SS7 rudder pedal install question
n223rv(at)wolflakeairport
PostPosted: Fri May 03, 2013 3:32 pm    Post subject: SS7 rudder pedal install question Reply with quote
I am building a SS7 and am getting ready to fab and install the adjustable rudder pedals. One question I have while reading the plans, I don't see how you space the inboard pedal so the 2 bolts holding the adjustable pedal control wheels do not contact each other. It seems that the bolt heads will hit after you install the plastic bushings and drill the assembly to keep your 1/32" side to side clearance.
What am I missing? Picture attached.
-Mike Kraus
RV-4 sold Sad
RV-10 flying Smile
KitFox SS7 Radial building Smile
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
 Filesize:  314.03 KB
 Viewed:  6291 Time(s)
7suds(at)Chartermi.net
PostPosted: Tue May 07, 2013 6:29 pm    Post subject: SS7 rudder pedal install question Reply with quote
Mike,
Not sure if anyone has had an opportunity to help you yet, I am in the
middle of replacing my rudder cables on my Model 5, so I am working with the
very items you have concern with. I will snap a shot of my standoffs for the
pulleys next time I'm at the hanger. From what I remember, my screw heads
have clearance and the only difference from your pic is the bushing you have
laying in front of your shaft is installed on mine and seems to help create
the separation you are looking for.
Lloyd C KF 5 Outback
912ul IVO IFA Northern Mi
PostPosted: Tue May 07, 2013 7:03 pm    Post subject: SS7 rudder pedal install question Reply with quote
Hi Lloyd,
Thanks for the reply. I am going to sand off the paint and install the bushings, but from looking at it, it doesn't appear the bushing will give me enough spacing. Maybe once I assemble it, it will become more clear.
Where in northern Mi are you? I'm at 26W near Jackson.
-Mike Kraus
RV-4 sold Sad
RV-10 flying Smile
On May 7, 2013, at 10:29 PM, "Lloyd & Lorrie Cudnohufsky" <7suds(at)Chartermi.net> wrote:
Mike,
Lynn Matteson
PostPosted: Wed May 08, 2013 11:38 am    Post subject: SS7 rudder pedal install question Reply with quote
26W???? That's practically my backyard....do I know you, Mike? I fly
in there from time to time with my orange Kitfox IV, and have done so
on wheels and skis. I didn't know there was a Kitfox being built in
the area.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1430 hrs... (since 3-27-2006)
On May 7, 2013, at 11:02 PM, Michael Kraus wrote:
<n223rv(at)wolflakeairport.net>
Hi Lloyd,
become more clear.
-Mike Kraus
RV-4 sold Sad
RV-10 flying Smile
> <7suds(at)chartermi.net>
> Mike,
> the
> working with the
> standoffs for the
> screw heads
> bushing you have
> help create
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Thu May 09, 2013 3:45 pm    Post subject: SS7 rudder pedal install question Reply with quote
Hello Mike,
I'm at KIMT Ford Airport, out of Iron Mountain in the upper peninsula. , I
have yet to make it back to the hanger, so I have no pics of my peddles to
share, it has been a rough week at work, looking forward to the weekend.
Also, I see you have a little experience with RV's, my hanger partner has an
RV-7A, he is pushing 600 hours flying time on it, it is a hoot to fly in.
Lloyd
PostPosted: Thu May 09, 2013 4:59 pm    Post subject: SS7 rudder pedal install question Reply with quote
To circle back, I forwarded my note to John McBean. He said there are a few builders who have the problem I mentioned and they have created a bushing with a wider flange to ensure the bolt head clearances. He is going to send me out a set! Sounds like I'm all set.
-Mike Kraus
RV-4 sold Sad
RV-10 flying Smile
On May 9, 2013, at 7:44 PM, "Lloyd & Lorrie Cudnohufsky" <7suds(at)Chartermi.net> wrote:
Hello Mike,
Lloyd
