yakpilot(at)comcast.net Guest
Posted: Mon Apr 01, 2013 9:11 am Post subject: Check Valve |
p { margin: 0; }Does anyone recognize this check valve, and which system it belongs to?
CROL
91.7 KB |
4531 Time(s) |
395.61 KB |
4531 Time(s) |
Posted: Mon Apr 01, 2013 9:20 am Post subject: Check Valve |
Are you sure it is a check valve?CJ or yak?
Doug
On Mon, Apr 1, 2013 at 10:09 AM, <yakpilot(at)comcast.net (yakpilot(at)comcast.net)> wrote:
[quote]Does anyone recognize this check valve, and which system it belongs to?
CROL
Posted: Mon Apr 01, 2013 9:37 am Post subject: Check Valve |
Yak.
Think it is a check valve, as it has some "internals", plus the arrow indicator. C
On Apr 1, 2013, at 12:17 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
[quote]Are you sure it is a check valve?CJ or yak?
Doug
| Quote: | Does anyone recognize this check valve, and which system it belongs to?
CROL
wlannon(at)shaw.ca Guest
Posted: Mon Apr 01, 2013 10:25 am Post subject: Check Valve |
Yes, definitely not CJ. Is the invisible end closed?? Or internal threaded for a fitting?
If threaded it could be some kind of check valve – non-return, reduced flow, etc. If closed it may contain a piston & spring and function as an anti-hammer or cushion.
Walt
Sent: Monday, April 01, 2013 10:34 AM
Subject: Re: Check Valve
Yak.
[quote] Are you sure it is a check valve? CJ or yak?
Doug
CROL
href='wlmailhtml:3D"http://www.matronics.com/Navigator?Yak-List"'>http://www.matronics.com/Navigator?Yak-List
href='wlmailhtml:3D"http://forums.matronics.com"'>http://forums.matronics.com
href='wlmailhtml:3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
Posted: Mon Apr 01, 2013 10:50 am Post subject: Check Valve |
Female end is threaded for fitting.
C
On Apr 1, 2013, at 1:22 PM, "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
[quote] Yes, definitely not CJ. Is the invisible end closed?? Or internal threaded for a fitting?
Walt
Yak.
| Quote: | Are you sure it is a check valve? CJ or yak?
Doug
CROL
cs.com
Vic
Joined: 12 Aug 2008 Posts: 117 Location: Southern Bavaria
Posted: Mon Apr 01, 2013 4:29 pm Post subject: Re: Check Valve |
Hi,
I suspect this valve is not complete, one male end missing. But no idea ....
Vic
219.49 KB |
4499 Time(s) |
keithmckinley
Posted: Thu Apr 04, 2013 5:09 am Post subject: Re: Check Valve |
It has a russian letter on it.
