jeff(at)westcottpress.com Guest
Posted: Mon Jul 08, 2013 11:51 am Post subject: Safety Wire for Plane-Power Alternator Installation |
Does anyone have pics of their safety wiring the tension arm bolts? The distance between them seems a bit much to tie one to the other.
Jeff Carpenter
40304
kdbelue(at)charter.net Guest
Posted: Mon Jul 08, 2013 11:55 am Post subject: Safety Wire for Plane-Power Alternator Installation |
Safety wire the bolt to the arm....
On Jul 8, 2013, at 2:51 PM, Jeff Carpenter <jeff(at)westcottpress.com> wrote:
Jeff Carpenter
40304
tsts4
Posted: Mon Jul 08, 2013 1:50 pm Post subject: Re: Safety Wire for Plane-Power Alternator Installation |
Ran into the same issue a few months back. Just drill some small holes into the tension arm and run the safety wire from the bolt to the hole and tie it off.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Kelly McMullen
Posted: Mon Jul 08, 2013 7:25 pm Post subject: Safety Wire for Plane-Power Alternator Installation |
While it may be "okay" to drill a hole, there is no need to. You can easily safety directly to the arm. That is done all the time on certified aircraft.
On Mon, Jul 8, 2013 at 2:50 PM, tsts4 <tsts4(at)verizon.net (tsts4(at)verizon.net)> wrote:
| Quote: | --> RV10-List message posted by: "tsts4" <tsts4(at)verizon.net (tsts4(at)verizon.net)>
Todd Stovall
aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace
RV-10 N728TT
Empacone, Wings, Fuse, Finishing
www.mykitlog.com/auburntsts
http://forums.matronics.com/viewtopic.php?p=404239#404239
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
dhmoose
Posted: Sun Jul 14, 2013 7:46 am Post subject: Re: Safety Wire for Plane-Power Alternator Installation |
I re-read AC43.13 and didn't find any mention of a limit to the length of safety wire that can be used. I simply brought the wire from bolt to bolt in a typical arrangement and the span looks to be about 3". Is this a problem? Seems ok to me.
_________________ David Halmos
RV-10
Flying!
Portland, OR |
flying-nut(at)cfl.rr.com Guest
Posted: Sun Jul 14, 2013 7:57 am Post subject: Safety Wire for Plane-Power Alternator Installation |
There's no doubt that shorter is better. The longer the span the
'potential' for loosening becomes greater.
So, ask yourself what the consequences of that (those) particular
fasteners loosening a little.
This could be an 'experiment' so get back to us ......
IMHO, of course.
Linn
On 7/14/2013 11:46 AM, dhmoose wrote:
David Halmos
RV-10
Electrical/avionics
Portland, OR
http://forums.matronics.com/viewtopic.php?p=404667#404667
Checked by AVG - www.avg.com
dhmoose
Posted: Sun Jul 14, 2013 8:38 am Post subject: Re: Safety Wire for Plane-Power Alternator Installation |
I suspect, in my experiment, I'll get a "backup alternator" light illumination on my panel. I'll then fly on or land...and adjust the belt tension when back on the ground. I'll then recall this thread, enjoy a good chuckle... and press on.
Or... I'll re-safety it now prior to first flight. Haha.
| flying-nut(at)cfl.rr.com wrote: | There's no doubt that shorter is better. The longer the span the
IMHO, of course.
Linn
David Halmos
RV-10
Electrical/avionics
Portland, OR
RV-10
Flying!
Portland, OR |
