Posted: Sat May 11, 2013 9:14 am Post subject: Crowbar OV Module |
At 02:06 AM 5/11/2013, you wrote:
| Quote: | Good morning Bob,
I just bought one crowbar OV module from your site. Could you tell me as precisely as possible the value of the voltage which triggers the module (14.5V ??)?
I plan to use a Rotax 912UL with a Ducati voltage regulator and an Aliant Lithium battery (Ref X4 12V 9.2Ah). This battery is supposedly best charged at 14.4-14.6V, but they also say that voltage over 14.5V could damage the battery ...
Of course I am trying to figure out if the crowbar OV module can protect this battery from voltage over 14.5V.
Eric Boutteloup |
Sure. The Crowbar ov modules we produce are
set on the bench at 16.4 volts and they
have a significant negative temperature
coefficient. In very cold conditions, the
voltage will be a bit higher, when hot
they'll be a bit lower. This is consistent
with a lead acid battery's performance needs
with respect to ambient temperature.
The OV module is NOT intended nor designed
to guard the welfare of a battery although
it's presence in the system will benefit
the battery and all other electro-whizzies
from a runaway alternator.
The failure condition we're concerned
with is a failed regulator that allows
an alternator to run essentially full bore.
While not a spectacular event with your Rotax
18A alternator, it's another matter with a
60A belt driven alternator on a Lycoming.
The Crowbar OVM is a rational addition to
your system but it's not going to catch
a poorly performing regulator that's putting
your battery at risk for LONG term effects
of inappropriate voltage setting.
Care and feeding of your lithium battery is
another matter entirely. I'd not heard of
the Aliant brand until your enquiry. Poking
around on the 'net I find that they've made
what appears to be a good penetration of the
sport vehicles markets. They filed for a trademark
late last year. http://tinyurl.com/d2ohsjo
I'm reading also where a part of their organization
has been awarded a contract to do safety
studies for the US Army to explore characteristics
based on environments and maintenance issues.
This is how the B787 cells should have been
tested too. Not unlike the work that the Navy's
battery labs in Crane, IN used to do and
may still do.
The lithium elephants in the room are: (1) Can
one drop an Li battery into location previously
occupied by lead-acid or Ni-Cad (with no other
changes to the system) and expect (2) a service life
commensurate with increased costs,(3) performance
enhancements commensurate with less weight and (3)
reliability equal too or better than the batteries
being replaced (i.e. pre-mature chemistry death
and catching fire is very much frowned upon!).
The technology is relatively young and variations
on a theme for chemistries increases the numbers
of variables for the sifting of elephants.
I quick appraisal of Internet images for Aliant
batteries
http://tinyurl.com/bnfnfeq
failed to show a battery with a socket for a "genius
charger" nor did I see any batteries fitted with
ports to connect such chargers. All the recommended
chargers ranging from wall warts (including Battery
Tenders) . . .
to 'Super chargers' . . . .
. . . appear to make two-wire connections to the battery.
This means that the charger cannot perform to any
cell-by-cell charging protocols. Now, are they 'tailored'
to lithium chemistry? Don't know. It would be interesting
to plot the output from one of these 'recommended' chargers
to see if they exhibit any more smarts than the commercial
off the shelf chargers for lead-acid.
So, Eric my friend, the SHORT answer to your question is
that the OV module has no duties or practical expectations
for enhancing battery performance on your airplane. Where
did you read about 14.5v charge levels being detrimental
to the product? Many vehicular alternator regulators may
produce system voltages at or maybe above 14.5 volts. Only
an accurate voltmeter on YOUR airplane will tell this
tale.
My suspicion is that the literature is referring to long
term maintenance or 'float' voltages. A system
operating voltage that was suited to your SVLA battery
may be no more detrimental to the Li-Ion given the
intermittent and short term application of the "excess"
voltage. SLVA is the same way. You MAINTAIN it at just
a tad above 13.0 volts and CHARGE it at 14.2 to 14.8 volts.
The numbers for a drop-in lithium battery should be just
FINE with similar CHARGE voltages . . . the MAINTENANCE
voltage will no doubt be different. This graph taken from
a learned treatise on Li batteries
[img]cid:.0[/img]
Suggests a room temperature open circuit voltage
on the order of 3.35 volts per cell or 13.4 volts
for an array of 4 cells. This means that the
Li-battery 'maintainer' needs to be on the order
of 13.5 volts . . . probably not too high for a
lead-acid battery either.
Given the drop-in-SVLA-replacement marketing policy
for the Aliant Li-products, you need not concern
yourself for any duties of ownership beyond having
a voltmeter in your airplane that confirms a 14.2
to 14.8 flight ops voltage . . . and a ov protection
system for mitigating regulator failures.
