Europa monowheel trailer, fuselage support
Richard Lamprey
PostPosted: Mon Apr 29, 2013 10:29 pm    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Good morning all,
I have photos of the original Europa monowheel trailer, from the factory (when I visited in 1995), and from other kind contributors to this site. The factory one has G-ELSA parked in it, so in the photos the wings obscure the fuselage. Photos from others don't have the Europa in it.
I have the only Europa in this region of the world, so I cant see a trailer in real life, all I have is photos.
This may sound stupid, but I can't for the life of me work out what keeps the fuselage upright, except for the mainwheel and leg lodged in their hinged cradle. There must be significant forces on the cradle, its hinge, and on the undercarriage swinging arm and its hinges onto the undercarriage frame.
There is a gap between fuselage and wing cradles, so the cradles don't seem to be doing any support.
So it would seem that the wheel cradle keeps the whole plot upright, and strong enough to counter any tipping forces as the thing goes around corners. This might be fine for mirror smooth UK country lanes at 40 km/hr, but on our Kenya roads, which are mostly holes, this isn't going to work.
Perhaps I have missed something here. Does anyone have a Europa factory-style monowheel trailer with fuselage supports, or a fuselage cradle? And can send me pictures?
Richard
Kenya
philipgeorge347(at)hotmai
PostPosted: Tue Apr 30, 2013 1:20 am    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Richard i built my own version of the factory trailer and yes the only support for the fuselage is the ramp ally channel that fits snugly either side of the u/c main channel . I added two support pad blocks  4"x4" between the the wing sling supports and the side of the fuselage.  These pads sit against the area of the fuselage covered by the wing root in front of the spar hole . The pads are made from plywood covered in upholstery foam and PVC ect. It works well and takes the sideways rock out of the fuselage , if i can find some photos i will send them .
                                      Phil George  (G-EORJ)  mono
Subject: Europa monowheel trailer, fuselage support
Date: Mon, 29 Apr 2013 23:29:13 -0700
--> Europa-List message posted by: "Richard Lamprey" <lamprey.richard(at)gmail.com>
Good morning all,
Richard
Kenya
http://forums.matronics.com/viewtopic.php?p=399643#399643
dave.glowa(at)termrim.co.
PostPosted: Tue Apr 30, 2013 1:30 am    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Richard
You may find the answers to your question if you go to the Europa Club Gallery, Bob Borger has posted a set of pictures for the monowheel trailer dated 6th December 2012.
I am also at the stage where I need a trailer and I too have concerns as to whether the Europa trailer can cope with our roads, you have probably got better ones than we have in West Yorkshire.
If anyone has got the dimensions available I would be pleased to know. If you can build a plane I am sure you can build the trailer.
Dave Glowa
davidjoyce(at)doctors.org
PostPosted: Tue Apr 30, 2013 1:44 am    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Richard, An alternative is to build a dolly for the plane
which bolts tightly on to the plane with 4 bolts into
captive (potted in) nuts in the fuselage with the dolly
fixed to the trailer with wing nut bolts. The dolly is
extremely useful for working on the plane and worth having
in its own right. For this to work nicely you need a flat
bed trailer, or better still of course a covered one.
Regards, David Joyce, GXSDJ
On Mon, 29 Apr 2013 23:29:13 -0700
Good morning all,
in it.
going to work.
pictures?
Richard
Kenya
Un/Subscription,
Forums!
Admin.
ward.t(at)xtra.co.nz
PostPosted: Tue Apr 30, 2013 1:54 am    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Richard,
I installed a foam support between the wing support and the fuselage to keep the fuselage in situ.
I glued the dense foam to the top 8 inches to the inside of the support and shaped the other side to the same line as the fuselage where it meets. So when you raise the supports after loading the aircraft onto the trailer the supports comfortable stand upright in place with the foam against the fuselage. Foam is good as it allows the fuselage to move in situ, enough to cope with the bumps in the road.
