rob10(at)tlb.sympatico.ca Guest
Posted: Sun May 12, 2013 1:07 pm Post subject: model 4 rudder pedal |
Thanks for the answer guys. You are probably right Lowell.
I’ll try to get the tubes out of the plane. Hard to do with the console and fuel lines in the way.
If I can get one end open, I’ll be able to insert a rod to tap the other bearing out.
Jack
