zackrv8(at)verizon.net Guest
Posted: Fri Jan 13, 2006 7:59 am Post subject: Trim Tab Cable Anchor Bracket |
Guys,
Dave made up some anchor brackets out of 6061 aluminum billet. He copied the exact angle of Vans W-415 weldment (you know the part with the "tack welded" nut). Well, I installed the new aluminum bracket onto the elevator yesterday and it wouldn't fit real nice. Let me explain....The new bracket was drilled exactly where Vans says to put his w-415. After installing the trim tab cable to the trim tab and routing the cable thru the forward elevator spar, the trim tab access cover would not nest in its recess in the elevator without undue force. The angle of the bracket (25 degrees) made the cable bind when going thru the forward spar of the elevator.
I doubled checked this with Vans W-415 part. Same thing. Did anyone else have this problem? Anyway, Dave came out, measured the proper nut angle (15 degrees), and made a new bracket. After installing the new bracket I am happy to say there is no more binding, thru the full range of motion of the cable, while it is attached to the trim tab. This thing fits perfect.
Btw, I called Vans and talked to Gus about this. Gus's answer was to re-weld the nut at the proper angle. I told him I would have someone make up a aluminum bracket from billet. He said that would be best.
Anyway, I caught this in time and Dave will send out all the brackets to those who already ordered from Dave, with this new 15 degree nut angle. He just has to make up new ones.
Zack
Dick Sipp
Posted: Sat Jan 14, 2006 5:58 pm Post subject: Trim Tab Cable Anchor Bracket |
Zack:
Please re-post Dave's contact info for ordering.
Dick Sipp
40065
do not achieve
zackrv8
Posted: Sat Jan 14, 2006 7:42 pm Post subject: Re: Trim Tab Cable Anchor Bracket |
Contact Dave at 302-437-6087. He made up a bunch of Trim Tab Cable Anchor Brackets with the new 15 degree angle. Again, this bracket is CNC milled from 6061 billet. Dave said it is 3 times stronger than Vans' part.
Zack
[quote="Dick Sipp"]Zack:
Dick Sipp
40065
do not achieve
_________________ RV8 #80125
RV10 # 40512 |
rv10(at)tpg.com.au Guest
Posted: Sat Jan 14, 2006 8:43 pm Post subject: Trim Tab Cable Anchor Bracket |
G'day,
Any ordering options for those of us in other countries?
Scott Lewis
RV-10 40172
Adelaide, South Australia
zackrv8 wrote:
Zack
Dick Sipp
40065
do not achieve
zackrv8
Posted: Sun Jan 15, 2006 5:11 pm Post subject: Re: Trim Tab Cable Anchor Bracket |
Scott,
G'Day mate! Dave is working on PayPal. Hopefully, he'll have it up on his web site soon. www.rivethead-aero.com
I enclosed a picture of the bracket riveted onto the trim tab cover plate.
Zack
[quote="rv10(at)tpg.com.au"]G'day,
Scott Lewis
RV-10 40172
zackrv8 wrote:
Zack
| Dick Sipp wrote: | Zack:
Dick Sipp
40065
do not achieve
| Trim Tab Cable Anchor Bracket. |
34.84 KB |
1205 Time(s) |
RV10 # 40512 |
william(at)gbta.net Guest
Posted: Sun Jan 15, 2006 7:28 pm Post subject: Trim Tab Cable Anchor Bracket |
Zack, will we need to order new cover plates if we've already got holes
drilled for the stock pieces???
Bill Britton
zackrv8
Posted: Mon Jan 16, 2006 5:42 am Post subject: Re: Trim Tab Cable Anchor Bracket |
| william(at)gbta.net wrote: | Zack, will we need to order new cover plates if we've already got holes
Bill Britton
Bill, Yes. The new bracket is wider than Van's W-412 and the hole pattern is wider.
RV10 # 40512 |
