Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Wed Apr 03, 2013 7:50 pm Post subject: Engine Removed |
Galin,
Sounds like you have it under control. Was the part number on the shock that you pulled out? I believe it was a auto shock what should still be available.
Bob
To: "kis-list(at)matronics.com" <kis-list(at)matronics.com>
Sent: Wed, April 3, 2013 9:23:50 PM
Subject: KIS-List: Engine Removed
We removed the engine and got a good look at the firewall. The damage is minimal just as we thought.
So I am going to take advantage that the engine is off and do several things. Lyle Hendricks is going to fabricate the parts so I am going to replace both lower brackets, the H bracket and both steel pins within the H bracket. I am going to change the shock absorber inside the nosewheel assembly. The exhaust system was sent out to get a completely new stainless steel exhaust built. I am also going to replace the fuel boost pump and all the bolts/nuts/washers I can get my hands on.
BTW: What kind of shock absorber do you guys use in your nose wheel assembly. The one I pulled out looks to be about one that Christopher Columbus brought over on his 1st trip to the new world.
sstearns2(at)yahoo.com Guest
Posted: Wed Apr 03, 2013 8:38 pm Post subject: Engine Removed |
Are you getting the exhaust ceramic coated?
On Apr 3, 2013, at 7:21 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]We removed the engine and got a good look at the firewall. The damage is minimal just as we thought.
<DSCN7117.JPG>
<DSCN7119.JPG>
<DSCN7123.JPG>
<DSCN7112.JPG>
galinhdz(at)gmail.com Guest
Posted: Wed Apr 03, 2013 9:57 pm Post subject: Engine Removed |
Probably not. I have read a lot of information that ceramic coating makes it impossible to repair and also contributed to pre-mature failures. Here is a link to Vetterman Exhaust that talks about ceramic coating.
http://www.vettermanexhaust.com/
On Wed, Apr 3, 2013 at 11:38 PM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
[quote]Are you getting the exhaust ceramic coated?
| Quote: | We removed the engine and got a good look at the firewall. The damage is minimal just as we thought.
<DSCN7117.JPG>
<DSCN7119.JPG>
<DSCN7123.JPG>
<DSCN7112.JPG>
