rickofudall
Posted: Mon May 06, 2013 10:16 am Post subject: Lift Reserve Indicator |
One of the members of my EAA chapter sent this to me for our newsletter. After I put it in, I got to thinking it might be interesting for the Kolb forum so I put it in a separate PDF.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Description: |
 Download |
Filename: |
LRI_Article.pdf |
Filesize: |
685.85 KB |
Downloaded: |
1012 Time(s) |
rickofudall
Posted: Wed May 08, 2013 6:55 am Post subject: Lift Reserve Indicator |
Jim sent me the info on the gauge he used. It's a "Minihelic" gauge from Dwyer, dwyer-inst.com, The part no. is 2-5002.
Rick
On Mon, May 6, 2013 at 1:15 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Quote: | One of the members of my EAA chapter sent this to me for our newsletter. After I put it in, I got to thinking it might be interesting for the Kolb forum so I put it in a separate PDF.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
byoungplumbing(at)gmail.c Guest
Posted: Wed May 08, 2013 7:55 am Post subject: Lift Reserve Indicator |
color me simple... but I don’t see the need.... aircraft that fly at extremely high altitude have a need. because the difference in operating speeds and stall speed narrows at high altitude. example: ss blackbird,,,,, the difference between stall and an operational speed of Mach 3 is less than 15 mph..... or aircraft that are heavy haulers can have their weight doubled when loaded vs empty. this can have a large difference in stall speed when empty or loaded to max....
our little planes are not going to be found at 43,000 feet.... and by the time we weigh the plane and pilot, are we going to double that weight when we add a passenger, provided we have room for a passenger.... so the indicated airspeed at stall is not going to change enough, in my humble opinion, to require an extra system in the plane.
golly gee... when I fly I like to see the area I am flying over.. not fixate on a gauge that gives me very little additional flight data,,, but if you like your gadgets,,,,, go for it. or prove me wrong,,, go and test and give me the differences in indicated airspeed at stall at max weight, vs normal operating weight... when your reserve lift gauge RLG hits zero. shucks maybe ill have some crow to eat,,, it will probably taste like chicken anyway....
kiss keep it simple sailor
boyd young
Rick
[quote] One of the members of my EAA chapter sent this to me for our newsletter. After I put it in, I got to thinking it might be interesting for the Kolb forum so I put it in a separate PDF.
Rick Girard
kuffel(at)cyberport.net Guest
Posted: Wed May 08, 2013 8:41 am Post subject: Lift Reserve Indicator |
Boyd,
<< I don’t see the need ... when I fly I like to see the area I am flying over.. not fixate on a gauge >>
Of course, an AOA gauge is for use on approach, not cruise. It lets you know exactly how close you are to stall independent of other factors. So for typical aircraft attempting high performance landings (sandbars for example), this gauge is very useful. However, agree for Kolbs you don't need to execute a high performance landing to get into the shortest of fields since the Kolb has such a low approach speed and high drag anyway.
Tom Kuffel
Posted: Wed May 08, 2013 10:00 am Post subject: Lift Reserve Indicator |
Tom
I had not thought of the sandbar landing, I was only thinking of the way I fly my plane... I bow to your experience.... do I need to start preparing my, taste just like chicken, crow ?
boyd young
Sent: Wednesday, May 08, 2013 10:40 AM
Subject: Re: Lift Reserve Indicator
Boyd,
Tom Kuffel
Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Wed May 08, 2013 2:39 pm Post subject: Re: Lift Reserve Indicator |
I have to admit I love gadget's as electronics has been my life. I have to say, though , learn to fly your plane and feel what it's telling you when landing. Looking at your airspeed is all you need to come home alive. Never paste your face on the dashboard as you have to do when flying in instrument conditions....
_________________ Rick Lewis
(VW Watercooled Engine) |
Thom Riddle
Posted: Thu May 09, 2013 3:28 am Post subject: Re: Lift Reserve Indicator |
Calculating the change in stall speed based on change in weight is pretty easy. The stall speed changes with the square root of the change in flying weight, all other things being equal.
