G-IRON flies
nigel_graham(at)m-tecque.
PostPosted: Sun Jul 07, 2013 11:42 pm    Post subject: G-IRON flies Reply with quote
On Saturday, 914 powered XS, G-IRON took to the sky for the first time following a major rebuild in the capable hands of owner Terry Clark.
In blistering sunshine and slack wind, G-IRON left the Fairoaks runway at 14.30 for a faultless one-hour sortie.
The second flight with your trusty scribe onboard to log flight parameters lasted one hour and forty minutes.
The plane is beautifully balanced and flies hands-off straight and level. G-IRON has been built to a very high standard by Terry and Ian Rickard and is a credit to them both (pictured below).
Nigel
[img]cid:part1.07020204.02090206(at)m-tecque.co.uk[/img] Normal 0 <![endif]--> Normal 0 <![endif]--> <![endif]--> <![endif]-->
 Filesize:  816.13 KB
 Viewed:  1214 Time(s)
rlborger(at)mac.com
PostPosted: Mon Jul 08, 2013 6:11 am    Post subject: G-IRON flies Reply with quote
Good work guys!
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Jul 8, 2013, at 2:41 AM, nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk) wrote:
Nigel
mp.gamble(at)talktalk.net
PostPosted: Mon Jul 08, 2013 6:36 am    Post subject: G-IRON flies Reply with quote
Great news Ian and Terry. Looks like you’ve built another good ‘un.
Look forward to seeing you both around.
Well done and look after this one!
