Kellym
Posted: Wed May 22, 2013 6:50 pm Post subject: Electronic Ignition |
I seem to recall G3i using the term "wasted spark". I chose to get two
Bendix S-1200 mags, which is the best mag Bendix ever made(same charge
freshly overhaul as new Slick). Sure, some of the benefits of
electronics would be nice, but I don't want to do dual bus, dual
alternator or dual batteries. If 5% fuel savings is true, I save 1 gal
every 20 hours. Gonna take a lot of hours to pay for the extra expense
of EI and whatever electrical changes are needed. If Pmag ever shows up
and gets a few years of development fixing bugs after they are in the
field, I'll revisit. A friend in RV-7 with E mag and a Pmag had total
ignition loss a few hundred feet in air, just barely enough to get back
to runway. A high voltage event had damaged electronics in both mags. Be
careful with your choices, especially with dual EI.
On 5/22/2013 4:36 PM, John Cox wrote:
| Quote: | This seems the point at which the positives of EI need to be clearly
stated - balanced against their negatives. Then compared directly
with the clear positives of a magneto and its negatives. When a
reader understands the trade-offs they can better understand the
frustration with the always coming into the near future Pmag for 6
cylinders which was going to solve everything (comes to mind).
Mr. Barrett (or the lovely Ms Rhonda) could weigh in on why the high
performance engines he builds use what they do and why power output
diminishes on their dyno with one EI and one magneto. Note: a most
popular blend with the RV-10 crowd. Another question is what do S.D.
Tucker, K. Chambliss and M.Goulian bet their lives on??
Tim's input had something to do with that isolated manufacturing
incident with Slick mags a few years ago. Two Slicks with bad carbon
made for a bad day. Two EI have their own Achilles heal. As of
today, there is still no single right answer.
Lycoming has made such an advanced engine in their iE2 with knock
sensors, variable timing and redundant FADEC wiring for the Lancair
Evolution TEO-540-A1A. The additional price knocked a few willing
participants out of the evaluation and they opt for turbine.
Know your mission, choose wisely, land safely Every Time.
John Cox
On Wed, May 22, 2013 at 3:51 PM, Bob Turner <bobturner(at)alum.rpi.edu
<mailto:bobturner(at)alum.rpi.edu>> wrote:
<bobturner(at)alum.rpi.edu <mailto:bobturner(at)alum.rpi.edu>>
Linn,
Your error is in assuming that a post that starts out "we gotta
talk" is going to be rational.
The poster said, correctly, that having two ignition sources and
two propagating flame fronts helps the fuel burn more completely
within the alloted time (especially true for fixed timing mags),
and hence improves engine power and efficiency. (which is why
there is an rpm drop on runup when operating on one mag).
He also said, correctly, that if you have an EI plug with advanced
timing, that its flame front may have propagated past the second,
mag fired plug, before the mag has fired, and thus the mag is
"doing no work", to use his words.
But then he says that this is "bad". If it was bad, then the EI
guys just wouldn't advance the timing. But they do, because the
engine runs more efficiently with advanced timing under typical
cruise conditions. Even if it's only one plug that's advanced. His
arguement makes no sense. I thought maybe it was an IQ test, to
see how many people responded.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=401148#401148
le, List Admin.
Checked by AVG - www.avg.com
KCHD |
Rhonda(at)bpaengines.com Guest
Posted: Thu May 23, 2013 8:11 am Post subject: Electronic Ignition |
Here is Monty’s feedback on the issue….
EI can be “tailored” to a specific ignition advance curve whereas a magneto cannot. EI can also incorporate a retarded position for improved starting whereas a magneto requires either an impulse coupling OR some type of auxiliary spark creating device. EI can also be constructed for redundancy necessary for aircraft engines which is a requirement of certification.
Having said all of this magnetos are a very reliable ignition source. They more or less generate their own power, and if one malfunctions in West Fence Post, Wyoming on a Sunday afternoon, most local mechanics can repair it. However, with EI you will have to wait on the Brown truck.
