Electronic Ignition
Goto page Previous  1, 2, 3, 4  Next
robin(at)PaintTheWeb.com
PostPosted: Fri May 17, 2013 4:44 pm    Post subject: Electronic Ignition Reply with quote
Jim,
I wanted to follow up to make sure you knew my post
> 56% of all statistics are either wrong or made up... including this one.<<
The "made up" part was referring to the 56% of all statistics... not your post.
It was more of a commentary of all the data we review and when one does not know the background of a "Stat" it can be meaningless or misleading. I know partially because I worked with an engineering firm that can cherry pick research data to best fit their clients' interests. We can all imagine the "expert witness". Unfortunately the courtroom is no place to dig into the nuances of predictive modeling and the like.
Back to aviation, I am more sympathetic to your argument. I absolutely want the efficiency of EI but I don't want two of them.
Excellent post.
Robin
Greg McFarlane
PostPosted: Sat May 18, 2013 3:46 am    Post subject: Re: Electronic Ignition Reply with quote
O Boy Jim talk about a can of worms. Interesting grab of the last 2 weeks of Matronics re electronic ignition, you sound just like my Mag AP. All the Spam Cans who haven't got the option of bringing ignition forward at least 80 years take it for granted, mag failure on ramp RPM drop 400 or 800 due to oiled up plugs or bad points, failure in flight, no worries, just hope we can make it home one one. We expect overhaul at 500 hours..... no worries at least we don't have to have a back up battery, What's the best starting technique? o hell we've just blown a starter cause we've had hot start issues. I think Tim's option of two bob each way (sorry a quarter each way) one EI & One Mag is best option, You get 90% of the advantage of Dual Electronic Ignition ie Optimum Timing, Easy Starting, Better fuel economy, Smooth running, Better Idle. Electronic readouts for RPM, MP & Timing Position of Ignition with Lightspeed. Wack in a Mag as an easy backup but be careful about relying on it after more than 200Hrs. Maybe the stats would be different if Klaus recommended overhauls at 500 Hours or even less because of the advantages of EI cause nothing lasts forever. Cheers from Western Australia
Mauledriver(at)nc.rr.com
PostPosted: Sat May 18, 2013 9:49 am    Post subject: Electronic Ignition Reply with quote
Just to be clear, I didn't mean to open up the whole can of worms about
whether EI is advisable or not based on reliability, availability and
serviceability
My understanding is that EI can perform better than mags and I assume it
does. So far some words about MPG being the proper metric and increased
efficiency being the payoff have been posted. Okay, I agree.
I know it's tough and expensive to do any side by side testing so I
guess none has been done that is somehow relevant to the '10. I was just
curious.
Bill "knows that EI is the future while flying around with 2 mags" Watson
On 5/17/2013 7:43 PM, JimVillani wrote:
Well,
1st of all
let's look at all of Just the "Matronics Mail" sent in about Electronic
Ignitions within
just the last 2 weeks with "An open Mind"...
1) I never have to "Carry extra coils with my mags in case one fails"
2) I never have to "Open my oil door to let my mag cool off"
3) I can "Fly without any electricity" in my plane with my mags
4) I don’t have to "Face my plane into the wind to cool my mags" after any
flight...
5) Mags have at least a "60 year history of reliability"
6) I can get Mag parts (Points) at about any FBO,
Or
I can file them down,
Set the "Gap" with a "match book cover"
And
Make them work to get me home.
Try doing that with EI...
And last but not least...
7) I don’t need a "Backup Electronic Ignition" for my mags...
as is "Recommended my most A&P mechanics",
Most all articles written about EI,
Or anyone who has used EI in the past..
And all of that is from the last few weeks of "Matronics mail"......
Haven’t read much about "Mag Failure" in the last few years...Have you?
I read the stats in a magazine article about reasons why experimental
airplanes
Fail in flight or need emergency landings.
Yes it was on line, and from a reputable source...
The article was written a few months ago,
and confirmed my prior research on EI.
The article did mention than less than 5% of airplanes crash due to
mechanical failure,
The article also mentioned crashes or emergency landings were mostly Pilot
error.
The article went on to talk about engine modifications,
and it did address mags vs EI,
It said mags fail 8% of the time,
and EI failure rate was 16%,
Twice as often as mags...
"Don’t Shoot me",
"I am just the messenger"...
I will find the article and post it...
Now I was going to use EI,
but
I elected to have my
Bendix mag completely rebuilt and I also added "Shower of Sparks" to the
system.
