mounting hinges
nickc(at)mtaonline.net
PostPosted: Tue Apr 09, 2013 9:36 am    Post subject: mounting hinges Reply with quote
Hello Kolbers,
I have built my wings, horizontal stabilizers, and vertical stabilizer. Now I need to mount my hinges…I remember someone split each hinges into thirds and mounted the hinge on both sides of the center line, on the trailing edge tube, rather than having the hinge mounted all on one side. This seems like a good idea to me, but I cannot find the “posts” in the Archives. I would be grateful if anyone has thoughts on the pro’s or con’s of this approach.
Nick Cassara
Palmer, Alaska
N607AK Kolbra #1
Ralph B
PostPosted: Tue Apr 09, 2013 10:51 am    Post subject: Re: mounting hinges Reply with quote
"nickc(at)mtaonline.net"
Hello Kolbers,
Nick Cassara
Palmer, Alaska
N607AK Kolbra #1
Nick, my Kolbra was built according to plan and the hinges were not split.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
byoungplumbing(at)gmail.c
PostPosted: Tue Apr 09, 2013 11:23 am    Post subject: mounting hinges Reply with quote
I went into the search engine and did a search on “x hinges” found this http://www.mindspring.com/~possums/Xhingestrailingedge.jpg   and http://www.mindspring.com/~possums/HINGESML.jpg if you do the search, you may find more. as I remember, you have to cut out every other spot on each hinges that the wire hinge pin goes through. I have no experience to determine if it is a good idea or not. hope this is what you are looking for.
boyd young
Sent: Tuesday, April 09, 2013 11:36 AM
Subject: mounting hinges
Hello Kolbers,
Nick Cassara
Palmer, Alaska
N607AK Kolbra #1
Carolina Flyer
PostPosted: Wed Apr 10, 2013 12:12 am    Post subject: Re: mounting hinges Reply with quote
Nick,
Here is a Picture of the X-Hinge I am using on my Firestar II. I do not know if these can be bought but they are very easy to make. It takes twice as much hinge to make these. Some people think less is better, but I think I need to make things as good as I can if my life is depending on it. This is by far stronger, and maybe even over-kill but I will bet this set-up is less likely to fail.
Best Regards Joe
 Filesize:  75.95 KB
 Viewed:  9094 Time(s)
Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
View user's profile Send private message Yahoo Messenger
Richard Pike
PostPosted: Wed Apr 10, 2013 4:45 am    Post subject: Re: mounting hinges Reply with quote
You can also split them this way:
 Filesize:  59.49 KB
 Viewed:  9080 Time(s)
 Filesize:  63.81 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Wed Apr 10, 2013 5:16 am    Post subject: mounting hinges Reply with quote
Ref x hinges.
See if I can figure this out.
Cut half the loops off the hinge resulting in a stronger hinge?
Lot of work compared using the whole hinge.
There is no problem with current hinges or Kolb method of attachment.
Johnh
MkIII
Lakeland, FL
PostPosted: Wed Apr 10, 2013 5:36 am    Post subject: mounting hinges Reply with quote
I erred I my previous post. Didn't realize it took twice as much hinge for x hinge.
John h
MkIII
Lakeland, FL
Ralph B
PostPosted: Wed Apr 10, 2013 6:05 am    Post subject: Re: mounting hinges Reply with quote
Using the full hinge mount per plan lasts a long time as my Firestar is built that way and has 1000 hrs. Also, I removed the book-binding tape between the aileron and wing and didn't notice one bit of difference in banking the Kolbra.
John H: you can use the "edit" button to the right when making corrections in your posts. There is no need to write another post. It will make the changes in your original post. I may have mentioned this before, but it bears repeating.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
ceengland7(at)gmail.com
PostPosted: Tue Apr 16, 2013 3:34 pm    Post subject: mounting hinges Reply with quote
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
1000+ hours
26 years flying it
Kolbra 912ULS
N20386
200 hours
I don't know which method John uses, but if he's using email (I do),
posts can't be edited after sending.
Ralph B
PostPosted: Tue Apr 16, 2013 4:55 pm    Post subject: Re: mounting hinges Reply with quote
"ceengland7(at)gmail.com"
The editing can be changed after sending if you are posting on the matronics.com forum. If you are doing it by email, then it can't be edited after sending. Thanks for pointing that out.
Ralph B
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
Dana
PostPosted: Tue Apr 16, 2013 5:23 pm    Post subject: mounting hinges Reply with quote
Note too that those of us who receive the posts by email will only get the original unedited version...
Dana
The supreme irony of life is that hardly anyone gets out of it alive. - RAH
