jonlaury
Posted: Thu Jul 11, 2013 8:01 am Post subject: Battery Cap Tester |
Last October, when I left my Pitot heater on overnight, my PC680 got pulled down to 7.5v and I mentioned the event in another post. At that time, you said you were building a batt cap tester to sell on the AEC.
Is it about to launch?
After charging, I've noticed that my PC680 drains from 13 to 11.6v over two weeks of sitting. My car battery doesn't drain that much even with phantom loads of the ECU, clock and anything else that I'm not aware of. So I was going to fab a poorman's cap checker unless you've got something that will save me the trouble.
klehman(at)albedo.net Guest
Posted: Fri Jul 12, 2013 3:22 am Post subject: Battery Cap Tester |
I believe HobbyKing sells a $20. ish dollar device that will integrate
whatever discharge you choose to put on the battery.
Ken
On 11/07/2013 12:01 PM, jonlaury wrote:
Posted: Fri Jul 12, 2013 6:45 am Post subject: Battery Cap Tester |
At 11:01 AM 7/11/2013, you wrote:
Hi John,
Funny you should mention that. I've been on an archeological
dig on the workbench and uncovered a nicely fabricated
po' boy's cap checker sent to me for troubleshooting.
It was receipt of that project that launched the software
based timer/cap-checker project. Paul got the software up
to a beta release state. It goes on the same ECB as the
uC based wig-wag controller. I need to stuff a board,
program a chip and see if it all comes together.
Sounds like you're needs are pretty immediate. Just the
pitot heater? Sounds like the the master was left on
and more 'stuff' than pitot heater was loading the
battery. In any case, an over-night load of that magnitude
certainly extracted 99%+ of the battery's contained energy.
How old was the battery when this event occured?
What are you using to charge the battery? Is it a smart
charger with a bulk/top-off/sustain profile?
This accelerated self-discharge doesn't sound good
but it MIGHT be that your charger isn't topping
the battery off. Does it still crank the engine?
Have you conducted a cranking load test (how many
amps delivered after 15 seconds loaded down to
9 volts)?
If it's still cranking the engine, then the battery
should top off in flight with a bus of 14.4 to 14.6
volts. But if the OCV drops that fast, then it's
almost a certainty that the battery is crippled.
I've moved the po' boy's battery cap checker to
the front of the bench but its going to be awhile
before it's in a practical state of utility for
you. If you're flying this battery, you need some
faster data. Clip a 55w head-lamp bulb across the
battery and come back in 2 hours to check the
voltage.
http://tinyurl.com/kgkxw3l
If it's not at 11.0 volts or above, the battery
is toast.
Another reader suggested this battery test fixture
from Hobby King . . .
http://tinyurl.com/q2sv4xl
It's designed to test an array of li-ion cells in
a model . . . not well suited to your task and is
certainly not outfitted to load your battery in
concert with your endurance loads. Further, reviews
of this device are in the toilet.
Posted: Fri Jul 12, 2013 7:57 am Post subject: Battery Cap Tester |
this is the hobbyking item I was thinking of.
Up to 60 volts and 130 amps.
http://www.hobbyking.com/hobbyking/store/__10080__turnigy_130a_watt_meter_and_power_analyzer.html
Ken
<nuckolls.bob(at)aeroelectric.com>
<jonlaury(at)impulse.net>
| Quote: | >
>Bob,
the AEC.
| Quote: | >
Hi John,
9 volts)?
voltage.
is toast.
rparigoris
Posted: Fri Jul 12, 2013 8:04 am Post subject: Battery Cap Tester |
Hi Group
Here's one slick tool that no home should be without:
http://www.hobbyking.com/hobbyking/store/__10080__Turnigy_130A_Watt_Meter_and_Power_Analyzer.html
You can keep it alive with an aux battery if required. I use a 4 AA holder from Rat Shack that has a built in switch.
You can data log watts in or out. I have used it to charge and measure capacity of batteries ranging from a 50mA NiMh to 4 in series 200 amp lead acid deep discharge.