For a mire $2500.00 or so.
I must report that they "the mags" and "SOS" have worked flawlessly,
For the 1,000 or so hours in prior planes that I have flown,
And also for the 90 plus hours on my RV-10.
Based in this "cool place" called "Las Vegas" (102 Tuesday)
And...
I never have (or had to) "exert any effort" to "Cool my mag down"
Even after the "hottest flight".
Imagine that...
N10KQ
Las Vegas Nevada
KVGT...
Jim
Bajajim
PostPosted: Sun May 19, 2013 11:00 am    Post subject: Electronic Ignition Reply with quote
Greg, Greg, Greg, Greg Greg...
Oh Boy...
Yea,
The mags are old school...
But
You mentioned...
Oiled up Plugs, Fouled plugs,
Sounds like you may have other problems
Mixture, Shut down Procedure, Start up procedure, Rings?
Blown a starter?
Maybe oil leaking from your engine into the throat of the starter,
Or maybe you went "Light" on the starter feed cable
using #4 or #6 from your battery instead of #2
to save weight (1 to 2 pounds) to get better gas mileage...
Mag overhaul or checkout at 500 hours
That's 5 maybe 7 to 10 years for most aviators.
Most of your hoses on your plane should be replaced every 5 years or so...
Oh yea that's in certified planes...
Sounds reasonable to me to have your Mags looked at every 5 years...
Hot start Issues...
Is the mag in control of a "Hot Start?"
Or is the Pilot responsible?
That's like blaming the Gun for the Murder...
I have "Electronic RPM readout" and "Electronic Manifold Pressure" using
Magnetos.
I have 1-2 turn starts with my Mags and Shower of Sparks System.
I also have EGT and Cylinder temps on all cylinders,
Oil pressure, Oil temperature, Fuel Pressure using my mags.
It's called an "EFIS"
Maybe you should look at your starting procedure...
Hot Starts on my IO540 are usually 2 to 3 revolutions,
but I blame that on the Fuel Injection not the Mag.
I have friends with Carbureted engines,
and Mags that start in 1-2 turns hot or cold.
Why not change out the "Old School Lycoming Engine",
It's only good for 2,000 hours anyway...
It's been around for 60 or so years also...
Why pay $40 to $60k for old school technology?
Again engines are good for 20 to 25 years for most aviators
You can go buy a Subaru or a "Brand New Factory Porsche engine" for about
$15k
(you can really save some gas cash using that thought)
Then modify it to work in your RV...
"Mooney Porsche" did that back in 1989 or so.
They were trying to improve on the old school technology also..
That model lasted a year or so...
Do you not think that the Millions and Millions of dollars Lycoming,
and Continental spends on R&D engineering and testing could have figured
this out over the past 30 years or so EI has been around.
Maybe they figured out it wasn't "Worth the Risk"
Or did you think maybe,
"They had a hell of an overstock" of these "Old School Magnetos" that they
needed to get rid of,
So..
They sold their antiquated engines and ignition systems to
"Not so up to speed companies like Cessna and Piper...
and they still haven't dumped all the magnetos...
Fuel economy...
Think about that one night when your EI turns your RV into a glider.
"Boy I saved $500 in fuel last year..."
"What a deal"
Meanwhile you are looking for an off airport landing site...
By the way...
What was that insurance deductable???
If you want Real Fuel Economy...
FLY COMMERCIAL...
No Offence...
Just some spare time...
And a big spoon to stir the pot...
Jim
N10KQ
partner14
PostPosted: Sun May 19, 2013 11:19 am    Post subject: Electronic Ignition Reply with quote
There's probably quite a few of the guys that would tell you were to put the spoon.
You had already made YOUR point.
BYW over 500 hours, no problems with dual EI in under 4 years.
--- On Sun, 5/19/13, JimVillani <Jim(at)JimVillani.com> wrote:
Subject: RE: Re: Electronic Ignition
Date: Sunday, May 19, 2013, 2:00 PM
--> RV10-List message posted by: "JimVillani" <[url=/mc/compose?to=Jim(at)jimvillani.com]Jim(at)jimvillani.com[/url]>
Oh Boy..
Yea,
But
You mentioned...
Blown a starter?
Hot start Issues...
Magnetos.
$15k
So..
Fuel economy...
"What a deal"
By the way...
FLY COMMERCIAL...
No Offence...
