johngoodman
Posted: Sun Apr 07, 2013 6:40 am Post subject: Butt Splice for #4 wire |
I have a #4 wire I need to put a new ring terminal on. It will make a tight reach. I think it will work, but I considered a #4 butt splice - they make 'em. If my new ring terminal makes it too short, my choice is adding a few inches of new #4 with a butt splice, or replacing the entire 5 foot length (which won't be easy to do).
Opinions, please
Posted: Sun Apr 07, 2013 6:55 am Post subject: Butt Splice for #4 wire |
At 09:40 AM 4/7/2013, you wrote:
<johngoodman(at)earthlink.net>
How much original wire is easily accessible?
It would be decidedly unhandy to have a splice
in close proximity to the terminal end. Can you
cut the original wire back before splicing on
the extension?
What kind of #4 wire?
johngoodman
Posted: Mon Apr 08, 2013 5:37 am Post subject: Re: Butt Splice for #4 wire |
It's #4 welding wire. I have access to about 18" of it before it passes behind the engine to the alternator. I get what you are saying - don't put a butt splice close to the terminal.
I worked on it yesterday and the break was very close to the terminal. I was able to put a new terminal on, losing only an inch or so of wire. I had to make a minor reroute change, but made it fit. My biggest issue was keeping it away from the exhaust pipes. I got it 2" away from the pipes and put a leftover piece of firesleeve on it.
My biggest surprise was how the cable fatigued so fast. Obviously, engine vibration took it's toll.
PS: I like your new book being bound, but I still like the ability to remove a page for immediate reference. I keep both copies at the hangar.
bbradburry(at)bellsouth.n Guest
Posted: Mon Apr 08, 2013 5:48 am Post subject: Butt Splice for #4 wire |
John,
Are you saying that engine vibration caused a metal fatigue break in #4
welding wire while you were flying off your Phase 1?
Bill B
On 4/8/2013 9:37 AM, johngoodman wrote:
#40572 Phase One complete and flying.
http://forums.matronics.com/viewtopic.php?p=398134#398134
johngoodman
Posted: Mon Apr 08, 2013 5:54 am Post subject: Re: Butt Splice for #4 wire |
[quote="bbradburry(at)bellsouth.n"]John,
Bill B
Bill,
No, I've been flying for almost 2 years. The wire was unsupported for the last 7" to 9" and I figure it was like a hand shake that wouldn't stop....
Posted: Mon Apr 08, 2013 10:13 am Post subject: Butt Splice for #4 wire |
Did you put heat-shrink over the wire-grip and
wire? More specifically, double-walled
heatshrink . . . very stiff?
Whether crimped or soldered, stranded wires
experience a stress concentration at the
transition point from solid to stranded. When
we sold terminal kits for installation
by soldering
http://tinyurl.com/ct36xen
the kit included a 2" piece of double-wall
heatshrink to provide insulation support.
Many builders have expressed a preference for
the 3-ring format. You can take your bound book
to a copy/print shop like Kinkos and have it
drilled for ring binder. They also have a paper
cutter that will shear off the spine.
Cut the spine off first so that the drilled
holes have the right edge margins.
Do you still have the terminal that broke off?
I'd like to have it if you could see fit to
mail it to me.
johngoodman
Posted: Mon Apr 08, 2013 2:34 pm Post subject: Re: Butt Splice for #4 wire |
| Quote: | Did you put heat-shrink over the wire-grip and
by soldering
I'm pretty sure it's regular heatshrink, although I have a couple of pieces of the double-wall stuff laying around.
| Quote: | Do you still have the terminal that broke off?
mail it to me. |
Yes, I do still have it. My e-mail is johngoodmanATearthlink.net
Send an address, and I'll mail it. The fatigue point is very close to the terminal.
toaster73(at)embarqmail.c Guest
Posted: Mon Apr 08, 2013 5:34 pm Post subject: Butt Splice for #4 wire |
John,
Did I miss it - I am sorry, but can you explain how you discovered the
problem? Was it complete disconnect? Was the break on the alternator end or
firewall end?
Chris Lucas
N919AR
40072
johngoodman
Posted: Tue Apr 09, 2013 4:49 am Post subject: Re: Butt Splice for #4 wire |
| toaster73(at)embarqmail.c wrote: | John,
firewall end?
Chris Lucas
N919AR
40072
The break was on the starter power lug. I have two wires on that lug - a #2 from the rear battery, and a #4 that goes around the engine to the lug on an ANL type fuse connected to the alternator - that's how the battery recharges.
A couple of flights ago I noticed that I only had about 12V on the battery after start, but my backup battery was fine. I figured the battery was beginning to fail, or there was some kind of grounded lead. I was getting large amp draws during start, so I figured that it had something to do with the starter/solenoid. I pulled the cowling and concentrated on the positive lead on the solenoid, but the big cables were getting in my way. I decided to remove them to get more room.
The #4 looked fine as I removed the nut, but as soon as a pulled it off the lug, the terminal was only hanging on by a couple of thin wires and a small piece of the heatshrink. The only thing that had been keeping it together was the heatshrink and the natural propensity of the wire to stay in place.
My only explanation is that the 7", or so, of cable between the terminal end and the first adel clamp, had enough weight and motion to respond to vibrations, and eventually fatigue the cable.
Hope this explains it.
Posted: Wed Apr 17, 2013 4:29 pm Post subject: Butt Splice for #4 wire |
At 07:49 AM 4/9/2013, you wrote:
--> AeroElectric-List message posted by: "johngoodman" <johngoodman(at)earthlink.net>
>wires and a small >piece of the heatshrink. The only thing that had
John sent me the carcass and we've had a chance to
peek inside the failure . . .
[img]cid:7.1.0.9.0.20130417192013.04c572e0(at)aeroelectric.com.0[/img]
95% of the strands failed right outside the crimp . . . a
telltale for insufficient insulation support like that offered by
PIDG style terminals.
A cross-section of the wire grip . . .
[img]cid:7.1.0.9.0.20130417192013.04c572e0(at)aeroelectric.com.1[/img]
. . . showed good crush . . . no voids. I'm pretty sure that
a piece of that extra stiff, two-walled heat-shrink over this assembly
would have produced a better story.
77.9 KB |
8617 Time(s) |
90.23 KB |
8617 Time(s) |