The above is OK quality, but not as nice as Astroflight Whatt Meters:
http://www.astroflight.com/electronics/watt-meters.html
It's whatt, not watt meter.
Hobby King thus far has been OK to deal with. If they show 0 in stock, you have to wait before they will ship until they do another run. That's the way they operate, they get orders, then build. You can go on their site and put something on a wishlist, then when they make a production run you will get an E-Mail they have stock. Shipping, their cheap kind is cheap, but slow (OK by me most of the time). I think they offer other modes of shipping.
Or buy a Whattmeter, they ship from USA, probably same day for a little more than double the price.
The only difference I find, is the Whatt meter is not a directional tool, run a load from a battery through the meter it will begin to accumulate watts, now begin to charge through the meter and it will accumulate watts the same. The Turnigy will only log in one direction. I tend to like the quirk of the Whatt meter.
Ron Parigoris
jonlaury
Posted: Sat Jul 13, 2013 8:02 am Post subject: Re: Battery Cap Tester |
[quote="nuckolls.bob(at)aeroelect"]At 11:01 AM 7/11/2013, you wrote:
(snip).....
9 volts)?
voltage.
is toast.
Bob . . . |
The battery was installed about 4-5 months before the pitot drain down occurred. It was being maintained by a Schumacher XC-10, set for 'Gel cell' per Schumacher recommendation after 'AGM' setting was pushing over the Odyssey max voltage of 15.5v.
When the battery is topped off at about 13.5 volts, it readily spins the 6cyl, 350 ci Franklin with 10.5 : 1 compression through about 4, 5-7 sec start attempts before getting tired and at rest voltage starts sagging.
Yesterday, after 24 hours on the XC-10, votage was at 14.67v.
After disconnect and about 1.5 hrs, it was at 14.04v.
I'll check it todayand I'll do the lamp test across the terminals too, and report.
Posted: Sat Jul 13, 2013 8:30 am Post subject: Battery Cap Tester |
Yesterday, after 24 hours on the XC-10, votage was at 14.67v. After disconnect and about 1.5 hrs, it was at 14.04v.
That's not a 'bad' value. There is a period of time
after charger disconnect until the battery terminal
voltage falls to its nominal resting value. There
are small variations between lead-acid technologies
but they'll generally fall into this range of values.
[img]cid:.0[/img]
These values are accurate only after a considerable 'resting
interval' for removal of either a charger or a load . . .
a 6-hour rest before measurement is probably reasonable.
The fact that it will deliver 4 cranking cycles suggests
that the battery is not seriously degraded . . . but a new
we tested a new 18 a.h. battery on a high compression
competition engine at 6 or 7 robust start cycles.
Sounds like your battery is wounded but still serviceable.
The self-discharge rate seems excessive . . . a reasonable
hypothesis is that it's a symptom of the 'wounding'. Unless
your design goals dictate that the battery support a
e-bus for several hours, this battery may service your needs
for some time.
| Quote: | | I'll check it todayand I'll do the lamp test across the terminals too, and report. |
Good move. Have you established an endurance load requirement
for how you use your airplane?
40.69 KB |
25541 Time(s) |
Posted: Sat Jul 13, 2013 2:07 pm Post subject: Battery Cap Tester |
Hi John,
> po' boy's cap checker sent to me for troubleshooting . . .
Made a few drill chips this afternoon and got all the
hardware mounted on the proof of concept Bat Cap Checker.
[img]cid:.0[/img]
[img]cid:.1[/img]
All the holes have been plugged with screws. It's
time to stuff the board and wire it up.
This version is configured to run a battery down using
the chosen load . . . in this case 3x55w lamps.
When the test terminates, the lights will go out,
the relay will drop and connect a charger to the
battery for replenishment. Touching meter leads
to BAT- and MTR+ will yield a voltage reading
between 0 and 5 volts. 5 volts = 5 hours of
endurance.
