Posted: Sat May 11, 2013 3:04 am Post subject: Fresh Air Vents |
Guys
The front seats fresh air vents which came in this kit are like this
with the female part where the eye-ball valve will be mounted.
But if I leave it like it is, this female part positon is not paralel with the instrument panel surface.
Is this the way you installed it?
Or did you cut that part and installed it flush with the panel surface?
Carlos
48.92 KB |
11349 Time(s) |
rleffler
Posted: Sat May 11, 2013 3:24 am Post subject: Fresh Air Vents |
Most folks will install an eyeball vent, such as those that Stein sells. Then run a short piece of scat between the naca vent to the eyeball vent.
On May 11, 2013, at 7:03 AM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Guys
<image003.jpg>
Carlos
| [quote][b]
_________________ Bob Leffler
N410BL - Phase I
dmaib@me.com
Posted: Sat May 11, 2013 4:10 am Post subject: Re: Fresh Air Vents |
I have mine installed at that angle and find that they work really well that way. Each one can pretty much be pointed anywhere in the cockpit when mounted at the prescribed angle. Now, if you are going to have a custom glass or carbon fiber panel with the vent actually mounted in the panel, then you would want to modify as Bob suggests. I bought the upgraded aluminum eyeball vents from Van's. http://www.vansaircraft.com/cgi-bin/store.cgi?ident=1368273286-484-93&browse=heatvent&product=sv-6 They are very similar to the ones Stein sells. These are probably the most efficient air vents I have ever seen on a light airplane. They adjust easily and are capable of providing way more fresh air than you usually need, The aluminum vents from Vans do not leak in rain, either.
I think they work really well when mounted as per the instructions. I don't have any good closeup photos, but here is one in my old "pre-GRT" panel.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
davidsoutpost(at)comcast. Guest
Posted: Sat May 11, 2013 4:37 am Post subject: Fresh Air Vents |
Posted: Sat May 11, 2013 5:13 am Post subject: Fresh Air Vents |
I agree with Dave. I also just used the stock black nylon vents as I
figured I'd rather spend the extra $300 on avgas. They work well. One day
I'll probably breakdown and spring for the nice aluminum ones from Van's.
Carl
Posted: Sat May 11, 2013 6:50 am Post subject: Fresh Air Vents |
David
Thanks for your answer, but I didn't get any photo you refer at the end of
your post.
By the way, since you installed the vent at that angle, how did you support
it below the panel, did you make a bracket?
Carlos
dmaib@me.com
Posted: Sat May 11, 2013 7:43 am Post subject: Fresh Air Vents |
Carlos,
Mine are not supported below the panel and they are rock solid. I believe we used proseal to mount the vent scoop to the fuselage wall, but it has been so long now that I cannot say that for sure. Sorry about the photo. I did not attach it properly, but if you log on to the Matronics site you can see it on my post.
David Maib
On May 11, 2013, at 10:50 AM, Carlos Trigo wrote:
David
your post.
Carlos
RV-10 #40559
rv10flyer
Posted: Sat May 11, 2013 10:15 am Post subject: Re: Fresh Air Vents |
I used the large eyeball vents from Stein attached directly to NACA vent using proseal for both like David. Stock panel. Works great.
_________________ Wayne G. |
Posted: Sat May 11, 2013 1:50 pm Post subject: Fresh Air Vents |
I'm not sure which David you are referring to but mine are the Steinair vents mounted to the stock RV-10 kit Naca's with the square flange.
David Clifford
RV-10 Builder
Howell, MI
Sent: Saturday, May 11, 2013 10:50:10 AM
Subject: RE: RV10-List: Re: Fresh Air Vents
--> RV10-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt>
David
your post.
Carlos
Posted: Sat May 11, 2013 5:06 pm Post subject: Fresh Air Vents |
David Clifford
Thanks for your answer as well..
Do you have a picture?
CarlosÂ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of davidsoutpost(at)comcast.net
Sent: sábado, 11 de Maio de 2013 22:50
Subject: Re: Re: Fresh Air Vents
David Clifford
RV-10 Builder
Howell, MI
From: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
Subject: RE: Re: Fresh Air Vents
--> RV10-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
David
your post.
Carlos
Posted: Sat May 11, 2013 5:39 pm Post subject: Fresh Air Vents |
The pictures were attachments on my first reply to your post.
David Clifford
RV-10 Builder
Howell, MI
Sent: Saturday, May 11, 2013 9:06:10 PM
David Clifford
Carlos
David Clifford
RV-10 Builder
Howell, MI
David
your post.
Carlos
Posted: Sun May 12, 2013 2:54 am Post subject: Fresh Air Vents |
For some reason, your first reply came out blank, even when going online to the Matronics site.
Will you please repeat your first post?
CarlosÂ
Sent: domingo, 12 de Maio de 2013 02:39
David Clifford
RV-10 Builder
Howell, MI
David Clifford
Carlos
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of davidsoutpost(at)comcast.net (davidsoutpost(at)comcast.net)
David Clifford
RV-10 Builder
Howell, MI
David
your post.
Carlos
Posted: Wed May 15, 2013 1:13 pm Post subject: Fresh Air Vents |
Carlos, I did something a bit different.
I can see from David Maib's photo that he has a Stein panel blank as
well as Steins eyeball vent. I used the same panel blank and vent but
instead of mounting it below the panel, I put the vent on the panel and
ran a piece of SCAT (I actually used CEET for the color and so that the
wire is covered, won't rust and it has less internal friction to air
flow). Take a look here:
http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=5253&log=66090&row=6
It turns out that you can do a minimum radius 360 turn with the SCAT
quite nicely. I just added a pic showing it finished:
http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=5253&log=170694&row=1
The SCAT (or CEET) is slightly visible underneath the panel but is
completely non-obtrusive. I think the vent looks best mounted in the
panel. Makes a nice water trap if that's a problem (I guess it isn't
because I've never heard anyone complain about it)
Bill "having just been reminded that it's bird nesting season... do they
always build on cylinders 1-3-5" Watson
Bob Turner
Posted: Wed May 15, 2013 1:20 pm Post subject: Re: Fresh Air Vents |
I used the Stein vents mounted in a hole in a piece of scrap aluminum, which in turn was mounted directly to the Van's duct with some screws/nuts.
I did put a piece of nylon screen in there to keep out bugs.
I mounted the Van's duct late in the game, and as I had no easy way to clamp it, I used a couple of flush pull rivets (fore and aft) to hold it while the pro-seal set. I left the rivets in.
Works fine, air can be directed anywhere, lots of it once you're moving.
_________________ Bob Turner
RV-10 QB |
dmaib@me.com
Posted: Wed May 15, 2013 4:07 pm Post subject: Re: Fresh Air Vents |
| Mauledriver(at)nc.rr.com wrote: | Carlos, I did something a bit different.
always build on cylinders 1-3-5" Watson |
That is a really nice looking air vent installation, Bill. Maybe on my next airplane.................
RV-10 #40559
Posted: Thu May 16, 2013 2:10 am Post subject: Fresh Air Vents |
Thanks David.
There are a few things I'd do on my next plane too... but I've told
everyone I know that I only have one in me. It's been the best project
ever, but I'm thinking it best not to return to the scene of the crime.
On 5/15/2013 8:07 PM, dmaib(at)me.com wrote:
David Maib
RV-10 #40559
Transition Trainer
http://forums.matronics.com/viewtopic.php?p=400715#400715
Checked by AVG - www.avg.com
