RV-10 Electric system
trigo(at)mail.telepac.pt
PostPosted: Wed May 01, 2013 8:35 am    Post subject: RV-10 Electric system Reply with quote
Hi there
It's time to think about and design the electric system, so can you guys
please tell me which system did you use.
Did you follow one of Bob Nuckolls architecture systems? Which one?
Yes, I know that I have to do the load analysis.
Carlos
flying-nut(at)cfl.rr.com
PostPosted: Wed May 01, 2013 9:12 am    Post subject: RV-10 Electric system Reply with quote
I found this on the 'net. Probably a good place to start. I used it as
a guide but added lots of things.
Linn
On 5/1/2013 12:35 PM, Carlos Trigo wrote:
Hi there
Carlos
Checked by AVG - www.avg.com
RV10_WIRING.PDF
 Filename:  RV10_WIRING.PDF
 Filesize:  1.49 MB
 Downloaded:  4719 Time(s)
rleffler
PostPosted: Wed May 01, 2013 9:16 am    Post subject: RV-10 Electric system Reply with quote
I used a VP/X Pro.
Even if you don't use a Vertical Power unit, their planning tools can assist you with your load planning. They have both an online Configurator and an excel spreadsheet.
Their units will speed up your electrical planning and implementation time.
On May 1, 2013, at 12:35 PM, "Carlos Trigo" <trigo(at)mail.telepac.pt> wrote:
Hi there
Carlos
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
robin(at)PaintTheWeb.com
PostPosted: Wed May 01, 2013 9:44 am    Post subject: RV-10 Electric system Reply with quote
I built two planes w/o using Vertical Power. If I ever build another I hope I don't make the same mistake a third time.
Robin
jesse(at)saintaviation.co
PostPosted: Wed May 01, 2013 9:45 am    Post subject: RV-10 Electric system Reply with quote
I agree completely. While I am disappointed that VP has somewhat abandoned their focus on electrical systems for a period of time, their VP-X will save you a great deal of time and frustration in planning and wiring your plane. You will be glad you did it. It will also clean up your panel a great deal, because of the elimination of so many breakers and some switches.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On May 1, 2013, at 1:16 PM, Bob Leffler <rv(at)thelefflers.com> wrote:
I used a VP/X Pro.
> Hi there
> Regards
> Carlos
schmoboy
PostPosted: Wed May 01, 2013 10:13 am    Post subject: RV-10 Electric system Reply with quote
If there's one thing I don't regret when I bought my avionics and did my
panel early, it was the VP-200. It's a shame it was discontinued.
Guess that doesn't help you now, but... It was all Greek to me until I
read Bob's Aeroelectric Connection book. Even with having the VP-200
there's a ton of useful information in there. Well worth it.
-Sean #40303 (wrapping up FWF)
Robin
rv10flyer(at)live.com
PostPosted: Wed May 01, 2013 10:47 am    Post subject: RV-10 Electric system Reply with quote
Agree with the VP disappointment!
Carlos;
when considering the wiring, consider the "initial" panel and overall
layout. For example a Dynon Skyview will interface with the VP-X, not sure
if Garmin will. Layout the landing light, nav light, basically the complete
layout where everything will go, than consider the wiring required, If you
go the VP-X route Verticalpower.com has a planning sheet for the VP-X, may
help you regardless of what you decide to do.
Site Admin
PostPosted: Wed May 01, 2013 11:01 am    Post subject: RV-10 Electric system Reply with quote
At 11:12 AM 5/1/2013 Wednesday, you wrote:
If there's one thing I don't regret when I bought my avionics and did my panel early, it was the VP-200. It's a shame it was discontinued.
>Robin
I couldn't agree more. I have a VP-200 system in the RV-8 and in the RV-6 and I couldn't imagine not flying with one. I've got well over 300 hours on the two systems without a single issue. The electrical automation that the VP-200 brings to the cockpit is outstanding. The simplification of wiring can't be understated. I am also very disappointed that Vertical Power hasn't stayed focused on what they are really good at - electronically controlled aircraft electrical systems. Hopefully VP will come out with something more akin to the 200 in the future.
Status: 150+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
 Filesize:  202.82 KB
 Viewed:  11336 Time(s)
 Filesize:  192.14 KB
Mauledriver(at)nc.rr.com
PostPosted: Wed May 01, 2013 1:35 pm    Post subject: RV-10 Electric system Reply with quote
Not sure where the line is drawn between the electrical system
(electrical power) and the avionics.
I used Bob's Z-14 (Dual alts, dual batts, dual busses) which I
understand to possibly be overkill but an overkill I've really enjoyed
flying with. No modification to his design, just selection of
components and load balancing. Used fuses for everything except for 2
req'd breakers for the regulators, 1 breaker for the AP (it's my
emergency kill switch), and 1 breaker for the flaps because I thought it
was a good idea.
I found Van's electrical plan and kit to be a great starting point for
wire routing and RV10 specific brackets and stuff.
For avionics I used Approach Fast Stack's hub to handle the panel
interconnections. If you decide to do your own panel, this is
definitely a great way to go.
I never broke into the VP stuff but it must be good at the stuff it does.
Bill Watson
Hi there
Carlos
rv10flyer
PostPosted: Wed May 01, 2013 6:49 pm    Post subject: Re: RV-10 Electric system Reply with quote
I have one 5 Amp alt circuit breaker, main/e-bus/hot battery bus fuse blocks, a bunch of toggle switches, a wiring harness from Stein, a 925L bat, a 680 bat and one 60A alternator. Has worked flawlessly and love my setup.
Wayne G.
PostPosted: Thu May 02, 2013 12:40 am    Post subject: RV-10 Electric system Reply with quote
Guys
Thank you all for your answers!
Great group.
Now, it's only brainstorming and work on the electric system ...
Cheers
Carlos
bob88
PostPosted: Tue May 07, 2013 11:05 am    Post subject: Re: RV-10 Electric system Reply with quote
I, too, am in the early stages of planning an electrical system. Vertical Systems seems to get the kudos. Does anyone have experience with the Protec Bus Manager? I am unclear about whether this could be used along with the VP product. Not sure if there is overlap/compatibility.
marcausman
PostPosted: Mon May 13, 2013 12:52 pm    Post subject: Re: RV-10 Electric system Reply with quote
bob88,
The VP-X should be used by itself without other bus managers like the one you mention.
The VP-X installation manual (available here: http://verticalpower.com/documents/ ) shows you how to provide system-level redundancy in case of a failure.
Hope that helps. Very Happy
Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying
