Albert Gardner
Posted: Fri Jul 12, 2013 11:51 am Post subject: USB Charger Adapter |
I installed a cigarette lighter outlet (now called courtesy outlet in my car
owners manual) but all we use it for is to plug in an adapter with USB
outlets in it. I'm thinking of replacing it with some USB ports mounted on
the panel. I haven't found a device that mounts directly to the panel like
the cig lighter outlet did but did find a 4 USB port adapter. Has anyone
else run across what I'm looking for? I'm thinking 4 ports because now I
plug in the Stratus, iPad, cell phone or music player. Here is a pic of the
4 port I found on the internet.
Albert Gardner
N991RV
Yuma, AZ
BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as
Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel,
just me and about 77 temp as I recall, plane preformed well. Wonder how it
would have been a gross?
2.63 KB |
15761 Time(s) |
_________________ RV-9A N872RV
RV-10 N991RV |
Tim Olson
Posted: Fri Jul 12, 2013 12:07 pm Post subject: USB Charger Adapter |
I have 2 subpanel mounted lighter outlets. I use 1 of them with a charger,
a Dual Scosche brand charger, to run two panel mount USB jacks (you
can get those from SteinAir), for charging the ipad and phone.
My advice is....
A) Don't buy that 4-port 1.
B) Buy something name brand. You don't want some cheap chinese knockoff
burning up your plane...I've bought a bunch of chinese USB chargers and
had high failure rates. So I stick with Scosche brand. They've
never went
bad on me at least.
C) Buy chargers specifically that are capable of 2.1A charging, so that you
can charge an iPad. Many are 500mA, 700mA, or 1A. The 1A will
do a phone fine, but not an iPad. I have a great Scosche that does 1A
and 2.1A. I just bought (before OSH) a new mini model scosche that
does dual 2.1A.
D) Find a way to make the connection snug so the thing doesn't slip
out easily...especially if you buy a larger one. The new Mini ones
I bought are going to go into the plane, since they're tiny and
light and low profile.
But beyond that, yeah, USB charging is great. If you really need 4
ports, I'd say do 2 lighter outlets.....because you'll never find a
good 4-port charger that can do 2.1A...at least not yet this year.
I also have 1A chargers in the rear seat, one for each passenger.
The lighter outlets are under the armwrests. They are part of the
Belkin bluetooth adapters that the kids use. That gives us
4 USB ports in the plane to charge with, and I still have the
ability to add 2 more up front if I need, since I have an available
lighter outlet.
On 7/12/2013 2:50 PM, Albert Gardner wrote:
| Quote: | I installed a cigarette lighter outlet (now called courtesy outlet in my car
Albert Gardner
N991RV
Yuma, AZ
Posted: Fri Jul 12, 2013 12:16 pm Post subject: USB Charger Adapter |
There are lots of USB panel mount adapters out there (Google or Bing usb panel mount) but you still need to drop the 12V down to the nominal 5V. Your 4-port adapter is a really good solution ..... and it's portable.
Linn
On 7/12/2013 3:50 PM, Albert Gardner wrote:
[quote] | Quote: | I installed a cigarette lighter outlet (now called courtesy outlet in my car
Albert Gardner
N991RV
Yuma, AZ
| Quote: | -----
Checked by AVG - www.avg.com
| [b]
sean(at)braunandco.com Guest
Posted: Fri Jul 12, 2013 12:29 pm Post subject: USB Charger Adapter |
Aspen topic,
I did Aspen a couple weeks ago in my RV10 at 2600 lbs and 10700 DA. It
performed well. I did the VFR departure of 360 degree heading at threshold
for at least two miles then turned left early per tower''s request and
cleared the mountains to the SE. I always underestimate the airplane ,
which is a good thing I guess. Short takeoff in calm winds but helps with a
2% slope down!
Posted: Fri Jul 12, 2013 12:33 pm Post subject: USB Charger Adapter |
I agree with Tim on all comments. I have however been very pleased with these adapters I picked up on eBay. I think I have purchased about 15 so far. They are ultra-low profile and are very snug in the receptacle. They charge iPhone &iPads. NOTE" some of these two socket chargers are "sided" in that one side will charge 2.1A and the other will only charge 1A.
http://www.ebay.com/itm/281027829654?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I also liked my 12V Honda outlet with a spring loaded square cover so much I ordered them from the dealership and stuck them in a number of places in the -10 including the back bulkhead in case I had some device I wanted charging back there. I have yet to use that plug but the others have worked out as planned. Sorry no photos.
Robin
jeff(at)westcottpress.com Guest
Posted: Fri Jul 12, 2013 1:36 pm Post subject: USB Charger Adapter |
Stein is now making panel mount usb outlets... I believe mine are somewhere here in this very expensive box of goodies.