Jim
N10KQ
Don A. McDonald
40636
jkreidler
PostPosted: Mon May 20, 2013 4:02 am    Post subject: Re: Electronic Ignition Reply with quote
We are approaching the 500 hour mark and are considering some form of electronic ignition as well. I struggle with the current timing advance systems available as I do not like the amount of data they make their advance decision on. From what I have been able to find all of the systems doing advance monitor manifold pressure and RPM then determine the amount of ignition advance based on a stored table. In a perfect world this method is fine, my issue is that they are not monitoring the output of the system to determine when the world is not perfect. In the automotive world this is done by monitoring all of the inputs and all of the outputs via sensors like knock, O2, mass air flow, injector PWM, etc. Then all of this information is used by the computer to make adjustments on the fly -er drive.
I am not debating the advantages of EI, or even the reliability. I just wonder if we are taking a big enough picture of the entire system to make, and know we are making the right decision when it comes to advancing the timing of the ignition. At very least I would like to see knock sensors. - Jason
Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617
jdriggs49(at)msn.com
PostPosted: Mon May 20, 2013 5:56 am    Post subject: Electronic Ignition Reply with quote
They all use stored tables.  The difference between the auto and aircraft EIS systems is that the auto systems use greater system sampling (more sensors) than do the aircraft EIS before making the ignition decisions. That is what makes the auto engines so efficient today. I understand that knock sensing is difficult in aircraft engines because they are so internally noisy. If they could introduce a couple of more sensors to the equation (like you stated) that would help. I've talked to Rhonda Barrett (Barrett Precision Engines) about EIS. They have been slowly working on a system for their engines but she says its a complicated subject. Her concerns were very similar to the ones you stated.
Subject: Re: Electronic Ignition
Date: Mon, 20 May 2013 05:02:03 -0700
--> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=400982#400982
Kelly McMullen
PostPosted: Mon May 20, 2013 6:55 am    Post subject: Electronic Ignition Reply with quote
There is one factor not mentioned. Combustion from EI spark produces a different vibration signature from combustion generated by mag spark. No, I don't know the technical reasons, just know it is an issue that affects propeller harmonics, and on certified planes Hartzell and others want a vibration scan before setting approved rpm ranges for the prop.Unfortunately, such vibration scans are expensive, so prop manufacturers only do them if they see marketing opportunity or someone else pays.
On Mon, May 20, 2013 at 8:55 AM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
From: jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)
> To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
--> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
Jason Kreidler
- sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Mon May 20, 2013 7:16 am    Post subject: Electronic Ignition Reply with quote
To my (admitted limited) knowledge Electroair is the only one out there that has certified EIS for the type of airplanes we commonly drive. They use inductive type of spark which gives a longer dwell time than the CDI which is much shorter and very intense. Mag spark is good over 5 degrees of crank and Electroair's is good over about 20 degrees of crank and CDI has to spark multiple times to get any kind of dwell time, or so I understand.
I really like the fuel efficiency and easy starting characteristics of the EFI systems. I "think" that with the EFIS systems monitoring multiple engine parameters that we can keep ahead of most potential problems if  or as they arise. I was programming my GRT HX EFIS yesterday. I'm still amazed at what it can do for such a relatively small amount of money.
Date: Mon, 20 May 2013 09:55:15 -0500
Subject: Re: Re: Electronic Ignition
Jason Kreidler
carl.froehlich(at)verizon
PostPosted: Mon May 20, 2013 10:22 am    Post subject: Electronic Ignition Reply with quote
At high vacuum (low manifold pressure) the electronic ignition advances the timing (pMag is 34-39 degrees). This is what you want under such cruise conditions as the earlier spark provides more efficient combustion. This does however change the engine resonance - and for some props yields operation restrictions such as reducing RPM below 2600 other than takeoff. I believe MT does not have such restrictions - but would need to verify.
Below is the Hartzell limitations for the 180hp Lycoming with electronic ignition (and what I have placarded in the RV-8A). I haven't seen any such testing by Hartzell for the IO-540 - and their website just says "not endorsed". Perhaps Van's will get them to do the same vibration test for the IO-540 like they did for the 180hp 360.