There are other inherent problems with EI that is currently marketed. One of the biggies is that as soon as the engine is started the ignition goes to the fixed advance position which does nothing but increase the CHT. Another problem with the current crop of EIs is that for every setting of an engine there is a finite point at which peak efficiency is obtained. It is a function of where the ignition point occurs relative to crank angle in each cylinder. The requirement for proper ignition “mapping” is a good dynamometer test cell or cylinder pressure measuring equipment, which is very expensive. The proper ignition point varies with manifold pressure, RPM, mixture strength and inlet temperature. It is a very complex set of circumstances.
To further explore this subject I need to explain why the M14 EI came into life. The Russian magnetos are quite heavy, are somewhat troublesome, and parts are extremely difficult to obtain plus there is no overhaul data available. During the development of the M14 electronic ignition it was decided that no parts of the Russian ignition system were to be used. We started with a clean sheet of paper. It was also decided to thoroughly “map” the engine under all possible operating conditions for optimum ignition points. We have a test cell with that capability. All this mapping was done on a mule engine that the shop owns. The M14 electronic ignition is a dual system, i.e. it should not be operated as a one and one system. There are certain design differences that inhibit this choice. It is also a coil near plug system (18 individual coils, 1 for each sparkplug), so that a coil loss has minimal effect on the ignition system. Each controller has a built in alternator which provides power to run that specific system at engine speeds above about 450 RPM. Once the engine has been started using battery power for the ignition source the engine will keep running normally, even with the master off. During the “start mode” there are multiple sparks to ensure better starting even with cold weather starts and flooded induction system.
As far as I know Tucker, Chambliss and Goulian all use magnetos: not a bad choice when you consider the logistics involved.
Monty Barrett
BPE, Inc.
[b]Rhonda Barrett-Bewley[/b]
[i]Barrett Precision Engines[/i]
2870-B N. Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1754 fax
www.barrettprecisionengines.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Wednesday, May 22, 2013 6:36 PM
Subject: Re: Re: Electronic Ignition
This seems the point at which the positives of EI need to be clearly stated - balanced against their negatives. Then compared directly with the clear positives of a magneto and its negatives. When a reader understands the trade-offs they can better understand the frustration with the always coming into the near future Pmag for 6 cylinders which was going to solve everything (comes to mind).
Mr. Barrett (or the lovely Ms Rhonda) could weigh in on why the high performance engines he builds use what they do and why power output diminishes on their dyno with one EI and one magneto. Note: a most popular blend with the RV-10 crowd. Another question is what do S.D. Tucker, K. Chambliss and M.Goulian bet their lives on??
Tim's input had something to do with that isolated manufacturing incident with Slick mags a few years ago. Two Slicks with bad carbon made for a bad day. Two EI have their own Achilles heal. As of today, there is still no single right answer.
Lycoming has made such an advanced engine in their iE2 with knock sensors, variable timing and redundant FADEC wiring for the Lancair Evolution TEO-540-A1A. The additional price knocked a few willing participants out of the evaluation and they opt for turbine.
John Cox
On Wed, May 22, 2013 at 3:51 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Linn,
Your error is in assuming that a post that starts out "we gotta talk" is going to be rational.
The poster said, correctly, that having two ignition sources and two propagating flame fronts helps the fuel burn more completely within the alloted time (especially true for fixed timing mags), and hence improves engine power and efficiency. (which is why there is an rpm drop on runup when operating on one mag).
He also said, correctly, that if you have an EI plug with advanced timing, that its flame front may have propagated past the second, mag fired plug, before the mag has fired, and thus the mag is "doing no work", to use his words.
But then he says that this is "bad". If it was bad, then the EI guys just wouldn't advance the timing. But they do, because the engine runs more efficiently with advanced timing under typical cruise conditions. Even if it's only one plug that's advanced. His arguement makes no sense. I thought maybe it was an IQ test, to see how many people responded.