Can do a photo if you like.
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Ph 64 3 3515166
Mob 0210640221
On 30/04/2013, at 9:30 PM, Dave Glowa <dave.glowa(at)termrim.co.uk (dave.glowa(at)termrim.co.uk)> wrote:
[quote] st1\:*{behavior:url(#default#ieooui) } <![endif]-->
Richard
Dave Glowa
tp://www.matronics.com/Navigator?Europa-List
cs.com
matronics.com/contribution
flyingphil2
PostPosted: Tue Apr 30, 2013 2:35 am    Post subject: Re: Europa monowheel trailer, fuselage support Reply with quote
This is a very timely thread for me as I'm just in the process of doing a few mods on a mono trailer.
I'd be very grateful if some of the previous posters could post or send some photos of their solutions. The only other one I know of is Raimo's idea which has some small pads welded to the wing carriers that hold the fuselage stable. There is a photo of that on this forum if you search hard enough.
Phil
hagargs(at)earthlink.net
PostPosted: Tue Apr 30, 2013 5:16 am    Post subject: Europa monowheel trailer, fuselage support Reply with quote
This Youtube video shows the dolly I made for my plane it also establishes the tie down points to the trailer. The unit is sturdy enough to do full throttle runups without the wings on. Takes about 3 minutes to install / remove
http://www.youtube.com/watch?v=BHYtCRwemiA
Steve Hagar
A143 Mesa AZ
h&jeuropa
PostPosted: Tue Apr 30, 2013 8:28 am    Post subject: Re: Europa monowheel trailer, fuselage support Reply with quote
We capture the main tire like the factory trailer does but also use a support similar to the one Steve Hager shows. Ours is more like the one used at Flightcrafters (see Europa Flyer Issue 40 page 2) but reversed so it is parallel to the swing arm like Steve shows. We just clamp the support to the swing arm and insert wood shims under the wheels when the airplane is secure in the trailer. We've trailered our Europa over 4000 miles this way.
Jim & Heather
N241BW
gavanne(at)iconz.co.nz
PostPosted: Tue Apr 30, 2013 5:20 pm    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Hi there,
What I did to my trailer was bond a neoprene block on each side of the wing cradle upright, carved to fit snug against the fuselage when the wing cradle is upright. Worked well and solved the problem of the fuse possibly rubbing against the metal uprights during towing.
Gavin Lee. #355
ZK -EPA
On 30/04/2013, at 6:29 PM, "Richard Lamprey" <lamprey.richard(at)gmail.com> wrote:
Good morning all,
Richard
Kenya
Richard Lamprey
PostPosted: Wed May 01, 2013 5:43 am    Post subject: Re: Europa monowheel trailer, fuselage support Reply with quote
Thank you everyone, Gavin, Jim & Heather, Tim, Steve, Phil, Dave, David and Philip, for your very helpful responses. And also Ferg Kyle in Canada, who sent me the trailer blueprints. What a great forum this is!
I'll be looking at a combination of Steve's dolly, with a side-support of one of the many described. Tim, in NZ, if you could send a picture, much appreciated (and by the way I fitted your Artex ELT transmitter plate you told me about last year.... It seems to pass the test, many thanks!).
Best to all
Richard
Kenya
PostPosted: Wed May 01, 2013 7:49 pm    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Will send a photo as soon as I am at home. In Shanghai at the moment.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 2/05/2013, at 1:43 AM, "Richard Lamprey" <lamprey.richard(at)gmail.com> wrote:
Best to all
Richard
Kenya
http://forums.matronics.com/viewtopic.php?p=399758#399758
Fred Klein
PostPosted: Thu May 02, 2013 11:50 am    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Steve Hagar
Steve...thank you so much for linking to the video...excellent design...!...solving several sticky problems for the mono-wingless.
I want to replicate your dolly and have found a source for that clever extrusion which allows for height adjustment of the wheels.
