Tdawson(at)avidyne.com Guest
Posted: Mon Jun 12, 2006 7:21 am Post subject: Experimental IFR w/o a certified GPS or looking for a copy |
Well, as someone else pointed out, integrity monitoring is a key feature
of IFR GPS units, so if a unit lacks that, it's a non-starter if you are
trying to match the "functional requirements" of the TSO.
Conceptually, you should be able to test the "functional requirements"
of a GPS unit without knowing the inside of it, but you will probably
need an anechoic chamber and a GPS signal simulator. You can't fly
around and compare your results to a map . . .
TDT