Example:
Typical flying weight solo 900 lbs., stall speed 40
Add a 200 lb passenger, flying weight becomes 1100 lbs
1100/900 = 1.22
sqrt(1.22) = 1.11 therefore stall speed at 1100 lbs = 44.4
So, for these class of airplanes, adding 5 to indicated speed during approach when carrying a passenger, an often heard bit of advice, is about right.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
rickofudall
Posted: Thu May 09, 2013 6:42 am Post subject: Lift Reserve Indicator |
I sent the article to start a discussion since the Kolb list has been pretty quiet these days and it achieved that goal.In defense of the idea, where is that most stall/spin accidents occur? At low speeds while approaching or departing an airport. Jim's indicator, as you can see from the picture, is located at the top of his panel where it can attract attention during that critical phase when the pilot's eyes should be outside the cockpit looking for traffic.
We've lost one list member to a landing stall/spin on his very first flight in his newly completed IIIX. Would an LRI helped? No way to know, but angle of attack gauges are the latest rage to combat the stall/spin accident and Jim came up with a homebuilder's solution that's inexpensive and uncomplicated.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rowedenny
Posted: Thu May 09, 2013 7:08 am Post subject: Lift Reserve Indicator |
I read below that we lost a member in a stall spin accident, I've been off list for quite a while and had missed this. I'm saddened to hear, but have to ask who it was?
Skid Rowe
Mk 3 2si 690, PA
On May 9, 2013, at 10:41 AM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote] I sent the article to start a discussion since the Kolb list has been pretty quiet these days and it achieved that goal.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
rickofudall
Posted: Fri May 10, 2013 5:49 am Post subject: Lift Reserve Indicator |
Dennis, it was a few years ago. Scott, as I recall, was his first name, sorry I forget his last (England?) He and his partner built a beautiful Mk IIIX. He was a new pilot with a Sport Pilot ticket and spun in when he stalled the airplane on the base to final turn.
Rick
On Thu, May 9, 2013 at 10:06 AM, Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
Quote: | I read below that we lost a member in a stall spin accident, I've been off list for quite a while and had missed this. I'm saddened to hear, but have to ask who it was?
Skid RoweMk 3 2si 690, PA
On May 9, 2013, at 10:41 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Quote: | I sent the article to start a discussion since the Kolb list has been pretty quiet these days and it achieved that goal.In defense of the idea, where is that most stall/spin accidents occur? At low speeds while approaching or departing an airport. Jim's indicator, as you can see from the picture, is located at the top of his panel where it can attract attention during that critical phase when the pilot's eyes should be outside the cockpit looking for traffic.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rlaird
Posted: Fri May 10, 2013 5:55 am Post subject: Lift Reserve Indicator |
Quote: | I read below that we lost a member in a stall spin accident, I've been off list for quite a while and had missed this. I'm saddened to hear, but have to ask who it was? |
August 10, 2009 (from a John Hauck email on the Kolb-List):
"Brad Stump, flying his Kolb MKIIIx, and a passenger died Saturday.
Brad trailered his MKIIIx to the Kolb Homecoming last year. http://www.wrcbtv.com/Global/story.asp?S=10878641 The accident is also listed in the FAA Preliminary Accident Reports for 10 Aug."
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
rickofudall
Posted: Fri May 10, 2013 6:25 am Post subject: Lift Reserve Indicator |
Different accident Robert.Here's the NTSB Factual Report
http://dms.ntsb.gov/aviation/AccidentReports/xmceaj45y0stth45pylpnl551/J05102013120000.pdf
and here's the final
http://dms.ntsb.gov/aviation/AccidentReports/5ulae355krrtfn45s0twgm2t1/G05102013120000.pdf
Rick Girard
On Fri, May 10, 2013 at 8:55 AM, Robert Laird <rlaird(at)cavediver.com (rlaird(at)cavediver.com)> wrote:
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Mike Welch
Posted: Fri May 10, 2013 6:34 am Post subject: Lift Reserve Indicator |
Two things.
First, Rick Lewis: You mentioned something about a pilot being concentrated too much on
"electronic gages". For the record, the Lift Reserve Indicator shared to the list by Rick G
is ONLY a sensitive air pressure gage, and necessary tubing and pitot mast. No electronics.
Listers: If anyone on the list is interested, I have the "real" thing, i.e., the Lift Reserve Indicator" made and
sold by LRI, Inc. As Rick G mentioned, the gage is a super sensitive Dwyer (I have 4 additional gages
I bought on eBay ( 0-2psi)
The pitot mast is an easily duplicated aluminum fixture. Detailed photos upon request.
Aircraft Spruce sells the red/green/ yellow curved arc gage stick-ons.
Lift Reserve Indicator. Some pilots will like them. Some will think they are a waste of time.
Mike Welch
