kenbrooks(at)charter.net Guest
Posted: Sat Jul 27, 2013 11:25 am Post subject: F-445 bolts |
Does anyone recall if the four bolts through the F-445 (phenolic) flap arm hold down blocks get torqued? Couldn't find it in the manual anywhere on on the drawing. We torqued them to 20 inch pounds and the arm would barely move with finger pressure. That little flap motor would have to work pretty hard to move the arm along with wind loading in flight. Thanks in advance. - Ken
denis.walsh(at)comcast.ne Guest
Posted: Sat Jul 27, 2013 1:19 pm Post subject: F-445 bolts |
Whatever the good book says for those size bolts, 20 sounds about right but check.
What you need to do is add washer(s) between the blocks as necessary to relieve the pressure to a reasonable amount. Start with a "thin" washer and add as neccesary. I found one regular size washer was just right.
Hark to the fact that I am going back 20 years in my memory, and I may be thinking of the rudder tubes which had the same system on the RV 6.
On 27Jul, 2013, at 1:24 , Ken Brooks <kenbrooks(at)charter.net> wrote:
