Needing to find a place for a filter.
brad(at)runawaymedia.co.z
PostPosted: Tue Jun 04, 2013 8:36 am    Post subject: Needing to find a place for a filter. Reply with quote
Hello all, I have been wanting to put a filter into the oil return line for some time.  I have been looking at various places taking into consideration the heat challenges as well as access. Breaking the paradigm I thought of putting it in the front of the engine?  Great ease of access ,inspection and added cooling. Has anyone done this before?
Have at it!
Brad Banks
Sent from Samsung Mobile
 Filesize:  240.76 KB
 Viewed:  1702 Time(s)
 Filesize:  187.12 KB
richard.goode(at)russiana
PostPosted: Tue Jun 04, 2013 8:52 am    Post subject: Needing to find a place for a filter. Reply with quote
Most installations have them on the firewall, and access is perfectly good. Also hose length is as short as possible, which helps. The amount of additional cooling would be absolutely minimal when you consider the surface area of the filter compared to an oil cooler!
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel:  +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Bradly Banks
Sent: 04 June 2013 17:34
To: yak-list(at)matronics.com
Subject: Needing to find a place for a filter.
Have at it!
Brad Banks
believed to be clean.
byronmfox(at)gmail.com
PostPosted: Tue Jun 04, 2013 9:08 am    Post subject: Needing to find a place for a filter. Reply with quote
PostPosted: Tue Jun 04, 2013 9:15 am    Post subject: Needing to find a place for a filter. Reply with quote
Thank you Richard.  Im not bypassing the oil cooler. But taking oil directly from the scavenging pump port,  and piping it to the filter (25micron) then returning to the  existing hose en route to the oil cooler.
Brad
-------- Original message --------
From: Richard Goode <richard.goode(at)russianaeros.com>
Date:
Subject: RE: Yak-List: Needing to find a place for a filter.
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Subject: Yak-List: Needing to find a place for a filter.
Have at it!
Brad Banks