Bob Turner
RV-10 QB
le, List Admin.
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
neal.george(at)gmail.com Guest
Posted: Thu May 23, 2013 9:28 am Post subject: Electronic Ignition |
Linn -
I'm not suggesting that one plug stops firing, but that one plug becomes ineffective.
Most electronic ignition systems advance spark timing with MAP, RPM or both. Since the magneto doesn't advance, it's spark occurs late in the combustion cycle and therefore doesn't contribute appreciably to the combustion event.
Recall all the glowing reports you've read from folks after installing a single electronic ignition to replace one mag. "Went out and ran it up and got 100-RPM drop on the mag and zero drop on the EI ". Well... No kidding. The EI fires at 32- or 34-deg BTDC and the mag doesn't fire until 25- or 20-deg BTDC. For all intents and purposes, the mag is not contributing.
Neal GeorgeSent from my iPhone
On May 22, 2013, at 4:44 PM, Linn <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote] On 5/20/2013 9:35 PM, Neal George wrote:
| Quote: | | Quote: | --> RV10-List message posted by: Neal George <neal.george(at)gmail.com> (neal.george(at)gmail.com)
Tim / Robin (et al) -
We gotta talk.
Our aircraft engines DO NOT have two ignition sources for redundancy. It's required for best operation.
The combustion chamber in our opposed air-cooled engines is so big it needs to have the flame lit in multiple locations to achieve reasonable combustion in the time allotted per power stroke.
If you're running one mag and one EI, you're only running on one plug above idle. | | Pardon my ignorance and I'm a little slow so bear with me. What you infer is that one plug/cylinder quits firing??? Why??? Which one quits .... the mag or the EI???
Well, the mag doesn't quit so that leaves the EI .... which (AFAIK) doesn't quit ...... so where did you get derailed???
Linn
flying-nut(at)cfl.rr.com Guest
Posted: Thu May 23, 2013 9:41 am Post subject: Electronic Ignition |
I'm a little slow but I'm catching up.Â
Since our engines are dinosaurs, maybe we should go back and install another engine control .... like the early cars .... that changed the timing mechanically.Â
NOT!!!
Thanks for the note.
Linn
On 5/23/2013 1:28 PM, Neal George wrote:
[quote] Linn -Â
I'm not suggesting that one plug stops firing, but that one plug becomes ineffective.Â
Most electronic ignition systems advance spark timing with MAP, RPM or both. Since the magneto doesn't advance, it's spark occurs late in the combustion cycle and therefore doesn't contribute appreciably to the combustion event.Â
Recall all the glowing reports you've read from folks after installing a single electronic ignition to replace one mag. "Went out and ran it up and got 100-RPM drop on the mag and zero drop on the EI ". Well... No kidding. The EI fires at 32- or 34-deg BTDC and the mag doesn't fire until 25- or 20-deg BTDC. For all intents and purposes, the mag is not contributing.Â
Neal George Sent from my iPhone
We gotta talk.
Linn
om/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
s.com">http://forums.matronics.com
om/contribution">http://www.matronics.com/contribution
05/23/13 [b]
deej(at)deej.net Guest
Posted: Thu May 23, 2013 9:45 am Post subject: Electronic Ignition |
On 05/23/2013 01:28 PM, Neal George wrote:
| Quote: | For all intents and purposes, the mag is not
contributing.
You are absolutely correct, but I think there is a fair argument to be
made that it doesn't need to. The hotter, longer spark from the EI is
not only adequate to run the engine, it does so far more efficiently
than the mag that it replaces. There are many reports of fuel savings
from replacing just one mag with an EI, which clearly implies that the
engine is performing more efficiently running off the one EI than it did
before running off two mags.
With one EI and one mag, the mag truly is relegated to the "redundant
backup" category rather than the "necessary to have two mag-fired plugs
in order to burn all of the fuel in the cylinder head" category.
