bob88
Posted: Tue Apr 23, 2013 12:08 pm Post subject: Engine purchase |
I have located Lycoming IO540 C4B5 (as opposed to the Vans current D4A5 model) with 700 hr on it for $18.5K. Anyone have opinions about the price or the difference in the model?
rene(at)felker.com Guest
Posted: Tue Apr 23, 2013 12:21 pm Post subject: Engine purchase |
That is what I have on my RV-10. Did not have any problems with it.
No opinion on price. But, I bought a used engine and regretted it. Really
sis not save me enough to make a difference.
Rene' Felker
N423CF
801-721-6080
Posted: Tue Apr 23, 2013 12:22 pm Post subject: Engine purchase |
The C4B5 is virtually identical, except it may have the different engine mount ears (which you can change out). What plane did it come out of? What accessories does it have. If it is a complete engine with good Fuel Injection system, mags with 500 hr check done, good harnesses, starter, ring gear, fuel pump, etc, and NO PROP STRIKE, then you might have a good buy. You can run the C4B5 at 2,700rpm for 260HP if you have the 8.5:1 pistons. If it was originally setup as 250HP, then they were running it at 2,575rpm. If it was 235HP, then it would be the lower compression pistons (7.2:1, I think). We have 1,300 hours on our C4B5 now and it keeps on going.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Apr 23, 2013, at 4:08 PM, bob88 <marty.crooks(at)comcast.net> wrote:
Kelly McMullen
Given that most fresh overhauled and new engines are north of $40K now, doesn't sound bad, depending on how old since last overhaul in calendar time, what kind of use it had and whether there is any hint of a prop strike in its history.
There is no difference in model, just in rpm limit on data plate. At 2575 redline it is rated at 250 hp. Dial the governor up to 2700 and it makes 260 and is now a D4A5.
On Tue, Apr 23, 2013 at 1:08 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
| Quote: | --> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=399236#399236
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
Rhonda(at)bpaengines.com Guest
Posted: Tue Apr 23, 2013 1:22 pm Post subject: Engine purchase |
Bob:
Seems like a good price if you are going to put it on your airplane as a
mid-time engine. Too much to pay if it is in need of overhaul. Things
to verify include whether or not the crankshaft is affected by any of
the ADs requiring replacement, whether it is complete, does it have
corrosion in the cylinders or on the cam/lifters. Also, verify if it
has cylinders that are affected by any SB or AD.
I would want the seller to guarantee that the crankshaft and crankcases
are repairable if it were me. If I were you, I'd ask to see the
logbooks and detailed parts list if the 700 hours are from overhaul
rather than new.
Good luck!
Rhonda Barrett-Bewley
Barrett Precision Engines
2870-B N. Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1754 fax
www.barrettprecisionengines.com
rleffler
Posted: Tue Apr 23, 2013 2:18 pm Post subject: Engine purchase |
You may want a local a&p to take a peek at the cylinders. A friend purchased a used engine that had been setting for a year in Las Vegas. That's not a place where you would expect moisture issues. Sure enough, a boroscope found some corrosion. He ended up negotiating a significant discount, which paid for a top overhaul from Rhonda and Allan. After Allan was finished, he now has an engine in a very known state.
I would give Rhonda a call directly. She'll make sure you know all the questions to ask and what typical costs are if you need them to overhaul all or just parts. Then you'll be well armed to negotiate.
You can't get better support than what Rhonda and Allan provides.
Bob
On Apr 23, 2013, at 5:21 PM, "Rhonda Bewley" <Rhonda(at)bpaengines.com> wrote:
Bob:
rather than new.
Good luck!
Tulsa, OK 74115
(918) 835-1754 fax
_________________ Bob Leffler
N410BL - Phase I
johngoodman
Posted: Tue Apr 23, 2013 2:56 pm Post subject: Re: Engine purchase |
At that price, make sure it was never on an Airboat....
_________________ #40572 Phase One complete in 2011 |
dmasys
Posted: Wed Apr 24, 2013 4:49 am Post subject: Engine purchase |
| Quote: | Time: 01:09:08 PM PST US
Subject: Engine purchase
model)
| Quote: | with 700 hr on it for $18.5K. Anyone have opinions about the price or the
difference
I found a really amazingly good deal advertised in Trade-a-Plane for a
newly rebuilt IO-360 engine, overhauled by an A&P/IA, for my RV-7A. The
engine failed catastrophically at 85 hrs. The seller is now in federal
prison in Oklahoma, and I get a small check from the Dept. of Justice about
twice a year, which will repay the price of the engine (as mandated by the
courts) in about 80 years. When disassembled by an FAA authorized repair
station, the engine contained parts that were stamped "Not Airworthy".
Not everybody in aviation is honest. When I built the RV-10, the clear
choice was a factory new engine, which has performed flawlessly for the past
600 hrs TTSN.
Caveat emptor...
Dan Masys
RV-10 N104LD
RV-12 N122LD
Kellym
Posted: Wed Apr 24, 2013 6:11 am Post subject: Engine purchase |
While there are always bad actors, one also has to understand that
choices are often made between seller/overhauler and the customer that
affect the end result.
Engines for experimental aircraft do not have to meet the standards for
certified engines. That can be good or bad. Parts can be reused that
would be rejected for certified engines. Some may be fine, others
dangerous. There isn't a universal answer.
If one doe not have the expertise to make those choices, then sticking
with a reputable shop or factory may be the best choice.
Some of us have the knowledge and ability to custom build an engine for
our project, but choose to not do so for many reasons, including getting
flying sooner rather than later.
I just did a safety seminar discussion on the crash of an RV-6, where
the owner chose to weld repair the governor line from the rear mounted
governor to the front of the engine. Such a repair is prohibited on
certified Lycoming engines by AD, for good reason. The repair failed and
the owner did not survive the ensuing crash.
Choose wisely.
Kelly
A&P/IA
On 4/24/2013 5:46 AM, Dan Masys wrote:
> From: "bob88" <marty.crooks(at)comcast.net>
model)
difference
> in the model?
600 hrs TTSN.
Caveat emptor...
Dan Masys
RV-10 N104LD
RV-12 N122LD
Checked by AVG - www.avg.com
KCHD |
cooprv7(at)yahoo.com Guest
Posted: Wed Apr 24, 2013 7:03 am Post subject: Engine purchase |
I had a similar RV-6 event with an O-360 overhauled by an engine shop, although the parts were correct they were not assembled correctly and the engine self destructed at about 80 hours. For my Skybolt I got an 1100 SMOH engine from an Aztec that a hanger fell on. Worked great. While a freshly overhauled engine should be the way to go in a perfect world, and you certainly should get more life out of it, there is something to be said about an engine that has already been running for a while and proved that the mechanic didn't come up short somewhere. I put a new IO-540 from Aerosport in the RV-10 and it has also worked great. So nothing definitive, but a couple things to consider.
IMHO a 8
700 hour engine will give you plenty of time left before you should have to do anything. I'd be more concerned about how recently it ran and what sort of life it had during those 700 hours.
Marcus
model)
difference
600 hrs TTSN.
Caveat emptor...
Dan Masys
RV-10 N104LD
RV-12 N122LD
