Posted: Mon Jul 01, 2013 12:00 pm Post subject: Nose gear leg repair using taper pin |
Folks,
| Quote: | From the archives, I have retrieved a number of postings on replacing the AN5-20A bolt/assembly with a taper pin.
That process involves the pin going in from the bottom - requiring separating the engine mount from the airframe.
Has anyone performed this repair from the top-down? This looks like it could be done with the engine mount still attached. I don't recall the engine-mount weldment configuration - that may dictate the direction of the taper pin.
I have a barely perceptible movement in my nose gear leg and I want to get it fixed before it gets worse. Acknowledging I am at a less than smooth grass field which is a contributing factor - this may only be a temporary fix.
Ralph Capen
RV6A N822AR (at) N06 190hrs
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