A question: My source (Grainger) for the extrusion (1.5" x 3" x 72") sells it in 6 ft. lengths...do you recall whether or not ONE pc. was sufficient?
Fred
PostPosted: Thu May 02, 2013 4:10 pm    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Fred:
I used 2 different sizes of extrusion so as not to have any concerns over strength and stiffness. The legs are 1.5 X 3 cross section material. The horizontal cross member is 3 X 3 cross section. Possibly double up with the smaller stuff. I am attaching a pdf and 2 auto cad versions of the drawing to give you the exact details. If you have any issues opening any of these get in touch at hagargs(at)earthlink.net (hagargs(at)earthlink.net) to possibly get a hard copy if you want it.
Steve
A143 Mesa, AZ
[quote]--
Landing+gear+dolly.dwg
 Filename:  Landing+gear+dolly.dwg
 Filesize:  157.56 KB
 Downloaded:  568 Time(s)
Landing+gear+dolly+pdf.pdf
 Filename:  Landing+gear+dolly+pdf.pdf
 Filesize:  43.89 KB
 Downloaded:  533 Time(s)
Landing+gear+dolly-A-LT.dwg
 Filename:  Landing+gear+dolly-A-LT.dwg
 Filesize:  111.32 KB
 Downloaded:  572 Time(s)
Fred Klein
PostPosted: Thu May 02, 2013 7:15 pm    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Steve,
Thanks for your help. After re-watching your video, I'm chagrined to have not noticed the 3 x 3 cross member.
BTW, do you use your dolly when changing a tire?...presumably by raising and temporarily supporting your tail...?...(and is that the reason you've made your cross member so stout?
Fred
On May 2, 2013, at 5:09 PM, hagargs wrote:
[quote]Fred:
I used 2 different sizes of extrusion so as not to have any concerns over strength and stiffness. The the smaller stuff. I am attaching a pdf and 2 auto cad versions of the drawing to give you the exact details. If you have any issues opening any of these get in touch at hagargs(at)earthlink.net (hagargs(at)earthlink.net) to possibly get a hard copy if you want it.
Steve
A143 Mesa, AZ
[quote]--
raimo.toivio(at)rwm.fi
PostPosted: Mon May 13, 2013 5:56 am    Post subject: Europa monowheel trailer, fuselage support Reply with quote
Hi Phil
I took couple of new photos and they are attached.
You can find at least four Europa mono trailer
mods, which all are important (at least I think
so):
1) Fuselage support "pads". a Fuselage side of
them is softened. They are not welded - they are
removable as my daughter shows. That is a must to
make a fuselage moveable. The wing carriers are
not very stable by nature. They are normally fixed
by pip-pins only. I added locking bolts also and
now they are like welded. An extra advantage:
fuselage must be very straight before dropping
those pads to the wing carriers. These pads reduce
some heavy sideway loads from the gear /main wheel
swing. Green and red colour are just for fun.
2) Douple axle. 2nd axle is totally useless until
you really need it! Just one axle and an explosing
tire etc could be a first class disaster and
spoiling your fun for ever. Yes - there are
several people driving decades w/o safety belts
also...
3) A Trailer floor. To make a trailer stronger, to
keep an Europa cleaner and without damages when
towing. When a trailer is garaged /hangared a
floor is also useful to keep things on it. A
trailer with a floor has even multipurpose tasks.
4) Doupled tail lights. To make night operations
more safety Wink
Wishes, Raimo
OH-XRT
-----Alkuperäinen viesti-----
Sent: Tuesday, April 30, 2013 1:35 PM
Subject: Re: Europa monowheel
<flyingphil627-europastuff(at)yahoo.co.uk>
search hard enough.
Phil
http://forums.matronics.com/viewtopic.php?p=399651#399651
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
 Filesize:  137.46 KB
 Viewed:  12850 Time(s)
 Filesize:  134.84 KB
