tank system in my MkIII Xtra.
>     > The fuel pickup tubes go to the bottom of both tanks and I have connected them with a
>     T at
>     > the top and then this single fuel line I run down to a fuel pump placed at the height of
>     the
>     > bottom of the tanks.
>     > The trick is to initially suck fuel from BOTH tanks so there is no air in the lines.
>     > Both 5Gal tanks are side by side so if one is full and one is half full the fuel will
>     eventually
>     > flow from the full to the lower until they are equal.
>     > My vent lines just plumb into the top of the tank and I run them up about 6 inches and
>     then
>     > down to the outside of the plane. In case I go inverted the fuel will stay outside the
>     aircraft.
>     > This system acts like one tank, no switching required. Just fill both up equally and its
>     > fine.
>     > I'm thinking of adding another 5 gal tank and may add a valve as a control into the 1st
>     two
>     > if I do that.
>     > Hope this helps.
>     > Oh, I also have two fuel filters, one just after the T at the top of the tank and one on
>     the
>     > fuel pump. No problems so far, 50Hrs flying.
>     > FrankD
>     > Read this topic online here:
>     > http://forums.matronics.com/viewtopic.php?p=405914#405914
>     > arget="_blank">http://www.matronics.com/Navigator?Kolb-List
>     > le, List Admin.
>     > ="_blank">http://www.matronics.com/contribution
>     > http://www.matronics.com/Navigator?Kolb-List
>     Jim Baker
>     Elmore City, OK
>     580.788.2779 home
>     405.426.5377 cell
> Zulu Delta
> Mk IIIC
> Thanks, Homer GBYM
>  - Groucho Marx
Jim Baker
Elmore City, OK
580.788.2779 home
405.426.5377 cell
GeoB
PostPosted: Tue Aug 06, 2013 12:51 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
I am not 100% sure I know what you mean here. Is 'press fit' the gadget that
is held in place in the hole by a neoprene grommet? It is a short tube with
a sort of barb on the end so the fuel line won't come off?
The circle track racers wind the vent tube around the tank 2-3 times.
GeoB
PostPosted: Tue Aug 06, 2013 5:11 am    Post subject: Need explanation of fuel system w/dual 5gal pickups Reply with quote
George
The press fit bushings are ultralight/light plane standard fuel fittings They are inserted into a hole in plastic fuel tanks. They are a fuel proof rubber like material. After they are inserted a metal fuel fitting is pressed into the bushing which locks the bushing in place and makes the assembly highly leak resistant. They do require that the proper sized hole is drilled, that is the hole is carefully debured, and the fuel fitting is lightly lubricated when it is installed.
Rick Neilsen
Redrive VW Powered MKIIIC
On Tue, Aug 6, 2013 at 4:51 AM, George Bearden <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)> wrote:
[quote]--> Kolb-List message posted by: "George Bearden" <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)>
le, List Admin.
Goto page 1, 2  Next
Page 1 of 2
