		| Author | Message |
		| Jacquescj6
		| Back to top |  |
		| dsavarese0812(at)bellsout Guest
				|  Posted: Tue Apr 30, 2013 3:47 pm    Post subject: cj6 mag problems |   |
				| Did you check the high voltage wick that sticks up into the distributor
cap?  Many times they are cracked and as soon as the coil fires, it goes
 directly to ground because of the crack in the high voltage wick.   Try
 removing the wick and examine it very carefully.  Look for carbon traces
 to ground around the hole.  They are not too pricey.  So you may want to
 just replace it anyway.  I am pretty sure Doug has new ones. If not,
 Jill at M14P has them.  They are the same for the M14 M9F or M9-35 mags
 as they are for the Housai mags.
 Dennis
 A. Dennis Savarese
 334-285-6263
 334-546-8182 (mobile)
 www.yak-52.com
 Skype - Yakguy1
 On 4/30/2013 5:03 PM, Jacquescj6 wrote:
  	  | Quote: |  	  |
 Hi all
 When I did a mag check this morning the no 2 mag was completely dead ie. Engine stop running on only mag no2.
 I flew two days before and there were no indication of any problems.
 We checked the grounding from the switch all good checked the points are opening and closing.
 Any idea where I can look for the problem?
 [Crying or Very sad]
 http://forums.matronics.com/viewtopic.php?p=399706#399706
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| mark.bitterlich(at)navy.m Guest
				|  Posted: Wed May 01, 2013 9:06 am    Post subject: cj6 mag problems |   |
				| Dennis already very correctly pointed out the "cigarette" as it is
sometimes called.  Remove it. Inspect it.  Replace it just to be safe.
 You said the points open and close.  Recommend you be slightly more
 detailed than that.  I have had the point arm crack (basic metal
 fatigue) and yes ... they were opening and closing, but the gap was ALL
 wrong.  So check the point gap and make sure it is set correctly.
 Along the same lines, connect a mag buzzer box and make sure that both
 mags are timed close to the same value.  These mags have internal GEARS
 that have been known to have the teeth wear down and then jump a tooth
 or two.  This will throw one mag so totally out of time to where it will
 not fire the cylinder at all.
 If the mag is in time, (checked with mag "buzzer box" timing tool) the
 points are set correctly, and the high tension extender (cigarette) is
 not damaged and you are sure that there is NO GROUND on the P lead when
 the mag switch is turned on, then it is most likely an internal mag coil
 failure.
 Mark Bitterlich
		| Back to top |  |
				|  Posted: Wed May 01, 2013 9:47 am    Post subject: cj6 mag problems |   |
				| I forgot to mention a few more things:
 Before you give up and decide the coil is bad, take a very careful look
 at the mag rotor and cap.
 On the rotor:
 1. Make sure it has both metal points showing.  I.E. On the rotor make
 sure the little metal tabs that strike the cap as it rotates are intact
 and not broken off in any way.  Rare, but it can happen and it is very
 easy to miss.  Only one of them is used on the #2 mag, but heck, just
 check them both.
 2.  Make sure the rotor itself is not LOOSE where it is screwed into the
 mag.  It has three screws that hold it down tight.  Make sure those
 screws did not come loose so that the entire rotor itself shifted.
 On the Cap:
 Check for electrical continuity from where the cigarette sticks up into
 it, over to the carbon point in the middle that in turn makes contact
 with the rotor itself.  Again, this is an extremely rare thing to fail,
 but if you tear the whole mag apart to replace a very expensive mag
 coil, only to find out you had a cheap mag cap failure, you'll be upset!
 And it is easy to check.
 The above stuff is so rare to ever fail, I forgot to even think of
 telling you to check it, so don't hold out that it will be this easy,
 but hey... some people get lucky!  Not me, but hopefully you.
 Mark
 p.s.  If all else fails, and you take the mag out of the engine, hold
 onto the top of the cigarette (under the cap) and have someone give the
 mag a good ole spin from the bottom.  If you yell out loud in agony and
 surprise, and throw the mag 10 feet up into the air, the coil is
 probably not the problem either.
		| Back to top |  |
		| Jacquescj6
		| Back to top |  |
				|  Posted: Wed May 01, 2013 2:46 pm    Post subject: cj6 mag problems |   |
				| BINGO!!!!  Glad you found the cigarette to be the problem.  FWIW, not an uncommon problem.
Dennis
 To: yak-list(at)matronics.com
 Sent: Wed, May 1, 2013 3:58:37 PM
 Subject: Re: cj6 mag problems
		| Back to top |  |
				|  Posted: Thu May 02, 2013 3:36 pm    Post subject: cj6 mag problems |   |
				| Good one Dennis.
 Sent: Wed 5/1/2013 6:44 PM
 Subject: Re: Yak-List: Re: cj6 mag problems
 Dennis
 Subject: Yak-List: Re: cj6 mag problems
		| Back to top |  |