73.74 KB |
25536 Time(s) |
74.29 KB |
25536 Time(s) |
billp(at)wwpc.com Guest
Posted: Sat Jul 13, 2013 2:44 pm Post subject: Battery Cap Tester |
jonlaury
Posted: Sun Jul 14, 2013 8:21 am Post subject: Re: Battery Cap Tester |
| nuckolls.bob(at)aeroelect wrote: | Bob,
...snip
[img]cid:.0[/img]
for some time.
Bob . . . |
2 hour 75 watt (parts on hand) load result:
Begin test voltage: 13.6 (down .44 from previous day)
End test voltage , lamp connected: 12.4v
After 2 hour rest: 12.97v
All-electric airplane 97% VFR
Electrical power: 60a alt, 40a stby alt, 18ah PC 680
Minimum electrical load at 75% power = 15.5a (load decreases slightly at lower power setting) EFI 3.5a, 1 Ignition 2.5a, 1 pump 7a, EFIS 1a, Xpdr 1.5a
Posted: Sun Jul 14, 2013 11:17 am Post subject: Battery Cap Tester |
Sounds like your battery's capacity is not seriously
hurt.
With dual power sources I think the risks
for continued use of this battery are low.
I'm at a loss to explain your observation of
accelerated self-discharge.
Posted: Sun Jul 14, 2013 3:21 pm Post subject: Battery Cap Tester |
Hmmmm . . . according to data right from the horse's
mouth, a 75 watt load on a new PC680 should take
it down to 10.00 volts in about 2.2 hours. This corresponds
to a current of about 9A.
[img]cid:.0[/img]
I'm pretty sure that Watts and Amps are CONSTANT values applied
by a 'smart' load . . . which resistors and lamps can only approximate.
Nonetheless, the fact that you were still above 12.4 volts after two hours
raises some questions. At first blush it appears your battery
is in REALLY good shape.
174.12 KB |
25512 Time(s) |
jonlaury
Posted: Mon Jul 15, 2013 8:50 am Post subject: Battery Cap Tester |
At 10:53 AM 7/15/2013, you wrote:
I'll try it again to see if I get something different.
Why is it that Odyssey comes up with a 9 amp load (at) 12v making 75W?
I thought you could take to the bank the relationship of volts, amps
and watts. 9 amps x 12v should be 108W in my perfect world.
EXCELLENT QUESTION! I'll try to study it
further and see if I can deduce their
methodology. Discharging the battery at
constant watts and constant amps for a
non-linear event will produce some disparity
of values . . . but I can't see that it
would be that big.
Posted: Mon Jul 15, 2013 9:28 am Post subject: Battery Cap Tester |
--> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
I thought you could take to the bank the relationship of volts, amps and watts. 9 amps x 12v should be 108W in my perfect world.
Here's an excerpt on PC680 data from another Hawker-Enersys
document . . .
[img]cid:7.1.0.9.0.20130715121715.020f01f8(at)aeroelectric.com.0[/img]
. . . and the companion plot
[img]cid:7.1.0.9.0.20130715121715.020f01f8(at)aeroelectric.com.1[/img]
This plot is consistent with tabular data and with your
test results. I must conclude that the earlier posting was excerpted
from erroneous data.
The fact remains that your battery seems to be in good shape . . .
which still leaves us with questions about the observed self-discharge
rate.
231.72 KB |
25494 Time(s) |
109.45 KB |
25494 Time(s) |
jonlaury
Posted: Mon Jul 22, 2013 4:22 pm Post subject: Re: Battery Cap Tester |
| nuckolls.bob(at)aeroelect wrote: | --> AeroElectric-List message posted by: "jonlaury" <jonlaury>
Bob . . . |
After a night on the charger and a few hours rest, started at 13.0 volts and after 2 hours of 75 watt draw, disconnected lamp and measured 12.0
The relatively high day to day discharge turns out to be attributable to having left my pilot side NC headset (battery bus) on. The LED indicator was facing the seat back.
Posted: Tue Jul 23, 2013 7:53 am Post subject: Battery Cap Tester |
| Quote: | After a night on the charger and a few hours rest, started at 13.0
Aha! A credible explanation. Good work!
