stephenbehn(at)bigpond.co Guest
Posted: Sat Jul 20, 2013 11:52 pm Post subject: GRT Avionic |
Hi All,
I have purchased a Grand Rapid HXr system for my Lightning and am in the process of making mount brackets and positioning all the equipment. I was going to fit the AHRS/Air Data Computer under the baggage compartment but the harness supplied is only 4 feet long. I will have to build a longer harness or put it behind the instrument panel. GRT say the magnetometer should be fitted in the wing tip again not easy especially when it has to be in the same orientation as the AHRS. I would appreciate any information and photos of the positioning of these pieces of equipment in a lightning. Thanks in anticpation
Cheers
Steve Behn
Lightning 69
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27640 Location: Livermore CA USA
Posted: Sun Jul 21, 2013 9:08 am Post subject: GRT Avionic |
At 12:52 AM 7/21/2013 Sunday, you wrote:
| Quote: | Hi All,
Cheers
Steve Behn
Lightning 69
Hi Steve,
I have an RV-8, but the installation for the GRT AHRS and Magnetometers might be similar. Attached are some pictures of my GRT AHRS installation behind the panel. Works great.
I didn't want to run wires all the way out to the wing tip for the Magnetometers either so I mounted mine in the tail between the Horz and Vert stabs. Again, worked great. I'll send some pictures of that next.
Best regards,
Status: 170+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
_________________ Matt Dralle
Posted: Sun Jul 21, 2013 9:14 am Post subject: GRT Avionic |
| Quote: | Hi All,
Cheers
Steve Behn
Lightning 69
Steve,
Here are some pictures of my installation of the GRT Magnetometers in tail of RV-8...
mark(at)flylightning.net Guest
Posted: Sun Jul 21, 2013 9:17 am Post subject: GRT Avionic |
Hi Steve,
We've installed a couple of HX systems with separate AHRS and have mounted them under the baggage floor. While GRT's suggestion of mounting the magnetometer in the wing tip works for RV's it's impractical for Lightnings unless you want to make a large access cover. In the 30-40 plus GRT SX systems we've installed we've mount the magnetometers in the tail cone.
I'll see the GRT gang at Oshkosh and ask about the provided wire length for the AHRS. The wire bundle they provide for the magnetometer has always been sufficient.
Best regards,
Mark
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Stephen Behn
Sent: Sunday, July 21, 2013 2:53 AM
To: lightning-list(at)matronics.com
Subject: GRT Avionic
Hi All,
Cheers
Steve Behn
Lightning 69
| Quote: | | http://www.matronics.com/Navigator?Lightning-List | 0123456789
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