57.02 KB |
28254 Time(s) |
uuccio(at)gmail.com Guest
Posted: Sat May 11, 2013 11:15 pm Post subject: Crowbar OV Module |
Aliant is a brand belonging to ELSA Solutions. They're an Italian company based in Bologna, whose main business is industrial automation and photovoltaic products.
www.elsaweb.it
Their website is in Italian and they use google translate which can yield some interesting results.
They claim that their batteries were designed with the Battery Management System as the central component which may explain why they haven't run into the same problems as the other manufacturers.
On 12 May 2013, at 02:18, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] Care and feeding of your lithium battery is
SCRATCH THE ABOVE.
Seems there's a company called Alliant/Valence that makes
a lot of aerospace/military hardware. These are the
folks getting the testing job . . . NOT Aliant
jan(at)CLAVER.DEMON.CO.UK Guest
Posted: Sat May 11, 2013 11:50 pm Post subject: Crowbar OV Module |
I know Valence very well. Been using them for a few years in other applications – They ran out of money some time ago. Looks like they are now doing work with this Aliant company .. Valence had a good technology and a good BMS system – Also the Iron Phosphate technology is pretty safe – Not as energy dense or as powerful as Cobalt .
To not damage the cells – over voltage under voltage and temperatures all have to be watched and maintained to not damage the cell.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sacha
Sent: 12 May 2013 07:56
Subject: Re: AeroElectric-List: Re: Crowbar OV Module
www.elsaweb.it
SCRATCH THE ABOVE.
| 01234567890123456
Posted: Sun May 12, 2013 5:45 am Post subject: Crowbar OV Module |
At 03:01 AM 5/12/2013, you wrote:
| Quote: | I know Valence very well. Been using them for a few years in other applications – They ran out of money some time ago. Looks like they are now doing work with this Aliant company .. Valence had a good technology and a good BMS system – Also the Iron Phosphate technology is pretty safe – Not as energy dense or as powerful as Cobalt .
Are you saying there IS a cooperation between Aliant
the battery guys and Alliant/Valence the aerospace/
military guys?
Bob . . . [quote][b]
Posted: Sun May 12, 2013 6:04 am Post subject: Crowbar OV Module |
I will make a few phone calls next week and see what I can find out…
Jan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: 12 May 2013 14:43
Subject: RE: AeroElectric-List: Re: Crowbar OV Module
military guys?
Bob . . . | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234567890123
Posted: Mon May 13, 2013 10:27 am Post subject: Crowbar OV Module |
Done a bit of digging on this .
First Valence is still in Chapter 11. Yes they have supplied some battery modules to Alliant – The US aerospace military contractor. If that ever became of anything ‘large scale’ I am not sure . if it ever did . it may not have been very profitable .. i.e. Chapter 11 J
Aliant in Italy have nothing to do with Valence – What Aliant looks to have done is to do the same as Valence did from a integration point – Take small Li-phosphate cells – and integrate them to look like a ‘normal battery’ .. and include some form of BMS.
What was great with Valence was that they based the form factor on your normal 12V ‘golf cart’ size battery – but it had 3 times the energy. Each battery would like together and you had a master MBS that would talk to all the battery modules and you would get all sort of interesting info over CAN.
From what I can see – Aliant in Italy have focused on single battery only (i.e. not high voltage application – with Valence you could easily string the battery together to give you 400VDC) …
What Aliant is saying about starting from a BMS is just sales blurb .. no one that makes any Li-ion battery will do so unless they have some form of BMS. The question is how good and sophisticated the MBS is.
I would not be surprised if Aliant are using the same cells as Valence – but that is pure guesswork – The cells are made in China by Tianjin Lishen Battery.
If I was to stick a Li-ion battery in a plane I would like to know a lot more about the BMS and how it interact with the cells.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jan
Sent: 12 May 2013 15:15
Jan
military guys?
| Quote: | | http://forums.matronics.com |
| Quote: | | http://www.matronics.com/contribution |
Demixl Guest
Posted: Sat Sep 28, 2019 9:36 am Post subject: Re: Crowbar OV Module |
Hey guys. Does anyone know how to register a trademark? sorry for offtop
1nvent
John M Tipton
Joined: 07 Aug 2018 Posts: 45 Location: Devon - England
Posted: Sun Sep 29, 2019 11:30 am Post subject: Crowbar OV Module |
At 12:36 PM 9/28/2019, you wrote:
NOT A SUBSCRIBED MEMBER OF THIS
LIST. TREAT AS SPAM.
