Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat Apr 06, 2013 3:04 pm Post subject: Flap Switch |
Has anyone found a source for a good, quality DPDT (mom) off (mom) toggle switch (preferably with a duck bill toggle)?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
psm(at)att.net Guest
Posted: Sat Apr 06, 2013 3:18 pm Post subject: Flap Switch |
Hi Tim,
I think I got mine at radio shack for a couple of bucks. It has a flat
handle rather than duck bill, but that is close enough.
Paul
Camas, WA
On 4/6/2013 4:04 PM, Tim Juhl wrote:
______________
CFII
Champ L16A flying
Wing modifications done - back working on the fuselage
http://forums.matronics.com/viewtopic.php?p=397983#397983
andrewtub
Posted: Sat Apr 06, 2013 3:39 pm Post subject: Re: Flap Switch |
http://www.bandc.biz/toggleswitch-doublepole.aspx
Me and two other 601's in our club are using the S700-2-5 (ON)-OFF-ON. Momentary for the down and maintained for the up. Flaps will turn off automaticly when they hit the up limit switch. When you are ready to retract the flaps just hit the switch. This will free up your hand to do other things instead of holding the switch.
aircraftspecialty(at)gmai Guest
Posted: Sat Apr 06, 2013 3:46 pm Post subject: Flap Switch |
Www.aircraftspecialty.com has a nice aftermarket flap handle that fits over a standard size existing toggle.
Steve
On Apr 6, 2013, at 18:35, "Craig Payne" <craig(at)craigandjean.com> wrote:
B & C? They carry lots of the items Bob Nuckolls recommends in his designs.
S700-2-7 (ON)-OFF-(ON) (+ $15.00)
Unfortunately only with a "bat" handle.
Digikey may have flat handled ones but in the ones I've seen where the flat
is plastic the plastic part tends to rotate on the metal shaft after a
while.
Ray Allen Company (known for their trim servos) makes a nice rocker switch
(not a toggle) with two good quality micro-switches inside. The RS2 is only
rated for an amp but the RS2-5 is rated for 5 amps. Because the way the
switches are wired when the rocker is in the center position the motors
windings are shorted which keeps the motor from coasting.
http://www.rayallencompany.com/products/switches.html
http://www.rayallencompany.com/RACmedia/instructionsT2andT3.pdf
http://www.rayallencompany.com/RACmedia/instructionsRS2withmods.pdf
-- Craig
erwinfbeckman(at)gmail.co Guest
Posted: Sat Apr 06, 2013 4:48 pm Post subject: Flap Switch |
Have you tried B&C Electronics? Check out Aeroelectric Connection by Bob Nuchols.
www.bandc.biz will get you there.
On Sat, Apr 6, 2013 at 6:04 PM, Tim Juhl <timjuhl(at)frontier.com (timjuhl(at)frontier.com)> wrote:
[quote] --> Zenith601-List message posted by: "Tim Juhl" <timjuhl(at)frontier.com (timjuhl(at)frontier.com)>
______________
CFII
Champ L16A flying
st" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
le, List Admin.
smgores
Posted: Sun Apr 07, 2013 11:35 am Post subject: Re: Flap Switch |
Tim,
Bob Nuckolls shows how to make your own flap switch handle.In the 2nd picture he mentions aluminum but I think he meant a type of plastic for the handle.
http://www.aeroelectric.com/Pictures/Switches/
Mike
Rochester,mi.
Posted: Sun Apr 07, 2013 12:40 pm Post subject: Flap Switch |
I don't think the post worked yesterday, but we make flap handles out of aluminum and powdercoat them. We have sold very many and received lots f positive feedback.
Steve
www.aircraftspecialty.com
