woxofswa
Posted: Sat Jul 20, 2013 11:22 am Post subject: Brain trust stick wiring poll |
I'm at the stage of wiring my stick grips and wondering what sage advice there is on running the wires inside the stick or outside. I'm leaning inside, but love to hear some feedback.
Thanks in advance.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
flysrv10(at)gmail.com Guest
Posted: Sat Jul 20, 2013 11:37 am Post subject: Brain trust stick wiring poll |
Inside man! Duh!
do not archive.
On Jul 20, 2013, at 3:22 PM, woxofswa <woxof(at)aol.com> wrote:
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. FWF complete.
http://forums.matronics.com/viewtopic.php?p=404980#404980
Posted: Sat Jul 20, 2013 12:45 pm Post subject: Brain trust stick wiring poll |
I ran mine on the inside .... full blown infinity stick grips. I had to
'relieve' the sharp bend at the bottom of the straight portion and the
wire exits through a 1/4" hole at the rear of the mount.
Linn
On 7/20/2013 3:22 PM, woxofswa wrote:
Thanks in advance.
Myron Nelson
Mesa, AZ
Checked by AVG - www.avg.com
cooprv7(at)yahoo.com Guest
Posted: Sat Jul 20, 2013 1:09 pm Post subject: Brain trust stick wiring poll |
Absolutely inside.
Marcus
Thanks in advance.
Myron Nelson
Mesa, AZ
rv10flyer(at)live.com Guest
Posted: Sat Jul 20, 2013 2:14 pm Post subject: Brain trust stick wiring poll |
I have the infinity grips. I drilled and put the wires on the inside,
however I also had an issue and needed to replace one of the switches on the
grip. It would have been a lot easier to have the wires on the outside.
Also, if you plan to put a boot over the stick, outside is fine.
Only reason to think outside is time, it is really easy to run the wires up
the stick and zip tie, but if you do, make sure you cover them with a full
stick boot.
Pascal
bill.peyton
Posted: Sun Jul 21, 2013 4:55 am Post subject: Re: Brain trust stick wiring poll |
I ran mine inside also. There is no reason not to, and it looks better. You will have to drill a hole at the top of the stick where the vertical attaches to the main part of the stick. You don't need a large hole. I covered the wires with anti chafe skin and left enough slack at the bottom where it exits, to pull the grip up off the stick very easily if they need servicing. The downside is removing the stick requires disconnecting the wires. To aid in making this a bit easier, I used a barrier block with screw terminals. If you put a connector on the end of the wires, you will not be able to pull them all the way back out.
141 KB |
19376 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
toaster73(at)embarqmail.c Guest
Posted: Sun Jul 21, 2013 1:47 pm Post subject: Brain trust stick wiring poll |
Here is a solution for running inside the stick. We welded a doubler on the
stick receiver since we slotted it. This allows complete removal of the
stick with the wiring/CPC connector. Infinity grips used.
-Chris Lucas
N919AR
336.6 KB |
19354 Time(s) |
274.52 KB |
19354 Time(s) |
Posted: Sun Jul 21, 2013 1:58 pm Post subject: Brain trust stick wiring poll |
Inside. In fact even if I had a stick boot (which I never will) I would run them inside. With the Infinity wire bundle there are a LOT of wires. I think we ended up using a common ground so we were able to remove more than a third of the wires leaving extras in case I wanted to expand in the future. This made it a lot easier to fish through the stick. On the tail end we used a D Shell style connector in the rare event we would have to remove the stick. We did the same set up on all the 2 place RV's as we often removed the Co-pilots stick for various reasons.
One note on grip buttons. If I were to do it over again with all the modern tech and push button items in our cockpit I would now dedicate one button to an OK or Accept button. We get the most random notifications on these glass displays that simply request acknowledgement. It would be nice the flick a pinky to confirm the notification.
One note on the grips themselves. I see so many installs that have the grip facing straight forward. I strongly suggest you sit in your seat properly located forward & aft to see what angle your stick hand lands on the stick. Put the grip in our hand un-mounted or over the stick to see what feels best. Close your eyes and drop your hand into position. Do it several times. You will notice the ideal orientation has significant rotation from directly forward. Mine was about a 40 Degree rotation. No way would straight forward be comfortable for long hand flying. Even worse on takeoff when you often have to flick the trim several times, flip the Flaps Up toggle and push the flip/flop not having the correct & natural orientation on the grip makes for something less than ideal button orientation as well as a less natural placement in your hand. Just something to consider.
Robin
Bob Turner
Posted: Sun Jul 21, 2013 3:37 pm Post subject: Re: Brain trust stick wiring poll |
My plane is definitely function first, beauty last. I ran the wires, in a protective covering, on the outside.
Adding to Robin's comment, one nice feature of the Tosten grip is that the hold down screw rides in a groove. With it snug but not tight the grip rotates naturally with your hand, as you move the stick.
_________________ Bob Turner
RV-10 QB |
woxofswa
Posted: Sun Jul 21, 2013 4:56 pm Post subject: Re: Brain trust stick wiring poll |
Thanks for the replies.