Carl (still flying with mags but pinging Brad at eMag to get the six cylinder ignition out)
<![if !supportLists]>1. <![endif]>
http://www.vansaircraft.com/pdf/Hartzell_c2yk.pdf
Hartzell HC-C2YK-1BF/F7666A-2 Propeller on 180 Hp Lycoming engines
equipped with Electronic Ignition or FADEC
The Hartzell Propeller Model HC-C2YK-1BF/F7666A-2 has been vibrationally approved per
FAR23.907 on the standard production Lycoming Engine Model O-360-A1A, and similar models,
rated at 180 HP at 2700 RPM with a restriction to avoid continuous operation between 2000 and
2250 RPM. The propeller vibration characteristics and stress amplitudes on a reciprocating
engine installation are primarily mechanically generated by the engine. Any modification to the
standard engine configuration to include high compression pistons, electronic ignition, FADEC,
tuned induction and exhaust, and turbocharging or turbonormalizing have the potential to
adversely effect the propeller vibration characteristics and stress amplitudes. Hartzell Propeller,
therefore, does not endorse any such engine modification unless the specific engine and
propeller configurations have been tested and found to be acceptable vibrationwise.
The Lightspeed electronic ignition is not certified for use on any aircraft engines so its use is
limited to the experimental/amateur built market. Hartzell recently conducted a test with the
propeller model HC-C2YK-1BF/F7666A-2 installed on a standard Lycoming O-360-A1A engine,
except for a modification to equip it with the Lightspeed ignition in place of one magneto. The
results of this test show an increase in the propeller vibratory stress amplitudes within the 2000-
2250 RPM range currently covered by the operating restriction noted in the first paragraph, and
additionally above 2600 RPM with high power settings. Based on this data, continued safe use of
this propeller on O-360-A1A and similar engines equipped with Lightspeed electronic ignition
would require the following:
The Hartzell Propeller Model HC-C2YR-1BF/F7666A-2 is satisfactory vibrationwise mounted on
Lycoming model O-360-A1A and similar engines rated at 180 HP at 2700 RPM and equipped
with Lightspeed Plasma II electronic ignition installed in Van’s Aircraft Model RV-8 and similar
single engine tractor aircraft with the following operating restrictions.
1. Avoid continuous operation between 2000 and 2250 RPM.
2. Operation above 2600 RPM is limited to takeoff. As soon as practical after takeoff the RPM
should be reduced to 2600 RPM or less.
3. The propeller blades are life limited and must be retired upon reaching 8700 hours.
The propeller diameter limits are 74 to 72 inches.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Monday, May 20, 2013 10:55 AM
Jason Kreidler
get="_blank">http://www.matronics.com/Navigator?RV10-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
 Filesize:  701 Bytes
 Viewed:  17040 Time(s)
Deems Davis
PostPosted: Mon May 20, 2013 11:09 am    Post subject: Electronic Ignition Reply with quote
Jason,
This is precisely the issue with today's EI. Not only is each engine unique (evidence the dyno runs), but the  conditions that the engine operates in are dynamic and vary considerably. We know that things like temperature, humidity, altitude, etc. all combine to effect the effectiveness of the engine. Several years ago, George Braly (GAMI)  announced they were investigating/developing a system that would address these specific issues. I believe it was called PRISM, Talking to Alan Barrett, about it, he said that his father (Monty) was very interested in following it's development,because he believed it was the only way that he could see for EI to be an acceptable aircraft engine technology. (Hope I got that right, Alan, pleas chime in). I see that PRISM is listed on the GAMI web- site, but don't know it's current state. As I understood it at the time, The were going to use sensors to sense the operating factors and dynamically build the power/spark curves in real time.
On Mon, May 20, 2013 at 5:02 AM, jkreidler <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)> wrote:
[quote] --> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
Jason Kreidler
le, List Admin.
jkreidler
PostPosted: Mon May 20, 2013 11:27 am    Post subject: Re: Electronic Ignition Reply with quote
Wow - talk about a simple subject that is about as complicated as can be. Now that vibration is brought up it adds a whole new element to the equation. I wonder what vibration is created when mags are not timed well and fire at different times, or worse as the gears wear they fire only within a band.
One of the systems I have been giving serious consideration is the G3I. Simply because it maintains both mags, so I have a redundant system. It times both sides together so I know the plugs are firing at the same time. It leaves the timing alone, but provides spark for another 20 degrees of rotation (not sure how / if that effects vibraton). On the downside I still have to rebuild those stupid dumb old school mags.
