Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Thu Mar 21, 2013 6:39 am Post subject: Seat backs |
OK, Maybe I'm missing something here but I have one of "those" questions. Before you ask, I did a search but turned up nothing useful.
Looking at the XL cockpit, I'm wondering what others have done to deal with the wide gap behind the seat back? Do you build some kind of stiffening into the seat cushion or?
I was thinking of spanning the gap with some 0.016 or 0.025 held in position by screws and nutplates. Comments?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
n1269k
Posted: Thu Mar 21, 2013 6:49 am Post subject: Re: Seat backs |
Hi Tim
My seat back cushion is made of, I think, 3/8" plywood. Works great.
Terry
psm(at)att.net Guest
Posted: Thu Mar 21, 2013 7:12 am Post subject: Seat backs |
Hi Tim,
I made seat backs from plywood - 1/4 inch Nordic Birch, I think. Each
seat back is held in place with 4 screws and nut plates.
I don't think you want to seal up the big hole between the baggage cross
piece and the one on the fuselage bottom. Access is necessary to get to
the aileron cables and other stuff that winds up back there like radio
antennas. I also have a bunch of electric barrier blocks to connect all
the stuff in the rear to the instrument panel. This includes stuff like
trim switches on the stick, radio transmit key, lights, and I don't know
what else. I used barrier blocks from Radio Shack mounted on bent
aluminum pieces.
Paul
Camas, WA
On 3/21/2013 7:39 AM, Tim Juhl wrote:
______________
CFII
Champ L16A flying
Wing modifications done - back working on the fuselage
http://forums.matronics.com/viewtopic.php?p=396740#396740
bryanmmartin
Posted: Fri Mar 22, 2013 1:16 am Post subject: Seat backs |
I used 1/8" birch ply-wood; The stuff used under vinyl flooring. I riveted a strip of aluminum angle horizontally a few inches below the top and bent that around the top edge of the baggage shelf support. The seat back cushion is velcroed to the wood. There are no fasteners holding the wood in place, just gravity. I can just lift up on the seat back to disengage the aluminum angle from the shelf support and fold it forward to access the area behind the seat.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
On Mar 21, 2013, at 10:39 AM, "Tim Juhl" <timjuhl(at)frontier.com> wrote:
_________________ --
Bryan Martin
do not archive. |
Ron Lendon
Posted: Fri Mar 22, 2013 8:22 am Post subject: Re: Seat backs |
1/4" Luan in the seat back cushion, just fits in the seat cover and is zippered into the cushion. Industrial Velcro holds things in place. Followed http://www.seatfoam.com/index.html guidance in carving the foams up. Pretty sure I purchased the foam from them also. Not cheap but very comfortable on long flights.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
paulrod36(at)msn.com Guest
Posted: Fri Mar 22, 2013 2:06 pm Post subject: Seat backs |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I think you'll find the aluminum to be a bit too flexible. I used some 3/16" underlayment plywood from Lowe's, (nice looking grain) 22" wide, and about 19" long, and fabricated tops to go over the seatback top. Easily removable, and nice and strong.
Paul Rodriguez
larrycmcfarland(at)gmail. Guest
Posted: Fri Mar 22, 2013 7:21 pm Post subject: Seat backs |
Hi Tim,
I’d suggest you look at the seat page I put together for the 601
http://www.macsmachine.com/html/seatupholstery.htm
Hope it is helpful,
Larry McFarland
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of paulrod36(at)msn.com
Sent: Friday, March 22, 2013 5:06 PM
Subject: Re: Seat backs
Paul Rodriguez
Tim Juhl
Posted: Tue Mar 26, 2013 3:48 pm Post subject: Re: Seat backs |
All very useful information, thanks!
I should have asked this question at the start but here goes. I haven't crawled into my fuselage yet (think I'll wait until it is on the gear) but was curious about the optimum height of the seat back. I'm 6'1" tall, so can anyone suggest how much, if any, I should extend the seat back above the top support? With the laid-back orientation of the Zodiac seat I would think that some head support would be in order.
Thanks!
CFII
Champ L16A flying
Posted: Tue Mar 26, 2013 4:16 pm Post subject: Seat backs |
Hi Tim,
I don't have any head support in mine and I am comfortable in the seat.
The important issue, from my perspective, is the constitution of the
cushion you provide for the seat. This trumps the seat back which
mostly serves to cover the big hole below the baggage compartment cross
piece.
I got a hold of three different kinds of foam which I used in my seat
cushions. There are two different memory foam (pink and blue) and heavy
grade polyurethane foam on top - the kind recommended for dinner chair
cushions. These are covered with Duck cloth. I wanted to try leather
but I decided the cloth was more comfortable.
Have fun,
Paul
Camas, WA
On 3/26/2013 4:48 PM, Tim Juhl wrote:
Thanks!
______________
CFII
Champ L16A flying
http://forums.matronics.com/viewtopic.php?p=397144#397144
bryanmmartin
Posted: Wed Mar 27, 2013 1:33 am Post subject: Seat backs |
I built a mock-up of the seat from wood so I could test the seat design. I used the mock-up to build up the seat foam pieces and glue them together before I took them in to the upholsterer. It was easier than trying to do it in the cockpit itself.
Bryan Martin
N61BM, CH 601 XL,
On Mar 26, 2013, at 7:48 PM, Tim Juhl <timjuhl(at)frontier.com> wrote:
| Quote: | I should have asked this question at the start but here goes. I haven't crawled into my fuselage yet (think I'll wait until it is on the gear) but was curious about the optimum height of the seat back. I'm 6'1" tall, so can anyone suggest how much, if any, I should extend the seat back above the top support? With the laid-back orientation of the Zodiac seat I would think that some head support would be in order.
Thanks!
Bryan Martin
do not archive. |