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
jdriggs49(at)msn.com Guest
Posted: Thu May 23, 2013 10:59 am Post subject: Electronic Ignition |
| Quote: | | I think D.J. summed it up nicely with this paragraph:"With one EI and one mag, the mag truly is relegated to the "redundantbackup" category rather than the "necessary to have two mag-fired plugsin order to burn all of the fuel in the cylinder head" category."If you do the research on this subject you will find that one EI system will give at least 90% of the claimed gains in fuel and power efficiency. The one mag (in a one mag one EIS system) isn't going to contribute much but it IS adding it's flame within the firing dwell time of the EIS. I would argue that it's probably more important as a backup but it does contribute to flame propagation. It seems like that every EIS company has a different way of getting spark to the cylinders. One is CDI based, another develops the spark via an induction method and another has its built in alternator to fire the plugs. It's been an interesting discussion!! |
| Quote: | Date: Thu, 23 May 2013 13:45:31 -0400
Subject: Re: RV10-List: Re: Electronic Ignition
--> RV10-List message posted by: Dj Merrill <deej(at)deej.net>
> contributing.
-Dj
Glastar Flyer N866RH - http://deej.ne======================
Posted: Thu May 23, 2013 11:48 am Post subject: Electronic Ignition |
Dj - Partial agreement.
The reported efficiencies come from advancing the spark.
The physics of the combustion chamber remain. The combustion chamber is so large and the stroke so short that two geographically separated sparks are necessary to extract maximum power from each combustion event.
Not to hijack the thread or change focus, but here's another point to consider. Timing specifics notwithstanding, our engines were tested rigorously and certificated using two synchronized sparks. (Yes, I understand that many of us are not operating in as-certificated configuration, but isn't that the basis of our safety and performance expectations?). Certification includes prop combinations and vibration analysis for structural integrity.
Changing the characteristics of combustion initiation changes the characteristics of the power stroke, which changes the vibrations and harmonic response of the engine and its individual components. Ever seen the result of a thrown counterweight?
Neal George
On May 23, 2013, at 12:45 PM, Dj Merrill <deej(at)deej.net> wrote:
> contributing.
-Dj
Kellym
I'd like to see some actual test data, rather than anecdotal reports.
Depending on the EI system the spark may be hotter, longer, maybe both,
although that is less likely. That still is NOT going to create a second
flame front, nor is the mag spark likely to create one with what little
fuel remains by the time it fires 10-15 degrees after the first spark. I
suspect most of the gain is from the advanced timing, not the quality of
the spark.
Only sophisticated test cell is going to get the kind of data needed.
On 5/23/2013 10:45 AM, Dj Merrill wrote:
| Quote: | -
KCHD |
acsjohn
Posted: Thu May 23, 2013 2:16 pm Post subject: Electronic Ignition |
Just to highlight one of Neal's points, have a look at ATSB investigation 200005572 under factual information regarding propeller failure.
It promotes a lot of thought.
John RV10 40315
http://www.atsb.gov.au/publications/investigation_reports/2000/aair/aair200005572.aspx
On Fri, May 24, 2013 at 5:47 AM, Neal George <neal.george(at)gmail.com (neal.george(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: Neal George <neal.george(at)gmail.com (neal.george(at)gmail.com)>
Neal George
On May 23, 2013, at 12:45 PM, Dj Merrill <deej(at)deej.net (deej(at)deej.net)> wrote:
> --> RV10-List message posted by: Dj Merrill <deej(at)deej.net (deej(at)deej.net)>
>> contributing.
> -Dj
le, List Admin.
Posted: Thu May 23, 2013 4:45 pm Post subject: Electronic Ignition |
On 5/23/2013 3:47 PM, Neal George wrote:
| Quote: | The reported efficiencies come from advancing the spark.