By the way, these decisions are a pile more complicated after the airplane is complete. When it is time to decide this stuff during the build you have a thousand other decisions to make, so if you want to finish and fly in a reasonable amount of time you just need to decide and move on. After the airplane is flying the time pressure is no longer there so you can contemplate, think, ask, drink, contemplate some more, go flying, and forget about the decision for another few months. That is until the mags go TU and you are sitting on the ramp somewhere - then you walk in the local shop ask if they have a mag to get you home and the decision is made for another 500 hours. ugh - I think I am reaching the drink stage again! - Jason
Jason Kreidler
PostPosted: Mon May 20, 2013 1:50 pm    Post subject: Electronic Ignition Reply with quote
While the G3I maintaining both mags is an attraction to some, I see it as a
disadvantage. The weak sister mechanical aspect of a magneto is as much
reason for me to not have mags as the better spark and timing curve with the
electronic ignition.
I'm sure others see it different.
Carl
RV-8A (700hrs - 400hrs on pMags and $2 NGK sparkplugs)
RV-10 (with 85 hours on mags and for the first time ever on an airplane just
cleaned sparkplugs - I hope never to have to do this again)
neal.george(at)gmail.com
PostPosted: Mon May 20, 2013 5:36 pm    Post subject: Electronic Ignition Reply with quote
Tim / Robin (et al) -
We gotta talk.
Our aircraft engines DO NOT have two ignition sources for redundancy. It's required for best operation.
The combustion chamber in our opposed air-cooled engines is so big it needs to have the flame lit in multiple locations to achieve reasonable combustion in the time allotted per power stroke.
If you're running one mag and one EI, you're only running on one plug above idle.
Not good. Nowhere close to optimum. A hotter spark from EI masks some of the roughness from inefficient combustion, but it's still just one plug doing all the work.
This is a critical system, and not a place for compromise or hedging bets. It's binary-land. You're either in or out. Pick one or the other and run with it.
Your fuel consumption per unit power / distance / time (pick your favorite measuring stick) will decrease and engine performance / smoothness will increase.
"Redundancy" or "safety" are false promises.
Neal George
On May 16, 2013, at 12:59 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
I feel about the same. I wouldn't ever be happy anymore with
2 Mags. Reliability wise I've actually had more worrysome
issues with planes over the years with mags than with the
lightspeed on one side. I'm not sure where those statistics
came from exactly, but especially with that last
Slick AD I'm not sure I'd believe them. Maybe Bendix
would be a different story. These days nobody runs
points and mags in a car....and even in my boat one of the
best things I did in the last year was swap the points
for an electronic trigger module. So one side has to be
E.I. for me.
But, just like Robin says, I don't know that I'd want to put
TWO of anything on the engine yet. If I did have 2, I don't
think the lightspeed would be my choice on the RV-10, because
you'd still have one crank sensor. And given the Looooooong
time to market and broken promises of pMag for the 6, I think
I'd want to see a few hundred flying, for a few 10's of
thousands of hours before I'd dive in. It wouldn't take but
a couple years for them to develop a track record one way
or the other...and I have to assume that if they were
reliable right now, they would be AVAILABLE right now, because
there certainly is a market for them once they are
released. I can only assume that it's because of issues
that they aren't making it to market...so I'll want to
see a track record before I'd go that route.
In the end, I'm very happy to have only 1 mag to overhaul,
but even happier that the engine runs best on that one
EI. I would prefer to keep that same type of
arrangement down the road...I'm not an "all eggs in 1
basket" kind of guy.
On 5/16/2013 12:20 PM, Robin Marks wrote:
> I prefer the mixed set up of one EI and one mag. I love the set up on my 8A with one Pmag. I won't run dual anything but Mags however I prefer the better burn of EI and with a single EI you get almost all the benefit of having dual EI but still have a good old Mag to rely upon.
> I would consider two different EI but not two of the same EIs.
> I wish the 6 cylinder pmag were available (and fully tested)
> Robin
flying-nut(at)cfl.rr.com
PostPosted: Wed May 22, 2013 1:45 pm    Post subject: Electronic Ignition Reply with quote
On 5/20/2013 9:35 PM, Neal George wrote:
--> RV10-List message posted by: Neal George <neal.george(at)gmail.com> (neal.george(at)gmail.com)
We gotta talk.
Pardon my ignorance and I'm a little slow so bear with me. What you infer is that one plug/cylinder quits firing??? Why??? Which one quits .... the mag or the EI???
Well, the mag doesn't quit so that leaves the EI .... which (AFAIK) doesn't quit ...... so where did you get derailed???
Linn
Neal George
On May 16, 2013, at 12:59 PM, Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com) wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> (Tim(at)myrv10.com)
E.I. for me.
