Hugo rv10-40456
gommone7(at)bellsouth.net
PostPosted: Sun Jun 11, 2006 3:21 am    Post subject: Hugo rv10-40456 Reply with quote
Good morning at all.
I just found a problem in the wings,I hope I miss somethings.
for the builders just finish the QB wings,how is suppose to rivet the flap gap fairing against the back spar ,when the bottom skin is allready in place,in the instruction say cleco and rivet,thats it.please tell me I miss some instruction.
Thanks for the help,Hugo
jesse(at)itecusa.org
PostPosted: Sun Jun 11, 2006 3:54 am    Post subject: Hugo rv10-40456 Reply with quote
I don’t know about the QB wing but that fairing is supposed to be installed
before the bottom skin goes on. If I remember right, the bottom skin is
installed by the builder in the QB wings, right? If your bottom skin is
truly already on, then you might have to use blind rivets, but I would ask
Van's first if this is acceptable. You might be able to access some of the
rivets through inspection plates, but not very many.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
armywrights(at)adelphia.n
PostPosted: Sun Jun 11, 2006 5:55 am    Post subject: Hugo rv10-40456 Reply with quote
Hugo,
I riveted mine on a couple of weeks ago. It took some effort and scrapes on
the arms, but I used the long and then elevator bucking bar to poke up
inside there to buck the rivets. Be careful, as no matter how hard I tried
I always vibrated the bar off the rivet, so I hit the rivet a couple of
times, reset the bucking bar on the tail, and shot again, as necessary,
until the rivet was set. I'm sure it would have been easier if I had two
people though. It was definitely a stretch.
For Slow-Wing builders, the inboard bottom skin comes riveted on except for
the row of tie-in rivets for the outboard bottom skin.
Rob Wright
#392 QB Wings
dav1111(at)cox.net
PostPosted: Sun Jun 11, 2006 2:33 pm    Post subject: Hugo rv10-40456 Reply with quote
On the rivets that were really hard to reach I used Cherry Max Pop Rivets.
Russ Daves
PostPosted: Mon Jun 12, 2006 3:52 am    Post subject: Hugo rv10-40456 Reply with quote
Thanks for the answers-sugestions, I thinks the cherry max are the logical solutions,few more dollars but far more safe then try to install a bucking bar by feeling inside the wing.
Thanks a lot .
Hugo
Date: 2006/06/11 Sun PM 06:30:09 EDT
Subject: Re: Hugo rv10-40456
Russ Daves