Yes, but advancing the spark also gives the fuel more time to burn,
which allows for more complete combustion versus the pair of mags, which
leads to the decrease in fuel consumption. More power is extracted from
the same amount of fuel using the EI compared to the pair of mags
because more of the fuel is being burned at the proper time.
| Quote: | The physics of the combustion chamber remain. The combustion chamber is so large and the stroke so short that two geographically separated sparks are necessary to extract maximum power from each combustion event.
Clearly a more complete combustion event happens from having one EI
and a mag installed versus having two mags installed, otherwise we would
not see a decrease in fuel burn at the same power level.
I would agree that having two EIs firing at the same time produces
the best, most efficient combustion event, followed by one EI and one
mag that is only slightly less efficient (by about 10% from reports),
followed by two mags which is the least efficient.
Real World data clearly shows that one EI and one mag is indeed
more efficient (ie, produces a more complete combustion event) than two
mags, regardless of the difference in timing.
| Quote: | Not to hijack the thread or change focus, but here's another point to consider. Timing specifics notwithstanding, our engines were tested rigorously and certificated using two synchronized sparks. (Yes, I understand that many of us are not operating in as-certificated configuration, but isn't that the basis of our safety and performance expectations?). Certification includes prop combinations and vibration analysis for structural integrity.
To be fair, the only ignition system available at the time of
certification was the mag. I highly doubt any new engine being
certificated today would use mags.
Your point about prop combinations and vibration analysis is well
taken, however.
-Dj
Kellym
Posted: Thu May 23, 2013 5:03 pm Post subject: Electronic Ignition |
You are misinterpreting your observations. Advanced timing does not
increase the burn time. In fact it likely decreases it, because the burn
starts while the mixture is still being compressed by the piston. More
power is generated by the advanced timing, not by any more complete
burning. If you advance the timing enough, you will get detonation, or
extremely fast burning. The decrease in fuel burn is simply you getting
more power for a given throttle setting, and reducing the throttle to
achieve same airspeed as before. If you advance timing and use same
throttle settings you will go slightly faster and not save any fuel. It
is a function of the percent power. Yes, you gain some efficiency IF you
throttle back, but there still is a price to pay in harmonic vibration
and the fact that you will lose power if the EI fails from loss of
battery power or any other reason, just as you lose power if one mag
fails. Two EI units WILL do better than one plus a mag. Is it as big an
improvement? Of course not. But it would be an improvement without
question. Probably in the 10-15% range.
On 5/23/2013 5:45 PM, Dj Merrill wrote:
burn, which allows for more complete combustion versus the pair of
mags, which leads to the decrease in fuel consumption. More power is
extracted from the same amount of fuel using the EI compared to the
pair of mags because more of the fuel is being burned at the proper time.
> event.
EI and a mag installed versus having two mags installed, otherwise we
would not see a decrease in fuel burn at the same power level.
two mags, regardless of the difference in timing.
taken, however.
-Dj
KCHD |
Posted: Thu May 23, 2013 5:14 pm Post subject: Electronic Ignition |
On 5/23/2013 9:03 PM, Kelly McMullen wrote:
| Quote: | Advanced timing does not increase the burn time.
That is correct, and not what I was trying to say.
Because the spark happens earlier in the cycle compared to the mag,
the fuel has more time to burn before the piston hits maximum
compression with the EI than it does with the mag. This is one reason
why it doesn't really matter that only the one spark plug of the EI is
firing versus the two simultaneous mag plugs firing.
-Dj
Posted: Thu May 23, 2013 5:26 pm Post subject: Electronic Ignition |
Just thinking out loud .....
I wonder if the increase in burn time is significant since while the EI
ignition occurs earlier the fuel is not compressed as much and the flame
front is actually slower at that ignition point. The increased
compression may cause secondary ignition by the mag ......
Just thinking ....
Linn
On 5/23/2013 9:13 PM, Dj Merrill wrote:
mag, the fuel has more time to burn before the piston hits maximum
-Dj