Robin
Checked by AVG - www.avg.com
ehm6006
PostPosted: Wed May 22, 2013 2:48 pm    Post subject: Electronic Ignition Reply with quote
I'll jump into the middle of this. I agree. I'm not a mechanic, but I do know my way around an engine. When I started flying in the mid 80's I thought the two mags were for redundancy also. A couple of experienced mechanics explained it was for better combustion. The flame front propagates so slowly that you need the two sparks to complete combustion correctly. Both mags are firing, since one is so early that starts the flame front. The other one fires so late it doesn't matter much.
Ed
We gotta talk.
Neal George
> E.I. for me.
> Tim
>> Robin
Bob Turner
PostPosted: Wed May 22, 2013 2:51 pm    Post subject: Re: Electronic Ignition Reply with quote
Linn,
Your error is in assuming that a post that starts out "we gotta talk" is going to be rational.
The poster said, correctly, that having two ignition sources and two propagating flame fronts helps the fuel burn more completely within the alloted time (especially true for fixed timing mags), and hence improves engine power and efficiency. (which is why there is an rpm drop on runup when operating on one mag).
He also said, correctly, that if you have an EI plug with advanced timing, that its flame front may have propagated past the second, mag fired plug, before the mag has fired, and thus the mag is "doing no work", to use his words.
But then he says that this is "bad". If it was bad, then the EI guys just wouldn't advance the timing. But they do, because the engine runs more efficiently with advanced timing under typical cruise conditions. Even if it's only one plug that's advanced. His arguement makes no sense. I thought maybe it was an IQ test, to see how many people responded.
Bob Turner
RV-10 QB
rv10pro(at)gmail.com
PostPosted: Wed May 22, 2013 3:36 pm    Post subject: Electronic Ignition Reply with quote
This seems the point at which the positives of EI need to be clearly stated  - balanced against their negatives.  Then compared directly with the clear positives of a magneto and its negatives.  When a reader understands the trade-offs they can better understand the frustration with the always coming into the near future Pmag for 6 cylinders which was going to solve everything (comes to mind).
Mr. Barrett (or the lovely Ms Rhonda) could weigh in on why the high performance engines he builds use what they do and why power output diminishes on their dyno with one EI and one magneto. Note: a most popular blend with the RV-10 crowd.  Another question is what do S.D. Tucker, K. Chambliss and M.Goulian bet their lives on??
Tim's input had something to do with that isolated manufacturing incident with Slick mags a few years ago.  Two Slicks with bad carbon made for a bad day.  Two EI have their own Achilles heal.  As of today, there is still no single right answer.
Lycoming has made such an advanced engine in their iE2 with knock sensors, variable timing and redundant FADEC wiring for the Lancair Evolution TEO-540-A1A.  The additional price knocked a few willing participants out of the evaluation and they opt for turbine.
Know your mission, choose wisely, land safely Every Time.
John Cox
On Wed, May 22, 2013 at 3:51 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Linn,
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=401148#401148
le, List Admin.
PostPosted: Wed May 22, 2013 4:14 pm    Post subject: Electronic Ignition Reply with quote
I spoke with Barrett and rather than get an answer on their preferred set up Alan told me they are working on a dual electronic ignition of their own (bolt onto the Magneto platform). They are fashioning it after the successful EI they developed for their MP-14 (Radial). ETA likely 2014.
As far as what Sean Tucker et.al. uses I am not sure their risk analysis matches mine. I frankly never considered flying upside down to cut a ribbon with my rudder a few feet off the pavement. Just never came to mind.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Wednesday, May 22, 2013 4:36 PM
John Cox
Linn,
Bob Turner
RV-10 QB
le, List Admin.
==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp;   -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [/quote]
:p>
PostPosted: Wed May 22, 2013 4:26 pm    Post subject: Electronic Ignition Reply with quote
Research will find they don't mix and match.
The Barrett solution for the M-14 has been remarkable.....but... the Russian & Chinese mags had a life limit of 750 hours. Getting correct parts is another matter.
Barrett's have made a lot of improvements, for the old M-14.
Too bad we don't have a thousand engines available with FADEC.
On May 22, 2013 5:19 PM, "Robin Marks" <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
> Thanks,
> Robin
> From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John Cox
> John Cox
> Linn,
> Bob Turner
> RV-10 QB
> arget="_blank">http://www.matronics.com/Navigator?RV10-List
> le, List Admin.
> ="_blank">http://www.matronics.com/contribution
> ============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp;    - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============== bsp;  - List Contribution Web Site - e> bsp;                   -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ==============
> ________________________________
> No virus found in this message.
> :p>
ms.matronics.com
Page 3 of 4
