Shrike nose
Goto page 1, 2  Next
amg(at)nc.rr.com
PostPosted: Sat Jan 14, 2006 6:38 pm    Post subject: Shrike nose Reply with quote
Hello,
Anyone know how much a Shrike nose cost, and who sells and installs them???
YOURTCFG(at)aol.com
PostPosted: Sat Jan 14, 2006 10:14 pm    Post subject: Shrike nose Reply with quote
In a message dated 1/14/2006 6:39:20 P.M. Pacific Standard Time,
amg(at)nc.rr.com writes:
About 12K for the nose. Installation is another 5 -6K Gary Gadberry, "The
Air Center" is the only source for new noses. jb
amg(at)nc.rr.com
PostPosted: Sun Jan 15, 2006 4:50 am    Post subject: Shrike nose Reply with quote
Thanks for the quick response, could use that much money for something
else more useful than looks.
Roland
n395v
PostPosted: Sun Jan 15, 2006 8:10 am    Post subject: Re: Shrike nose Reply with quote
If you are looking for speed the flap gap seals and square rudder cap mods give a lot better bang for the buck than a nose job. +/_ winglets.
The winglets are from Commander Aero the others from Air Center (Gadberry)
Milt
YOURTCFG(at)aol.com
PostPosted: Sun Jan 15, 2006 10:27 am    Post subject: Shrike nose Reply with quote
In a message dated 1/15/2006 8:11:01 A.M. Pacific Standard Time,
N395V(at)direcway.com writes:
The best speed mods are #1 Buy a good GPS, and use it. Fly everywhere "GPS
Direct" and #2 bigger gas tanks:-) jb
steve2(at)sover.net
PostPosted: Mon Jan 16, 2006 5:18 am    Post subject: Shrike nose Reply with quote
I must be in the minority prefering the snub-nose of the older Commanders to
the pointy nose of the later models......
What kind of percentage of older models get the nose-job? Sounds like a
question for Barry....
Steve
n395v
PostPosted: Mon Jan 16, 2006 5:43 am    Post subject: Re: Shrike nose Reply with quote
Nope. I suspect most of us prefer that classic buxom look. Very Happy
N295V
 Filesize:  32.99 KB
 Viewed:  2401 Time(s)
Milt
barry.collman(at)air-brit
PostPosted: Mon Jan 16, 2006 5:48 am    Post subject: Shrike nose Reply with quote
Hi Steve,
Well, it is indeed a question for me!
I have traced about 270 of the Bathtub and Speedline nacelle Models that have
been modified with the installation of a Miller nose.
There were 1,865 airframes built under the 'old' msn system, but some of these
left the factory with the long nose.
Without refining everything down to the last decimal point, the answer is
approximately 15%.
Very Best Regards,
Barry
amg(at)nc.rr.com
PostPosted: Mon Jan 16, 2006 6:25 am    Post subject: Shrike nose Reply with quote
My original question was not intended to change my model 500 from the
original nose, but to try to see if this increased the value of a
project I know of. I appreciate all the response from all of you. Gap
seals is not an option for me as I have a 2500 ft. (paved) strip of my
own, and understand this inhibits the climb performance somewhat.
Comments???
Roland
Barry Collman wrote:
Hi Steve,
approximately 15%.
Very Best Regards,
Barry
moe(at)rosspistons.com
PostPosted: Mon Jan 16, 2006 7:53 am    Post subject: Shrike nose Reply with quote
Roland,
You are most likely correct in your feelings that Flap Gap Seals are not a
good idea if you operate on a 2,500 foot strip.
Moe
YOURTCFG(at)aol.com
PostPosted: Mon Jan 16, 2006 10:56 am    Post subject: Shrike nose Reply with quote
In a message dated 1/16/2006 5:48:55 A.M. Pacific Standard Time,
barry.collman(at)air-britain.co.uk writes:
SIR BARRY.
You forgot the 6 that had the "Little Rock" nose installed;_) jb
PostPosted: Mon Jan 16, 2006 1:04 pm    Post subject: Shrike nose Reply with quote
No, no, no. I didn't forget. Just wanted to see if anyone was on the ball.!
Well done JimBob!!
Barry Wink
bowing74(at)earthlink.net
PostPosted: Mon Jan 16, 2006 2:34 pm    Post subject: Shrike nose Reply with quote
Maybe a relief tube to go with those loooong range tanks.
bilbo
BillLeff1(at)aol.com
PostPosted: Mon Jan 16, 2006 5:35 pm    Post subject: Shrike nose Reply with quote
Flap gap seals actually improve takeoff performance even though they close
off the gap somewhat.
Bill Leff
YOURTCFG(at)AOL.COM
PostPosted: Mon Jan 16, 2006 6:19 pm    Post subject: Shrike nose Reply with quote
In a message dated 1/16/2006 5:36:24 P.M. Pacific Standard Time,
BillLeff1(at)aol.com writes:
That is not true:-) I have empirical knowledge of this. I operated from a
very short (1600) strip at 2500 ft above sea level. After installing the gap
seals, the TO (and landing) performance suffered noticeably. In fact, I was
so disappointed that I never painted the gap seals, wondering if I might
remove them. They do however give the advertised increase in speed. If you
always fly from a long (3000 ft) I recommend them. jb
tylor.hall(at)sbcglobal.n
PostPosted: Mon Jan 16, 2006 7:07 pm    Post subject: Shrike nose Reply with quote
Has anyone tried to add Vortex Generators on a field approval?
There is one 500B that has them on it and I was told that they were a
great help in lowering approach speeds and lower single engine
control speed. They were installed on a one time STC.
Sir Berry can tell us who has them.
Tylor Hall
they close
operated from a
installing the gap
fact, I was
might
speed. If you
PostPosted: Tue Jan 17, 2006 3:30 am    Post subject: Shrike nose Reply with quote
Hi Tylor,
No, I can't! Vortex Generators is an item I don't track. I do recall seeing a
few Forms 337 for their installation, but to find them again.........
Best Regards,
Barry
amg(at)nc.rr.com
PostPosted: Tue Jan 17, 2006 4:31 am    Post subject: Shrike nose Reply with quote
Hello all,
Try landshorter.com.
Roland
Hi Tylor,
Best Regards,
Barry
Jerry Sprayberry
PostPosted: Tue Jan 17, 2006 6:53 am    Post subject: Shrike nose Reply with quote
I hate to get into this one, However, I have Pictures of N198JW 50FT. in the
air, 1000FT from start of take-off from my 1900 FT grass strip 800 Ft
Elevation. I can't complain about that performance.
My Two Cent's worth JRS.
Capn Spray
bertberry1(at)aol.com
PostPosted: Tue Jan 17, 2006 7:02 am    Post subject: Shrike nose Reply with quote
Hey JB,
Maybe the magic doesn't work until you paint them.
Bert
Goto page 1, 2  Next
Page 1 of 2
