carb synch hose sizes
JohnE
PostPosted: Tue Jun 25, 2013 2:38 pm    Post subject: carb synch hose sizes Reply with quote
I'm going to synch my carbs. Does anyone know what size hoses are used to hook into the manifold pressure port? I have a digital manometer (dual) that I'm planning on using. I figure I can get hoses for testing at an auto supply store. The manometer connects to 1/4 inch npt btw. I figure I'll need to get some sort of reducer as well. thanks. John
Roger Lee
PostPosted: Tue Jun 25, 2013 3:03 pm    Post subject: Re: carb synch hose sizes Reply with quote
Hi John,
I just use vacuum hoses from the auto parts store. Then adapt that to the size you need with a fitting from the hardware store.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
JohnE
PostPosted: Tue Jun 25, 2013 5:10 pm    Post subject: Re: carb synch hose sizes Reply with quote
Roger Lee wrote:
Hi John,
Thanks for the reply. That's what I am planning on doing. You don't by chance know what size hose to buy? (saves me a trip to the airport, the auto parts store is close to my house)
Roger Lee
PostPosted: Wed Jun 26, 2013 6:12 am    Post subject: Re: carb synch hose sizes Reply with quote
They are the small ones. I think around 1/4" OD and maybe 1/8" or less ID. The hole size should be small and the smaller the better. We don't care about volume just the vacuum. The larger hole sizes will just give you more needle fluctuation to dampen out. I would put a an adjustable needle valve inline on both vacuum lines so you can dampen any gauge needle fluctuation. I'm still old school in on my connection at the cross over. I just pull off the left side of the cross over tube rubber end. Then I know the carbs are separated and not leaking verses if I just pinch off the rubber between carbs. I then just use a barbed fitting and up-size to the hose end I need on the 90 degree fitting (3/8" poly hose) off the top of the manifold and a smooth shank fitting that goes into the rubber end on the cross over tube. (smooth shank= I took a barbed 3/8" barbed fitting and sanded off the barbs)
You can certainly use the manifold port screws that are on top of the manifolds to make the connection, but then you still have to separate the carbs by pinching off the cross over tube rubber hose.
Roger Lee
Tucson, Az.
Cell 520-349-7056
Roger Lee
PostPosted: Wed Jun 26, 2013 11:21 am    Post subject: Re: carb synch hose sizes Reply with quote
Here's an older picture, but it gets the point across and this works very well. I would use regular vacuum lines and not the clear plastic. The plastic does work.
 Filesize:  120.66 KB
 Viewed:  9296 Time(s)
Roger Lee
Tucson, Az.
Cell 520-349-7056
JohnE
PostPosted: Wed Jun 26, 2013 3:57 pm    Post subject: Re: carb synch hose sizes Reply with quote
Thanks for the picture. Makes sense to me now. How close are you able to get the difference between the carbs? Also, do you make the adjustments to a running engine or do you shut off between adjustments?
Roger Lee
PostPosted: Thu Jun 27, 2013 5:26 am    Post subject: Re: carb synch hose sizes Reply with quote
I can get the needles dead on for idle and the high rpm settings. Once you do it a few times it doesn't take long. If you do it each annual or 100 hrs. it's a piece of cake. I always do a running engine. I wear goggles and ear muffs and I give that prop a wide berth. The wheels are always chocked and someone is in the cockpit.
Roger Lee
Tucson, Az.
Cell 520-349-7056