Jeff Carpeter
40304
Albert Gardner
N991RV
Yuma, AZ
<USB Car Charger.jpg>
Posted: Fri Jul 12, 2013 1:40 pm Post subject: USB Charger Adapter |
Here are a couple of pics
Albert Gardner
N991RV
Yuma, AZ
119.04 KB |
15278 Time(s) |
134.07 KB |
15278 Time(s) |
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Fri Jul 12, 2013 1:55 pm Post subject: USB Charger Adapter |
His site describes this as 1.5A, which I do not think is enough to charge an
iPad.
rv10flyer(at)live.com Guest
Posted: Fri Jul 12, 2013 3:02 pm Post subject: USB Charger Adapter |
with a 2a fuse, as seen in the picture, I guarantee it would not work on an
Ipad.
stein(at)steinair.com Guest
Posted: Fri Jul 12, 2013 3:11 pm Post subject: USB Charger Adapter |
They are 2A units, but experience and lots of testing has shown us that the
real world usable output of these things is closer to 1.6-1.8 instead of 2.1
when plugged into a running iPad. That means that if you have a regular
iPad up and running something like Foreflight along with Bluetooth, gps and
music going then this will just keep a float on it and not charge
aggressively...but if you shut off the intensive apps or it's resting then
it charges it just fine. It'll also charge an iPad mini in all conditions
(apps running or not). We spent a whole lot of time testing these out on
the bench and in the planes and I wouldn't sell something based on just
magazine info...you can find plenty of those out there that in fact don't
perform in the real world as advertised. Anyway, it's the best that can
easily be done in a reasonable price point and will cover a large majority
of what it's intended to do; so as usual I'd rather under promise and over
deliver instead of the other way around.
Just my 2 cents as usual!
Stein Bruch
President - SteinAir, Inc.
651-460-6955
Posted: Fri Jul 12, 2013 3:40 pm Post subject: USB Charger Adapter |
Remember, that's 2A at 12V, which is 24W. The output needs to be close to 2.1A at 5V, which is 10.5W. Even with heat loss, that should work fine.
Do not archive.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Jul 12, 2013, at 7:01 PM, "Pascal" <rv10flyer(at)live.com> wrote:
with a 2a fuse, as seen in the picture, I guarantee it would not work on an Ipad.
wgreenley
Posted: Fri Jul 12, 2013 4:04 pm Post subject: USB Charger Adapter |
Thanks, good reminder to do the math. See you at Oshkosh.
Bill Greenley
wwc4(at)njit.edu Guest
Posted: Fri Jul 12, 2013 5:16 pm Post subject: USB Charger Adapter |
billz
Joined: 08 Jul 2009 Posts: 26 Location: Clinton, New York
Posted: Fri Jul 12, 2013 6:39 pm Post subject: USB Charger Adapter |
We usually buy a stock of stuff from cellphoneshop.net because we move around so much between planes that we tend to lose. I have ended up buying a couple of good ones and not losing them for a period of time. I really like the ones that sit almost flush with the face of the lighter plug.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Jul 12, 2013, at 10:15 PM, "billz" <billz(at)roadrunner.com> wrote:
rv10rob(at)gmail.com Guest
Posted: Fri Jul 12, 2013 7:06 pm Post subject: USB Charger Adapter |
Nice thing about using a panel-mounted cigarette lighter and a USB adapter, rather than a panel-mounted USB adapter, is if the USB part breaks, you just pop it out and put another one in.
-Rob
On Fri, Jul 12, 2013 at 6:36 PM, Pascal <rv10flyer(at)live.com (rv10flyer(at)live.com)> wrote:
[quote]--> RV10-List message posted by: "Pascal" <rv10flyer(at)live.com (rv10flyer(at)live.com)>
If you say it works I would never bet against that based on your history! My history has never seen my ipad work on a outlet with a 2a fuse however. You have always been different Stein. So no! I wont bet against you and your word..ever. a losing proposal!
Thanks for trying however!!
Pascal
flysrv10(at)gmail.com Guest
Posted: Sat Jul 13, 2013 2:41 am Post subject: USB Charger Adapter |
Albert,
Here is a product on Amazon that I have installed in my plane. It has 2 USBs and it is a very clean installation. It does gradually charge the ipad in flight with the display set on bright.
http://www.amazon.com/gp/product/B0082CXEI8/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
On Jul 12, 2013, at 3:50 PM, Albert Gardner <ibspud(at)roadrunner.com> wrote:
Albert Gardner
N991RV
Yuma, AZ
Albert Gardner
Posted: Sat Jul 13, 2013 6:38 am Post subject: USB Charger Adapter |
Rob: Do you know if both outlets are 2.1 amp or just one of them like many I
see. The description says "Max. Output Current: 2.1A" so I guess that means
both the iPad and the Stratus can't be charging at the same time. But I like
this idea and Monday I'm calling Stein concerning his offering as well.
Maybe install 1 or 2 of his and keep my cigarette lighter for an adaptor if
needed.
Albert Gardner
RV-10 N991RV |