I went for the inside option tied to a bus terminal mounted on the gear tree. I ran enough slack to just clip off ring terminals and re-crimp several times if I ever have to remove.
My stick grips are unique. To have a little flavor of the day job, I used a battle worn salvage Boeing 737 yoke. I cut off the uprights to make them my stick grips. My trim, A/P disco, and PTT will all be original Boeing on the left grip. I'm still looking for another trim switch module to install in the right. To attach the grips to the sticks I hillbilly engineered an interface from a stack of the scrap spar spacers.
Mesa, AZ
Flew May 10 2014 |
Tim Olson
Posted: Mon Jul 22, 2013 5:07 am Post subject: Brain trust stick wiring poll |
While usually Robin and I are on the same page, here I differ a bit.
I think too much is made of the rotating of the grip. Yeah, you will want it
rotated slightly, but I don't think any major rotation is warranted.
I would probably be more likely to recommend AGAINST going
very far in rotation and here's why...
When flying the RV-10, even during landing, I rarely use more than
2 or 3 fingertips on the stick....LITERALLY. You just give it gentle
nudges with 1 or 2 fingers and it does what you want. Honestly
I never ever have the need to grab the grip with a full hand on most
flights. You could throw an mis-shapen blob of rocks on the end of
the stick and I could fly with it, because gripping it is just not
something you would do for hours on end. Your forearm rests
on your legs and it's very comfortable to fly. I could fly with it
cockeyed by 40 degrees, 90 degrees, or 180 degrees.
But, when the rubber meets the road, and you DO need to grip it
hard, that's likely going to be during a time of trouble....some time when
you're going to actually exert yourself to push or pull or yank and bank
like during some event or bad turbulence. At that point I would
recommend that the yoke be rotated in the direction that gives you
the most arm "solid" control ability. Sit at your desk right now,
and try to push yourself back from your desk with your fist, and
see what position your arm wants to be in. Mine certainly doesn't
have full strength at 40 degrees offset. In fact, it's probably
not many degrees off straight...maybe 5-10 at most.
So my position on it is basically....rotate the grip so that if you needed
to do a hard push to override an autopilot or break a stall or
perform a hard maneuver, you could do it with a locked wrist and
be comfortable. And, beyond that, don't worry about it much because
if you're giving the stick your full grip during normal maneuvers
you're probably trying too hard...it's a plane that can be flown
with fingertips and trim alone.
As Dave Mason sung years ago..... "We just disagree", Robin.
No worries though....this one falls into that "do whatever you wish"
category as far as I'm concerned. I'm just providing the counterpoint.
On 7/21/2013 4:58 PM, Robin Marks wrote:
Robin
johngoodman
Posted: Mon Jul 22, 2013 6:58 am Post subject: Re: Brain trust stick wiring poll |
Infinity grip with the wires on the outside. Full boot cover from Flightline Interiors. Very slightly rotated.
Posted: Mon Jul 22, 2013 10:39 am Post subject: Brain trust stick wiring poll |
I tried to strike a reasonable balance between beauty and function.
Actually I just got lazy.
Tosten grips and external wire run without a boot. Looks utilitarian
but neat to my eyes. No regrets until this thread.
I chose the Tosten grip because the Infinity had 1 or two more functions
than I could see using. I also liked the rotating ability because the
most comfortable position is far from straight ahead as someone else has
noted. Rotating is even better and the Tosten does that very well.
After 2 years of flying I use the mic button and trim hat all the
time. But since the AP is normally connected, I use the the AP disco
100% and the Transponder ident 50% of the time. Don't use the flip flop
at all. Can't think of another function I would actually use if on the
stick.
Bill "only slightly embarrassed as I look at my taped up stick move all
by itself" Watson
On 7/21/2013 7:37 PM, Bob Turner wrote:
Bob Turner
RV-10 QB
Posted: Mon Jul 22, 2013 10:58 am Post subject: Brain trust stick wiring poll |
On 7/22/2013 2:38 PM, Bill Watson wrote:
| Quote: | I chose the Tosten grip because the Infinity had 1 or two more
functions than I could see using. I also liked the rotating ability
because the most comfortable position is far from straight ahead as
someone else has noted. Rotating is even better and the Tosten does
that very well.
I just didn't like the looks of the Tosten, although the swivel function
was pretty neat.
flop at all. Can't think of another function I would actually use if
on the stick.
Part of the reason for my choosing the Infinity is .... I'll have
aileron and rudder trim driven by model airplane servos. Maxed out the
switches with only one momentary switch not spoke for. I figured that I
could let switches go unused Vs. adding switches later .......
One comment on running the huge number of wires .... I have all wires
running through a DB-25 that connects to a harness. The harness is 3
DB-25s, one mounted each side behind the pilot/copilot calf and one in
the center tunnel for distribution .... all in parallel. I can easily
install a switch to break the copilots ground rendering that stick inop
... just haven't found a good place to put the switch.
