AW: Re: AW: G Load testing
Alfred Buess
PostPosted: Sat Jul 27, 2013 4:25 am    Post subject: AW: Re: AW: G Load testing Reply with quote
Clive,
We made a strong steel support for the wings to avoid any damage to the
fuselage. I published a short report about our load test with some pictures
in the Europa Flyer #30, that you can find on the Europa Club website.
The load test is worth wile, but it is thrilling! Good luck
Alfred
Alfred Buess
CH-3700 Spiez, Switzerland
Email ykibuess(at)bluewin.ch
Europa XS HB-YKI, Ercoupe 415-E N94804
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von gtagr
Gesendet: Samstag, 27. Juli 2013 13:25
An: europa-list(at)matronics.com
Betreff: Re: AW: G Load testing
Bruno,
Thanks for your post -we can trust a German to provide some excellent
detail! That photo gives me great confidence in the design - they are bags
of cement?
Clive Very Happy
uvtreith(at)t-online.de
PostPosted: Sat Jul 27, 2013 5:35 am    Post subject: AW: Re: AW: G Load testing Reply with quote
Bruno,
of cement?
Clive Very Happy
Yes, these are bags of cement, borrowed from a local DIY shop.
 Bruno
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von A. Buess - Aviatik
Gesendet: Samstag, 27. Juli 2013 14:23
Betreff: AW: Re: AW: G Load testing
--> Europa-List message posted by: "A. Buess - Aviatik" <ykibuess(at)bluewin.ch>
Clive,
Alfred
Alfred Buess
--> Europa-List message posted by: "gtagr" <clive.maf(at)googlemail.com>
Bruno,
of cement?
Clive Very Happy
PostPosted: Sun Jul 28, 2013 3:35 am    Post subject: AW: Re: AW: G Load testing Reply with quote
Hi Paul,
Here are some pictures.
02+04 is preparation with a soft foam blanket on which we also marked the position of the concrete bags, each 25 kg. 07 shows the support winches, which you can release very slowly and jumpless
15 shows the measurement after each load increase, 16+17 the full load of each side and 21 the full load spread.
Each side 1035 kg concrete bags, therefore 2.070 kg in total. To this you have to add the wing weight of 94-100 kg complete, depends on build.
The winches were released free (you can see it on the loose foam supports). One problem was that the support timber sticks were too short, so that we had to do some work on the wing surface later.
A similar test was also done with the tail plane 100 to 150 kg and opposite (pictures 9839, 9842 and 9845
With picture 9854 you can see, that this load test on a classic one failed. The fuselage/cockpit was not correct made and the fuse started to bulk out. This was later repaired and than ok.
This is the wing load test, approved by the OUV and LBA here in Germany
Bruno
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Paul McAllister
Gesendet: Samstag, 27. Juli 2013 17:34
Betreff: Re: Re: AW: G Load testing
Does anyone have any photos that show the entire wing under load where I can see the deflection?
On Sat, Jul 27, 2013 at 6:24 AM, gtagr <clive.maf(at)googlemail.com (clive.maf(at)googlemail.com)> wrote:
--> Europa-List message posted by: "gtagr" <clive.maf(at)googlemail.com (clive.maf(at)googlemail.com)>
Bruno,
Thanks for your post -we can trust a German to provide some excellent detail! That photo gives me great confidence in the design - they are bags of cement?
Clive Very Happy
http://forums.matronics.com/viewtopic.php?p=405403#405403
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
 Filesize:  86.61 KB
 Viewed:  1696 Time(s)
 Filesize:  110.13 KB
 Filesize:  103.34 KB
 Filesize:  97.72 KB
 Filesize:  99.98 KB
 Filesize:  105.49 KB
 Filesize:  101.98 KB
 Filesize:  95.29 KB
 Filesize:  75.49 KB
 Filesize:  86.82 KB
 Filesize:  87.79 KB