Linn .... through the stick.
all by itself" Watson
> Bob Turner
> RV-10 QB
hotwheels
Posted: Tue Jul 23, 2013 6:23 am Post subject: Re: Brain trust stick wiring poll |
I have Tosten grips and like them a lot. I ran the wires inside the stick (a pain) and then decided to use the Flightline stick covers. Does wiring inside or outside matter? Not much. Once you get in the plane and close the door, all you see is the panel and outside.
I did wire in DB15 connectors and am glad I did so as they've been in and out several times.
Be advised that lots of folks (me included) have had to bend the sticks to allow for adequate fwd clearance. I used a mandrel that my ME buddy made instead of a hydraulic press.
Jay
433RV - Phase 1
Posted: Tue Jul 23, 2013 7:41 am Post subject: Brain trust stick wiring poll |
Those of you that used DB15 and DB 25 connectors and ran the wires inside
the stick, I suppose that you are not able to pull the grips off without
unsoldering the DB connectors, because they don't fit through the stick,
right?
Carlos
-----Mensagem original-----
De: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Em nome de hotwheels
Enviada: 23 de julho de 2013 15:23
Para: rv10-list(at)matronics.com
Assunto: Re: Brain trust stick wiring poll
out several times.
Jay
433RV - Phase 1
http://forums.matronics.com/viewtopic.php?p=405158#405158
Posted: Tue Jul 23, 2013 8:18 am Post subject: Brain trust stick wiring poll |
There's no way to get the solder-cup connectors through the stick socket without really weakening the socket. Just drill a hole the size you need for the number of wires. I have one stick with the connector on to do testing. I'll have to pull the wires from the connector and feed them through the hole and re-insert them back into the housing .... very carefully!!!!
I'm a NASA certified solderer and have good tools but I HATE solder cup DB connectors. I changed out all my solder cup connectors for crimp-on pins.
I had to pull a lot of wires loose from my DB connectors because I can't see or can't count!!!!
Using the crimp pins also helps when you want to add a wire to a connector that's buried down in the innards where you can't solder well.
You can get connectors, shells, pins, crimper and removal tool at http://steinair.com/. No, I don't get any discount!!!
If you're replacing solder cups with crimps you can use the shells you have. I used DB connectors for all the low current cabling and Molex for the high current ones. Molex for the same reasons ... removeable and crimp. I have ratcheting crimp tools, one for lugs one for DB pins and one for molex pins. Pricey, but well worth it to make good air-tight connections. You can't go wrong using the proper tools.
Linn
On 7/23/2013 11:39 AM, Carlos Trigo wrote:
[quote] | Quote: | --> RV10-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt> (trigo(at)mail.telepac.pt)
right?
Carlos
De: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)
[mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] Em nome de hotwheels
Para: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
--> RV10-List message posted by: "hotwheels" <jaybrinkmeyer(at)yahoo.com> (jaybrinkmeyer(at)yahoo.com)
out several times.
Jay
433RV - Phase 1
| [b]
Posted: Tue Jul 23, 2013 8:37 am Post subject: Brain trust stick wiring poll |
Ok, Linn, I was not only referring to unsoldering but also to “uncrimping”.
What I meant is that, after you ran the fat blue cable inside the stick, and you install the DB connector, you will never be able to pull off the Infinity (or other) grip without cutting the wires…
Carlos
P.S. – if you would be interested in crossing the big pond and come to Europe, I could use a NASA certified solderer! I hate installing DB connectors inside the fuselage…
De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Linn Walters
Enviada: 23 de julho de 2013 17:18
Assunto: Re: Re: Brain trust stick wiring poll
Linn
| Quote: | | Quote: | | --> RV10-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt> (trigo(at)mail.telepac.pt) Those of you that used DB15 and DB 25 connectors and ran the wires insidethe stick, I suppose that you are not able to pull the grips off withoutunsoldering the DB connectors, because they don't fit through the stick,right? Carlos | 0123456789 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 0 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 1 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 2 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 3 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 4 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 5 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 6 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 7 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 8 | Quote: | | Those of you that used DB15 and DB 25 connectors and ran the wires inside | 9 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 0 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 1 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 2 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 3 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 4 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 5 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 6 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 7 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 8 | Quote: | | the stick, I suppose that you are not able to pull the grips off without | 9 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 0 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 1 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 2 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 3 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 4 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 5 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 6 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 7 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 8 | Quote: | | unsoldering the DB connectors, because they don't fit through the stick, | 90123456789012 |
3 - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] [/quote]4
tsts4
Posted: Tue Jul 23, 2013 8:58 am Post subject: Re: Brain trust stick wiring poll |
With crimped pins I don't think you'd need to cut the wires. After you extracted the pins from the D-sub connector, the diameter of the mass of freed pins would be close to that of the "blue" wire, or at least close enough to allow you to pull it all back up through the stick.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
rleffler
Posted: Tue Jul 23, 2013 9:08 am Post subject: Brain trust stick wiring poll |
You don't "un-crimp", just simply pull the pins out of the connector.
On Jul 23, 2013, at 12:35 PM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
<![endif]--> <![endif]-->
Carlos
De: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] Em nome de Linn Walters
Linn
3http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c=4
5
_________________ Bob Leffler
N410BL - Phase I
